Sent from my SM-N9005 using Tapatalk
UPDATED - CX919 - 4.2.2 - Finless ROM 1.6b
Originally posted by sanju_x20 View PostJust a quick question. .. my cx919 is plugged in in ac power however in the settings for battery it shows 50% and not charging. ..is it normal?
Sent from my SM-N9005 using TapatalkPlease consider making a Donation to freakTab
Couple of Questions
Hello All,
I just signed up on this board. I've been watching it for a month now after ordering my CX919 stick. I really appreciate all of the hard work that happens here. In fact, that is what convinced me to get the stick as I saw there is an active support community.
I have a couple of questions about Bob's 1.6b ROM
1. Is there a way to change the cursor?
2. Are there any known issues with CrossBreeder with this ROM? I did flash CrossBreeder (after flashing CWM Recovery) and it seems to work well. I get an Entropy of 4096. Just wondering if others had some experience with it.
Thank You all again.
Brad
Originally posted by PsyDonia View PostThanks I have now Flash my stick and used the 720p mod some guy uploaded.
even I have the 1GB ram version from DX.com it seems to work great so far.
I read somewhere in this thread how to remove the bar at bottom so I dont see the clock and the home button and stuff. I have a remote for it so I dont need that bar at the bottom.
also the google search bar on the homescreen is that posible to remove also.
I want my homescreen clean with only apps i use.
Strange
Originally posted by britoso View PostBob, It looks like the "Internal Memory Error, Format SD Card OK?" bug still exists in 1.6b
I just got this. I leave my stick always on.
rebooting fixed the issue, for now.
AW: UPDATED - CX919 - 4.2.2 - Finless ROM 1.6b
Brad
1. It is quite easy to change the mouse pointer, just install 7zip on your pc and change the mousepointer in the file ;system/framework/famework-res.apk
In the folder /res/drawable-mdpi/pointer-arrow.png
i am not totally sure about the filename thou, but the path is correct...
2. Forget about cross breader, it only causes more snappyness on the devices because generating entropy causes higher cpu load and the cpu is on higher frequency step while ideling
_________________________
tapatalked from GalaxyS3
Originally posted by maddealhunter View PostIs there a reason why my WiFi signal is only 18mbps max even with the AP right next to the cx919?Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
Originally posted by losl View PostMy CX919 is not rooted and i flashed it to the stock 4.2.2 rom. Should i root my device prior to flash "4.2.2 - Finless rom 1.6B" ?
Thank you !
loslTronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
There are currently 2187 users online. 1 members and 2186 guests.
