Thanks again!
[ROM] "GENERIC" SC v2.0 USER/USERDEBUG - S905x2 / S905x3 - AndroidTV 9
Ye i was expecting it, thks!
it's unfortuante, but now I may be buying a X96 Air, is your rom compatible with it? I know there are various revisions, but just wanted to check before I pull the trigger.
However, better yet, what box would you recommend for your firmware?
thanks a lot for your time!
Originally posted by Cafpy90 View Post
X96 Air
I have the P3 rev. - on XDA there is even a hybrid rom AOSP/ATV and you can switch between within the system...
Originally posted by soldiaz View Post
In my experience one of the best boxes out there! The 4GB 32 unit has really good stock, fluid and fast!
I have mine now, and it was a difficult box to flash, i tjink i have some new variant or w/e. Slimboxs roms didn't work, some roms bricked it, and had to short pins to get it back, and finally got a daviet rom to work.
Unfortunately, i was hoping SC's rom was going to flash, but it did not. Ram mismatch error.
But at any rate, it's working now, after a lot od trouble, and really is an incredible box. Super fast, and amazing wifi.
SC - make a rom lol.
for best wifi I recommend minixfreak 's roms....by far best wifi performance!!!
You can check your revision in settings. Slimbox releases for any revision
Originally posted by soldiaz View Postfor best wifi I recommend minixfreak 's roms....by far best wifi performance!!!
So here's what happened:
P4, P3 and P1 from slim - brick.
V2 and P2 - hung on loading screen, no brick. But, no boot.
Daviet - V2 rom - works perf.
Another developer, on 4PDA his v2 worked, but didn't work very well, so switched to daviet.
When using aida to check the firmware build, as it's built off of stock anyway, on daviets, it says P2.
So i am totally confused as to what my box is. I have the 4/32, with 100M lan.
Speaking of minixfreak, i didn't see he made a rom for the air? It's all beelink studf? Unless i missed something?
Anyway, what's your thoughts on this. I do have pics of the board abd all tgat, if you'd like to see.
Let me know. Thanks.
Originally posted by Cafpy90 View PostSC - make a rom lol.
So it gets to a point where you lose the "mood" to do any work, also another big thing is i stop getting new devices to work on... ye i simple do not get any devices anymore from anyone, other that my regular work but that i cant share public.
its sad but is the truth
Well i cant, if you guys notice i stop rls roms for a while now, just got a bit tired of it also my job every single day(not weekends lol) is working on that type of devices.
Anyway, thanks for it all!
I did that. It said i had V2.
I own the P3 guess with Gigabit, 1000mbit. Dont know v2
Hello All,
My TV Box: Tanix TX3 4GB,32GB Amlogic S905X3 2.4G/5GHz Dual Wifi BT 4.2 QZ
High-Resolution PCB Picture: https://ibb.co/zbqW5HH
Details from PCB: CS_905X3_TX95_B4_QZ_V1.2 (So this a QZ version of the Board)
WIFI Chip:
SP6330
ZX190906
I have tried to install this ROM (checksum matches) with UBT and it failed. I have tried 2 times.
SC v2.0 S905x2/S905x3 ATV USERDEBUG BUILD IMG
MD5: 2052BBBFC8EFDC2A98D30FA287D39D0E
Any help appreciated.
Regards
Hannah
There are currently 3021 users online. 1 members and 3020 guests.
