UPDATED - CX919 - 4.2.2 - Finless ROM 1.6b
Originally posted by baccilus View PostPlease consider making a Donation to freakTab
Originally posted by blinkone View PostTry this rom & yes the instructions are in the download http://www.freaktab.com/showthread.p...nless-ROM-1-6b
Originally posted by peety View PostAnyone have a link/copy of the 1.6 rom? Not 1.6b... unless im getting confused and it went from 1.5 to 1.6b. Been awhile since I have had to reflash with tool. Been using cwm. Thanks.Please consider making a Donation to freakTab
No HDMI output
Originally posted by JakeNewman View PostIs this ROM supposed to work with CX919 V2.0? I get no HDMI output when I've tried this. The Finless ROM 2.0 - KitKat 4.4.2 for CX-919 - BETA does work, but HD video is choppy and wifi sucks.
Cheers,
Jake
I am experiencing the same thing as above. Can use the the Kitkat version and the stock ROM from Gekkbuying site but every time I try install Finless 1.6b everything completes fine with no errors but when I plug in there is no output at all. Need some help pls.
Originally posted by blinkone View PostTry this kernel with finless 1.6b rom bet it works
http://www.mediafire.com/download/98...m_cpu1704h.zip
Blinkone...there are 8 kernels within the above zip file, which one should I use and what are the differences? I was having the same issue with the finless 1.6b and it worked using the kernel_vsfsam_cpu1704h_gpu798h_ddr720. Also what is the reason we need to change the kernel?
Thanks in advance.
I am having same issues with these kernels whereby my WIFI will not stay on. Need help ASAP pls.Last edited by u4icpsychopath; 04 October 2014, 21:49.
Originally posted by sonnytrouble View PostI just got my cx 919 the other day and tried to put finless rom 1.6b on it. I followed the instruction in readme file and now my stick does not show anything on the tv? any help would be much appreciated. im a complete noob at this!
could you post a photo of the pcb bored as there are many clones aboutPlease consider making a Donation to freakTab
Originally posted by sonnytrouble View Postthis is my cx 919
Edit
Look hear
You could also
Try this rom its from a Chinese webpage so it may be a slow download
Originally posted by sonnytrouble View Postthanks for quick reply. I changed to 1080p kernel and now have picture but no wifi is this because I have a clone?Please consider making a Donation to freakTab
There are currently 6055 users online. 3 members and 6052 guests.
