    Originally posted by Sterno View Post
    nope tryed it i suspect its a hardware issue
    Stock ROM? Guess it could be Hardware. Cuz if you had an OS on an SD, that it could find & default to... Then,
    It should go, right? I mean you shouldn't even have to be in recovery
    **SUK!
      Originally posted by ClarkKent View Post
      Stock ROM? Guess it could be Hardware. Cuz if you had an OS on an SD, that it could find oh, default to... It should go, right? I mean you shouldn't even have to be in recovery
      **SUK!
      thats what i think bad rom it wont even load boot screen
        hey clarkkent is the brand of your box a magicsee ?
          Yes Sir...a giant among midget Chinese Tech minds. Er, so I've been told.
            how long have you been using it is it a stock rom ?
              ?? stock rom ?
              7 months? & Yes. But, Fairly personalized with custom adds, as mentioned.
              ~~ PM me pls or hit me on N6 thread if needed?
                ya about the n6 updates iv had a couple leelboxes and never seen a single update for them iam an advanced user but by no means an expert ive crippled a couple rooted boxes but never actually bricked one (knock on wood) LOL
                Perhaps the problem with firmware. Try recording to external media (SD card or USB flash drive) Libreelec or Armbian and check their run. Either check write firmware via USB cable in the locked eMMC (it helps if he corrupted u-boot in eMMC).
                  i tried but the boot process does not get far enough to get to recovery screen
                    ok thanks
                      You don't need a recovery screen. Start USB Burn Tool, select firmware, press Start button in the program. After this preparation, hold down the button on the AM6 and connect the USB cable to the AM6.
                      You need to run the forced firmware mode (this is analogous to shorting contacts on the eMMC when restoring it from the brick).
                        do i need a windows cpu to do this ? i do not have a windows cpu
                          There is a USB Burn Tool for Linux(tested on Ubuntu 16.04) not sure it will work on your AM6. I have not used the Linux version, so I cannot help with that.
                            where can i get it ? i do not see it on ugoos site
                              I learned of it over at Khadas' site. I am only a casual Linux user, so I cannot help with it. Please don't blame me if it bricks your box, oh, wait a minute, too late.
                              Seriously though, hope you get your AM6 back on its feet.
                                ok thanks
