[ROM] POISONATV S912 NEW V4 [20190317] *UPDATE*
Originally posted by enerdude View Post
No there was no 4.4, goes from 4.3 to 4.5. There was however a fix after 4.3 for some people that had issues with google play which I guess was sort of 4.4
Originally posted by minixfreak View Postalright guys neomode will update the p0ost later , but here are the links for v4.5 .... i never did a changelog but it should be stable with no bugs
https://mega.nz/#F!A8BihSCb!EA2vnBM6sqVX8BYll-W_PA
NC
I just flashed on my H96pro+.
Same issue here, on setup cant detect network either ln wifi or cable.
When try open google play, it popup a screen said no internet connection.
Double checked, cable working and wifi working when run youtube or play trailer from google play movie.
Edit:
Same for me, from Malaysia.
I manually fix google play by restoring google play store and services with Titanium backup.
Other than the initial setup that affect google play store, so far the rom is solid.
Magisk still work nicely per V4.2.
Thanks.
Double checked, cable working and wifi working when run youtube ornplay trailer from google play movie.
Edit:
Thanks.
force erase with usb burning tool .... if your using sd card method always gives issues
Not helping, not sure what is the real problem when Internet clearly no problem.
It seems to me during first startup, the setup is not able access to Internet. Clearly hardware have no issue as after finished the setup without network, youtube and Internet is working.
remember everyone PLEASE USE USB BURNING TOOL with force erase all option , if your using sd card method that always gives issues ..... i assure you usb burning tool with force erase all works and wont have issues .... and if u do have a bit of issues on first boot its because of my performance scripts running with second reboot will fix ..... hope you all enjoy and follow instructions then if anything persists then by all means let use know
Already with burning tool and forcd erase and erase bootloader.
There are currently 3188 users online. 1 members and 3187 guests.
