UPDATED - CX919 - 4.2.2 - Finless ROM 1.6b
Originally posted by Echo7 View Post
Originally posted by smithmal View PostThat's weird. I thought the flash tool wouldn't recognize your stick at all unless it was in flash mode. Have you tried uninstalling the unknown USB device in device manager, reboot and see if the PC requests a driver? From my recollection, getting Windows to "forget" a bad driver is not easy although it is possible with some work. Has your PC ever recognized your stick in the past? My suggestion would be to try and find a Windows 7 box and try connecting your stick to that.
smithmal
PS I do NOT know if this works with Windows 8 as I've only used it with Win 7 x64 and x86Attached Files
i cant get my computer to see the tv player.
i have it off hold the button on the side.
the put the USB cable from computer to usb DC port so it boot it boot into recovery mode.
should I change and have the usb cable from computer into the other USB port.
and how.
should I have it of.
hold the button insert DC power cable then usb to computer and let it boot into recovery mode.
is that right or how to.
Originally posted by Finless View PostI am game but fill me in.... What are they?
Maybe we work on a ROM together if you like?
Thanks for the offer, but I do not know much about Android internals and ROM buildingI simply fixed annoying things, that's all.
My mod is described on the page 12, message #227 and can be downloaded from there. Basically, I've replaced misaligned cursor, changed boot image/animation to a less annoying and swapped sdcard/external_sd mount points.
Originally posted by PsyDonia View Posti cant get my computer to see the tv player.
and how.
1. Start up the Flashing tool (it should say no device recognized)
2. Unplug everything from your Android stick except the microUSB cable (which came with the stick (VERY IMPORTANT that you use this cable)) which should be plugged into your OTG slot (side slot).
3. Hold down your flash button on your Android stick
4. While holding down your flash button, plug the other end of your USB cable into your PC (use USB 2.0 slot and don't use a USB hub). It's preferable to use a USB slot in the back as that hooks straight into your motherboard.
5. Once you've plugged your cable into your PC let go of the stick's flash button
6. You should here the familiar "bong" from your PC which indicates that it has recognized that a USB peripheral has been connected to your PC. If you don't then re-try. You must make sure that you are holding the flash button while connecting the cable to the PC.
7. At this point your computer should have recognized your stick (if you've already installed the proper drivers) and the flash tool has also indicated that your stick is recognized. If you haven't installed your drivers, then you will be asked to do this at this point. Use the drivers that are included in the ROM pack that Finless provides.
8. Flash your stick with the ROM as indicated in the instructions located within the ROM pack.
Hope that helps.
smithmal
Originally posted by smithmal View PostYou need to use the side microUSB slot (which should be the OTG port). The DC port if for power only and is not used or necessary when flashing as the stick get's its power from your PC.Please consider making a Donation to freakTab
Thanks I have now Flash my stick and used the 720p mod some guy uploaded.
even I have the 1GB ram version from DX.com it seems to work great so far.
I read somewhere in this thread how to remove the bar at bottom so I dont see the clock and the home button and stuff. I have a remote for it so I dont need that bar at the bottom.
also the google search bar on the homescreen is that posible to remove also.
I want my homescreen clean with only apps i use.
Edit:
It was the USB cable!! wtf!!!
The same cable worked for all my phones, but not for this CX-919.
Changed to my galaxy nexus cable and it worked the first time.
Note: The blue LED stays lit even though it is in flash mode for my CX-919
Here are the settings I used:
Works great so far. Thanks Bob.Last edited by britoso; 29 December 2013, 23:29.
1080p
Hello,
Today I flash my cx919 with this software.
I used the 1080P and I try to connect to my nas to watch some movies.
Conclusion
DVD are okay with wifi stream
720P are okay with wifi stream
1080P not okay with wifi steam, It needs more buffer..
Is there a way to create more buffer for 1080P streams?
Or is there a way to watch 1080P steam over the wifi with cx919?
XBMC is also working on this one, but 1080P not
Hi all... new to the blog. I just updated my cx919 with cx-919-rk3188-T-4.2-6210-20130 and since then it is not working properly. The screen keeps flickering and internet doesn't work properly. Can someone please tell me how to undo the rooting process and take the stick back to factory settings.
Sent from my SM-N9005 using Tapatalk
Originally posted by britoso View PostCan you try playing the file from the SDCard? If that works then maybe you can get a LAN adapter and try that.
1080p did not work well for me with the stock ROM, yet to try this.
I can play from a local HD 1080P no problem.
It is not working on WIFI :-(
I have A usb LAN adapater, but I don't have a driver for this kernal 3.0.36+ only 3.0.8+ and I don't know how rebuild the driver to 3.0.36+ there are more users with the same lan adapter waiting that some have a driver for android.
Originally posted by sanju_x20 View PostHi all... new to the blog. I just updated my cx919 with cx-919-rk3188-T-4.2-6210-20130 and since then it is not working properly. The screen keeps flickering and internet doesn't work properly. Can someone please tell me how to undo the rooting process and take the stick back to factory settings.
On the first page you can find the software, this works verry good.
Unzip it, and flash it in your HDMI stick.
I had the same problem with latest stock software, but with this software is it okay, also XBMC.
I make my stick 1080P software, but in the readme file stand how you can do it, standaard when you flash it will be 720P but on the WIFI you cannot play 1080P movie, it is just a bit to slow it needs more buffer.
Regards,
Michel
Re: UPDATED - CX919 - 4.2.2 - Finless ROM 1.6b
Regards,
Michel
It is about bit rate... If the bit rate is to high you won't be able to steam 480p movies.
So saying that 1080p doesn't work is wrong. It works great for me. However, the quality, due to the low bit rate, is not that great.
Signature? Signature!
There are currently 2155 users online. 1 members and 2154 guests.
