[ROM] POISONATV S912 NEW V4 [20190317] *UPDATE*
    Originally posted by muncheno View Post
    I will try test it again on tmr or Friday with my T95Z.
    Additional finding here, airscreen working on V4.2 but not V4.5 bcoz of advertisements blocked. Not sure why.
    i added a hosts file that blocks ads its such an easy fix
      Allready install rom and works perfect.but i dont see any differences...its like 4.3.only gui change
        Well firmware 4.5 working on my minix u9h very well.nice job. Sleep mode is working well, that does the job for me the only issue I have is the USB port, it's not working. But minix freak explained to me that it's an issue with the minix firmware . I hope he gives me a hand to solve this issue stb emulator is working very well channel change very faster than before
          I tweaked it to the max ... 32 scripts running for performance and played with codecs and all and fixed setup bug also ui is different as well
            Great job on this Rom- installed on Tanix tx9 Pro lpddr and everything works great exept clock patch but I flashed old clock fix for another rom and it works. Well done Poison team!
              OK on my TX9 pro and T95z plus 3gb 32gb.
              I will test gigabit lan asap
                So the gigabit lan works perfectly on My Tx9 pro but on my t95 z plus works for somes seconds and switch to disconnected.
                Other little things : Netflix ESN is empty ( maybe a result of "force erase all" )
                  Can you tell me how to fix this hosts file?
                  Thanks.
                    Thanks.
                    use file explorer that hgas root access go to device-system-etc and erase hosts
                      Thanks. Easy enough.
                        Hi everyone, congratulations for your Rom. I have a box h96pro plus ddr4 3gb ram 32gb. poison atv 4.5 everything works fine, ram shown 2,449 on 3gb ram I suppose it's for ddr3 and not ddr4. Do you have any solution? besides wifi, airscreen works all very well except the bluetooth that when it remains active drops the wifi. 9377. unpacking the firmware and putting the original bootlader I would lose the scripts and all the optimization functions? I await your news, thank you.
                          Whitch img is the right one for the H 96 pro plus? I try the PoisonATV_V4.5_S912 but when i set the sd card back in the box, the upgrading screen comes only a few seconds,than it went to black?? When i try the PoisonATV_V4.5_S912_LPDDR and insert the sd card to the box nothing happen, it won?t upgrade. Ps i use Burn Card Maker
                            PoisonATV_V4.5_S912 is the right one mate. I install this with burn card maker to.check force erace all at burn card maker
                              Win 10 doesn?t recornize my box with a male to male usb
                                Same problem here
