UPDATED - CX919 - 4.2.2 - Finless ROM 1.6b
    Does this work on the tronsmart cx919 ?
      Apparently not, but finless 2.0 kitkat rom works fine...
        Re: UPDATED - CX919 - 4.2.2 - Finless ROM 1.6b
        Which cx919 then?
          Which cx919 then?
          The tronsmart cx 919 with rk3188T bought from geekbuying..
            Yes i meant that one, read my comment.
              after i flash this rom i have on tv this message :
              no signal video
              help my??
                un & Bricked device - help needed (with pics)
                Hi Bob.
                I have tried to flash your rom into my CX-919 stick with NO hdmi output ( same like the guys asked here )
                the reson I have said unbricked and bricked is that Walter FW is working fine except for overheating the device!!! it is burning hot and stop playing after while ( pureX_KitKat_V1.1_cx921a - with the change of the kernel_KK_v4.2.5_TVSTICK_AP6210_HD.img )
                One post said I can flash your new rom ( ap6210_kitkat_finless20_beta2 ) - is it right?
                apperantly, my CX-919 is Ver2.3, and I have bought it based on your reply (back then ) that it has become your primary stick in the bedroom.
                Thanks !
                see my pics below
                (device bought from GEEKBUYING)
ID:	437282Click image for larger version
ID:	437283Click image for larger version
ID:	437284Click image for larger version
ID:	437285Click image for larger version
ID:	437286Click image for larger version
ID:	437287Click image for larger version
                  @ tobenary yes you can flash this
                  http://www.freaktab.com/showthread.p...or-CX-919-BETA
                  or this they are both good roms
                  http://www.freaktab.com/showthread.p...-4-4-2-*Update
                    Same answer for this one?
                    NOT ORiginal Tronsmart.
                    pic below
                    do I need to short something? or Fn key is enought ?
                      pic below
                      [ATTACH=CONFIG]10605[/ATTACH]
                      This is one of the very first cx-919 I have 2 of them they are the better one's & is not the T model. the fn button will be enough follow the instructions in the finless rom download oh & the otg port is the small usb next to the full sizes usb connect that to you pc wile holding the fn button then your pc will sound the bong ping what ever you call it anyway its all in the instructions good luck.
                      Blinkone
                        Blinkone
                        Meaning, This 1.6b is a good rom for it?
                        sorry for the Question, I don't want to brick my device.
                          No wifi
                          Hello.
                          i installed a lot of firmwares.
                          with some i get no image but one works great.
                          the only thing missing (and the most important one) is that wifi and bluetooth are not working.
                          i tried installing different kernels but with no luck.
                          i have cx-919.
                          pay attention that i have the model with the Fn button in the middle of the device and not the one with the Fn button next to the HDMI connector.
                          please help me!
                          thank you!
                            interesting, i must buy it
                              Originally posted by tomerinb View Post
                              Hello.
                              i have cx-919.
                              thank you!
                              read my post, I think it's same like yours
                                Hey there. I have the same stick. Could you tell me which kernels are you using to OC? I've tried d33's v3.1 but the stick gets unstable.
