Originally posted by shehatasat View PostI am thinking of buying one but my question is
how to know fan device from fan less?
ThanksKris....don't forget my boxes! Okay?
gona try the new hibernation feature because the sleep isnt working right has trouble coming out of sleep now not sure why but i did find a workaround for my location issue if i go and set it on and not go back into location setting it stays on but if i go back to see if its on it turns it off so set and leave alone
Originally posted by Sterno View Post.....set it on and not go back into location setting it stays on but if i go back to see if its on it turns it off so set and leave alone
Seems like ya getting your pro skills fine tuned to me.
ya i dont understand it but a lot of these new boxes have 64bit cpu and 32bit OS i just dont see why not put a 64 OS
Rockchip devices run 64-bit OS but then you have an older CPU like RK3399 or RK3328.
The problem is Amlogic the chipset vendor of S922x, S905x never asked all the manufacturers of the wifi, bluetooth, ethernet, HDMI etc. to develop 64-bit drivers, now there aren't any. You can build a 64-bit OS for Amlogic devices but half of the components won't work or boot since they only have 32-bit drivers.
There are currently 2357 users online. 1 members and 2356 guests.
