[ROM] POISONATV S912 NEW V4 [20190317] *UPDATE*
Great ROM!!!Fast and clean!!!!
Just for know...
(after various rom tests on this device i would like to give a test also on this but burning tool stop at 7%!!!)
Tried to install PoisonATV_V4_S912 on my Beelink GT1 Ultimate A706D0 3/32gb (but "fake RAM")..
(i've also change my 3 usb ports & test + restarting my PC when i change version of tool!!)
N?of try
01-02-03 : Usb tool 2.0.7.2 portable & Normal Erase ...result FAILED!
03-04-05 : Usb tool 2.0.7.2 portable & Force Erase ...result FAILED!
06-07-08 : Usb tool 2.0.8 installed & Normal Erase ...result FAILED!
09-10-11 :Usb tool 2.0.8 installed & Force Erase ...result FAILED!
12-13-14 : Usb tool 2.1.7 installed & Normal Erase ...result FAILED!
15-16-17 : Usb tool 2.1.7 installed & Force Erase ...result FAILED!
18-19-20 : Usb tool 2.1.6 installed & Normal Erase ...result FAILED!
21-22-23 : Usb tool 2.1.6 installed & Formal Erase ...result FAILED!
24-25-26 : Burn_Card_Maker (2 times i tried ) but ...result FAILED!
So before turning back to the original rom because i was "tired.." (over 25-30 times under test!!!) ...the fortune .....
i said to test for the LAST time with my favorite version of Usb tool 2.0.7.2 portable & Force Erase...
and VOILA'!!!!!!!!!!
The installation finish with SUCCESS!!!
Original remote & Mini touchpad works great.
WIFI & Ethernet also.
Thanks all of you for this great rom.
After successfully installing this Rom on m8s plus L I did some testing and found that it was not as responsive as the 1gb s905x poisonatv rom. I found that strange considering that this box has 2gb and supposedly better cpu. Intalled cpu-z and it only detected 1gb of ram same with aida64. What can I do to try to fix this?
Good morning,
My brother reached out to me and asked me to install this ROM on his Alfawise 96 Pro +, which I did with no issues. I have added the TV app repo to this ROM for other short cuts to be added to the main app list. My question is trying to boot in to recovery, i went into the settings under power and there is no option for booting into recovery. Is there a other option for booting into recover.
BTW This is a very nice ROM, great job Team Poison
Thanks,
NC
Thanks,
NC
That's it....
New Version is out V4.2 thanks to minixfreak for his Work.
Please see in the first Post for new Download URL!
Neomode
Originally posted by neomode View PostNew Version is out V4.2 thanks to minixfreak for his Work.
Neomode
Originally posted by antonio6o6 View Posti have waiting seen firmware v1 v2 v3 v4. V4.2.same. Remote issues.usb port not working. Whet back stock firmware minix u9h
There are currently 2678 users online. 2 members and 2676 guests.
