[ROM] "GENERIC" SC v2.0 USER/USERDEBUG - S905x2 / S905x3 - AndroidTV 9
Deleted as I bought a different box and want to avoid confusion in other threads..Last edited by sevsman; 27 August 2020, 06:35. Reason: Deleted as I bought a different box and want to avoid confusion in other threads..
Just tried installing the debug version on an A95x f3 air. Failed on 1% download DDR error using burning tool 2.2. Tied using SD card with burn maker. No joy - starts then drops out. . Hasnt erased anything - boots up with the currently installed stock. Just cant seem to install this firmware - any ideas? probably the DDR3 I suspect
Originally posted by sesdave View PostJust tried installing the debug version on an A95x f3 air. Failed on 1% download DDR error using burning tool 2.2. Tied using SD card with burn maker. No joy - starts then drops out. . Hasnt erased anything - boots up with the currently installed stock. Just cant seem to install this firmware - any ideas? probably the DDR3 I suspect
Ah pity - oh well i will try on the x96 max plus when it turn up but as that has DDR3 I suspect that probably wont installl either.
Update - no joy on x96 Max Plus- failed 0x10303004/Romcode/Switchstatus/Identify/Error Result - that was using burning tool 2.2
Lucky for me it still boots stock rom after this attempt . So no custom firmware for me to play with yet. I did read that this error can be circumvented by changing temp settings to 20/80 or 0/90. Might try that later - may as well see how stock run first.,
Update - tried changing temperature setting in burning tool. Same error at 3% downloading uboot. So looks like this box is also not compatible with the firmware.Last edited by sesdave; 06 August 2020, 04:24.
@superceleron Hello. Do you have access to the original quality version under X96 MAX + with Amlogic S905x3 Cortex-A55 4GB / 64GB firmawre that you can work for ANDRIOID TV because we have a mobile, it shows the quality of the original ANDROID TV, are there any options, how much does it cost with paypal send me email link
There are currently 2335 users online. 1 members and 2334 guests.
