UPDATED - CX919 - 4.2.2 - Finless ROM 1.6b
    Thanks! Much better performance now!
    Applied 4.2.2 to my CX-919 gen 1 and it's working better than ever!
    I even messed it up the first time, but I just re-flashed per the instructions and it was all good.
    As a yardstick I'm running an Amazon video using Firefox and Flash with zero problems.
    Very impressive!
    Thanks for making a good thing better!
      Cx-919 just arrived and flashed to finless 1.6b
      Love it, however I used it all day and added some media apps..spotify, xbmc and then I rebooted maybe for the 5th time today and its stuck on the flashing lights w the android logo, any ideas? Should I just reflash?
        CX-919 keeps rebooting
        I flashed my cx-919 today like the instructions. But my device keeps rebooting everytime after several minutes. What can i do about that?
          Don't overclock it and get a better power supply. My bet is the power supply is junk or your booting from a computer usb port that's under powered.
          Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
            I used the default settings and i use the power supply from my phone, that worked with the normal firmware.
              The power supply from your phone is probably .5 amp and isn't big enough. Try the power supply that came with the android stick or get a 2.1amp from Amazon.
              FYI the power supply from my iphone causes a reboot every couple of minutes.
                Hey guys I have problem with my cx919. I try and stream movies using es file explor and any player. It plays fine for 10-15mins then just stops. Any help appreciated
                  problem solved with new power supply, thanks guys
                    Those with post purchase USB chargers, who are not having these WIFI disconnect issues please provide your links for the charger you are using. I have similar issues with my CX-919 and MK908 v3 devices.Thank you
                      HEEEEELP !!!
                      I just got mine cx 919 and it does not work for me , i have an asus charger 2 A and the original charger does not change ......
                      flickering screen ..i have already tried finless rom 1.4-1.5-1.6 , Neomode rom nothing
                      please help me , i just bought this from geekbuying and they not answerd my email s .....
                        I had the same exact problem. Tronsmart cx-919 from geekbuying. Bought last week, died after 2 days! Had screen flickering after flashing 1.6b and neomode 1.3. Went back to stock rom problem still present when it wasnt to begin with, then after one more flash the stick has completely died. No power whatsoever. Not recognised by pc - nothing.
                        Wish I knew what causwd it and what the reason for thwle screen flickering is as didnt get any feedback on why that might be or where I went wrong.
                        My advice, go back to stock rom while you have a chance. Dont overclock and pray you didnt get a dud like ne.
                        Geekbuying are shit at responding. Have an open dispute with paypal, I will get my money back one way or another
                        Sent from my GT-I9505 using Tapatalk
                          Btw I had a 5v 2a samsung power supply that worked fine. Had no problems with reboots whatsoever for the couple hours I stayed on stock rom
                            thks
                            Thanks for your answer , i just filed a paypal claim for a refund , i hope i will get it.
                              Hey guys I was having all sorts of problems with my cx919. ...but since I installed kitkat 4.4 available from geekbuying.com everything works fine
                              Sent from my SM-N9005 using Tapatalk
                                I whant to try it out but i cant get it in to flash mode anymore after neomode 1,3 , i am stuck with this. Imposible to flash.
