    Originally posted by Spastro View Post
    Does ota update work with this box...
    ... Or, Do we Have to play with flashburning tools?
    OTAs @ ugoos/downloads/? device.
    What? ... and miss out on all the fun?
      Does ota updates work with this box to get it up to date or do we have to play with and cards and flashburning tool to get updates on?
      Hi ,
      yes it works , Ugoos is for sure the only one , with workin OTA , BUT not
      so often as sometimes needed or wanted , for sure not a bad choice ,
      good luck / gefattern
        Thanks. Was looking at the am6 pro as I think I just bricked my old MeCool m8s
          My Ugoo6 arrives by Monday.
          Any 1st steps, extra steps, or special advice for "moving-in" from the n6, or M8S Pro?
          Should I go from scratch, or let Google handle the bulk of it?
          Does the device or you have a sequence of priority, etc. which supports a smoother more stable set-up?
          "Tards" question...How to move a complete TitaniumBackup over to new box? Never had much luck, I must be exacuting the nand-BkUp wrong for starters.
          Would the titan-BkUp from the rockCp be useless, as compared the s912Aml?
          ... As far as migrating the individual app settings? Just trying to get a baseline install done to save a little infinite tweaking time. Thanks!
          ;~0 ...or I can just go at it, COMMANDO Style ?!
            Hi ,
            dont think that you get Problems with TB between two different SOCs , for Data & OBB Backup i always copy the whole "Android" Folder to SD ,
            then to new Device & then restore TB , so no need to download obb Files again , reboot and try , a Backup on SD or PC is always good ,
            hope you get it , good luck / gefattern
              thanks! we will give it a go.
                Doesn't TB require root on each device to do a complete backup/restore?
                  Hi ,
                  yes , Ugoos Roms have "Root" option , so no Problem ,
                  greetings / gefattern
                    I just received the AMD 6 Pro 4gb / 32 version.
                    Also bought the MX3 MX3-L Backlit Air Mouse Smart Voice Control 2.4G RF Wireless Keyboard Remote Voor X96 mini T9 A95X H96 MAX Android TV Box.
                    Its a Great Player, never gonna buy a Minix again.
                    I got a few small problems with setting it up:
                    I bought Nova Launcher Prime a long time ago.
                    Root is enabled.
                    Updated the Box to latest UGOOS 9.0 v0.2.1 update.
                    But I can't add widgets to my Home screen with Nova Launcher... Or drag & drop app shortcuts..
                    Stock Launcher works.
                    Niagara Launcher also.
                    Any Idea?
                    And YouTube isn't installed & want to use YouTube Vanced.
                    Which YouTube Vanced module should I use?
                    Tried the latest Root v7a and V8a White / Black version.
                    Can't install them...
                    Which architecture is this box?
                    Also use a paid VPN service, Wifi is secure & stable, Ethernet drops the connection?
                    Is this a UGOOS bug?
                    Best regards
                    D.
                      Originally posted by Duvel View Post
                      Also bought ??? the MX3 MX3-L Backlit Air Mouse Smart Voice Control 2.4G RF Wireless Keyboard Remote Voor X96 mini T9 A95X H96 MAX Android TV Box.
                      Root is enabled.
                      Updated the Box to latest UGOOS 9.0 ??? v0.2.1 update.
                      Any Idea?
                      Best regards
                      D.
                      I know what is causing Nova to not work with widgets, will try to send Ugoos a bug report.
                      All Amlogic devices are 32-bit, so you can use the arm(not rm64) versions of Youtube Vanced, MicroG.
                      SmartYoutubeTV also works well.
                      You can also upgrade to v0.2.2 firmware to fix the ethernet bug with VPN.
                      Here is AndroidTV v0.2.2 but you must flash through a PC with a USB-USB cable.
                      https://forum.freaktab.com/core/images/icons/icon3.pngUpdate: [ROM] Ugoos AM6 Android TV by Sasvlad 0.3.6 (Dualboot and SingleBoot) Suitable for AM6, AM6 Pro and AM6 PLUS. Dear friends, I present to your attention my new hybrid for ATV lovers. Many thks to UGOOS for sending me the device to play. Why a hybrid? Anyone
                      "10. Fixed ethernet link down if enable VPN"
                        Thank you for your reaction. Gonna do that.
                          Thank you for your reaction. Gonna do that.??
                          There is actually an even newer firmware.
                          The first one is for flashing from a PC.
                          The second firmware, ota, you can copy onto a USB drive and point the Ugoos Updater app to it and then it will update on the device itself without a PC or downloading the ota manually which is not available at the moment until more people test this new firmware I heard.
                          This is the normal Android firmware, not AndroidTV.
                          v0.2.3
                          1. Fixed CEC wake up
                          2. Added CEC work with function "disable auto power-on"
                          3. Improvements of system automatic frame rate function for more stable work with program AFR functions
                          4. Fixed video offset (black stripes), if use custom display size
                          5. Fixed colored stripes bug when boot with AV and on some old TVs
                          6. Replaced Android TV Remote Service to version from play market
                          7. Fixed bug, not showing all external storages for Samba Server
                          8. Added usb audio settings, removed USB audio routing from developer settings
                          9. Fixed CPU load with droidlogic app
                          10. DolbyVision disabled by default
                          11. Fixed "None" proxy setting
                          12. Fixed static ip settings bug, not showing current dns servers
                          13. Added custom ir power key setting
                          14. Some changes in deep color setting
                            Can I OTA update with Root or should I disable it?
                              Hi ,
                              if Update available , no Problem for sure it must work ,
                                am6 Arrived Saturday 11/09,
                                somehow the Rii i4 keyboard came same day... yippee!
                                Both pcs are the MOST Impressive items ever purchased from gearbum!
                                Build quality, Look, feel, and operating performance is excellent and exceptional.
                                ... I am now Melting down the M-see N6 and sending an equal share to each MagicSuk and GearBust.
                                ... as a little token of my appreciation for all the good times had with that lil' Snafu.
                                Last edited by ClarkKent; 11 November 2019, 17:21. Reason: deleted extra characters injected by Vmod, sheez!?
