UPDATED - CX919 - 4.2.2 - Finless ROM 1.6b
    Flashing was successful. Thanks for the great ROM!
    gesendet von meinem Samsung Knochen
      Originally posted by okey View Post
      Hope ive done it right, let me know
      link below
      https://www.mediafire.com/?acj793mju8t2p66
      could you please tell me what is this kernel in your package?
      "kernel_vsfsam_cpustock_gpu798h_ddr800.img"
        This ROM is back online. Sorry for the delay.
          Hi
          I have this running on my mk809III, it works fine, but i cannot get the enter button to work on my airmouse/keyboard, i have tryed 2 different ones and it is the same.
          No other rom will work on my stick other than this one
          Is there anything i could do to get the enter button working.
            After reboot my Bluetooth ipazzport is not working anymore. Any clues?
              Hi everyone,
              After flash my cx919 with this version, i can't use the 720 nor 1080 resolution because the screen start flashing. Any thoughts about this? I try to flash the stock firmware, but i have the same issue.
              Thanks in advance.
              PS: Sorry for my english, i'm spanish, you know.
                Re: UPDATED - CX919 - 4.2.2 - Finless ROM 1.6b
                Originally posted by litros View Post
                Hi everyone,
                Thanks in advance.
                See http://www.FreakTab.com/showthread.php?t=9421
                Sent from my GT-I9505 using Tapatalk
                  AW: UPDATED - CX919 - 4.2.2 - Finless ROM 1.6b
                  I did some investigations: after reboot my ipazzport is recognized and testing with F1 key and external keyboard helper leads to the conclusion that everything's fine but something prevent the correct pairing after reboot. Same with Neomode 1.9a. KitKat working fine but only 1.2 GHz (crappy T).
                    Meh I'm losing hope all the smooth roms I use just end up giving me a flickering screen!!!
                      try NEO mode 1.9a or 2.0 roms, they will work... anly CPU will be 1.2 - 1.43 (but that's for all "T" users)...
                      i found this: http://www.freaktab.com/showthread.p...d-other-things! i didn't tested yet works those kernels with "T" crap or not...
                        I did this and it woukdnt boot it just went to a boot loop
                        Sent from my iPhone 5 using Tapatalk
                          Looking for help
                          Hello, can some tell me if I have a chance at fixing my cx-919?
                          What I did was flashed the finless Rom before I rooted the device.
                          Now when it is plugged into tv it flashes RKM logo for 1 second, goes black, then Flashes android robot with CX-919 in the middle and then goes black and cycles back to RKM logo.
                          Thanks for any help
                            Thanks for any help
                            You don't root it to flash it just no point to that ,,finless rom is already rooted..what you do need to do befor you flash it is erase the IDB (nand)
                              Thanks. Then does someone know why I am just getting a Flashing RK logo, black screen, Android logo with cx-919 in middle and then back to black screen?
                              Thanks for any help
                                Thanks for any help
                                Hi there it may be a silly question but I have to ask it.Are you 100%sure you got a cx919
