...Or, will it Brick the box still ??
Originally posted by ClarkKent View Postsmall 84mg ota came down today, no problem update.? ? SU 2.82 loaded, but wants to update binarys....Is the a Go on the 922x/ A9?
...Or? will it Brick the box still ???
Originally posted by RiCkLaR_atvX View Post
Don't update Binary! ..... it will definitely brick the device. SuperSU apk was last updated for Nougat and is not properly formatted for Pie.
Does the apk Still support the paid 'PRO' key ver?
I know they sold the SW line-up. Of Course I bought the proV. yet and it's really tough to find again. It may have been abandon, or rendered mute IDK?
I Can't to keep ram below 75%. IT was running about 55% last eve, and quite well too. Seems awfully strange and inconsistent behavior.
Especially since the cores are hardly working, and since yesterday the only changes have been to freeze google chrome and a couple others like Kernel/ CPU apps.
In other words, trying a 'clean os' approach.... and taking the update.
"Most Illogical Jim" ~spock
ClarkKent have you heard of the Apps: Greenify or KillApps ??? I use both and generally have both installed in all my Android devices. Both have a service to run a permanent notification so you can easy pull down the notification window and activate Kill-All-Apps(KillApps) or activate Hibernate(Greenify). Both also can make a widget for the Homescreen if you are using a launcher that allows widgets. These apps will keep you ram usage clean from storing background app and process.
Also in all my Rooted devices I run the Adaway apk to block/stop all those pesky Ads-Ad trackers-Analytics that can fill your ram, it is not a lot, but still I don't appreciate apps running all these background services to collect analytical data on everything your device does. Adaway can be found on Android File Host with details posted on XDA-developers.com
Another App that is good is the All-In-One Toolkit app, it can boost Start-up which actually is list of all your apps installed that are allowed to start/open at boot; which you can disable-ALL for the user installed apps and then just activate(toogle On) the apps you feel are vital to device usage like Adaway, Greenify, and your VPN.
Hope that helps,
Cheers
Originally posted by Duvel View Post@ mo123 where can I find the latest firmware for this box like you offered us? At Ugoos?
You can also check their blog https://ugoos.com/blog and androidpctv.com
I also sent Ugoos patches to add extra game controllers, fix nova launcher to work with widgets and to add changes to make the home button work so if AndroidTV firmware is built by users that it can work there.
The latest firmware is v0.2.3 but I heard some users already got a new ota update, not sure on which firmware they are on.
Originally posted by mo123 View Post....The latest firmware is v0.2.3 but I heard some users already got a new ota update, not sure on which firmware they are on.
v0.2.3 dated 2019 07 11 just a tweak tho, most didn't pertain to me. took it anyways.Last edited by ClarkKent; 17 November 2019, 18:54.Kris....don't forget my boxes! Okay?
Originally posted by Duvel View PostCould Magisk be installed instead of SuperSu?
Than also .zips, like Customs Roms & TWRP installer zips could be used.
And Magisk module like YouTube Vanced etc.
I use this on my One Plus.
Youtube Vanced can work but you need to install the YV and MicroG app.
At the moment Youtube Vanced website is down, so you need an older version.
Magisk will hopefully be supported in the future, but it's a problem on all Amlogic Pie devices at the moment.
Originally posted by ClarkKent View PostPick up your OTA file from ugoos downloads/product/ am6
use the ota, move/ copy to thumb drive or SD card. Reboot to recovery and select file....Should go just fine.
I the zips contain an img. flash file via .PC
I downloaded OTA 0.2.3 to usb key & pointed the Ugoos updater to the file & it loaded without problems.
Originally posted by maryann View Post
Thank you for that.
.... it loaded without problems.
Surely all these will be included in the next larger (full) update.
I do believe that this 85mg auto ota does change the cec service.
enjoy!
There are currently 1695 users online. 1 members and 1694 guests.
