Again, I do not have the AM6 and I have never used the Linux tool. I do not know if it will work on your AM6, as the instructions there are for Khadas products. Additional info(scroll down to Linux section) is here, maybe you can get something out of it, but again, instructions are for Khadas products. FYI The Khadas VIM3 uses the Amlogic a311d SoC, that is closely related to the Amlogic 922x SoC used in the AM6.
Wish I could help, but I do not have the experience to do so.
balbes150 gives some instructions above about getting the box into upgrade mode using the Windows USB tool, maybe the same procedure will work on the Linux tool.
Good luck.Last edited by RISCy Dude; 15 September 2019, 10:06.
Originally posted by Sterno View Post....ok thanks
HE EVAN HAS ONE FOR THE (rk3399) N6, running from a sd card. Of course you must create the boot able card first. Idk you could do it w/o a pc. GoodLuk!Kris....don't forget my boxes! Okay?
balbes150 said, "At the bottom there is a hole, behind it there is a button, you need to gently press it and hold down, connect the power cable and then connect the USB cable.
1.) Push and hold the button, keep holding that button until Ubuntu picks it up, then release the button.
2.) Connect power cable
3.) Connect USB cable.
While I do not have the AM6, that procedure is similar to devices I do have.
There are currently 1547 users online. 0 members and 1547 guests.
