[ROM] "GENERIC" SC v2.0 USER/USERDEBUG - S905x2 / S905x3 - AndroidTV 9
Originally posted by rajatnagpal View PostPut password.bin file in usb burning tool
without it software will not flash
connect to them from whom u bought your box. i purchased from AliExpress they send me firmware and key file
this link i got and flashed stock firmware first then try other
Originally posted by rajatnagpal View Postconnect to them from whom u bought your box. i purchased from AliExpress they send me firmware and key file
https://dropmefiles.com/euBsK
Flashed on Bqeel Y8 Max (u214 board I think, maybe u219) Everything seems good so far, except during set up wifi did not work. Plugged in ethernet and finished set up, will test wifi and other features and report back shortly.
Edit: Wifi does NOT work on Bqeel Y8 Max 4gb/64gb (u214 board (confirmed))
Bluetooth DOES work!
Ethernet is fast and strong and consistent!
Navigation is smooth.
Unfortunately without wifi I won't be able to continue using this rom
The hunt continues.
Hi. All
which of these versions is correct for my box
x96 max + 4gb ram 64gb rom
I installed the supersu and the box no longer starts properly suspended on the boot logo, admittedly it had root (I think) but it did not allow editing build.prop and hosts file
thanks.
edit:..
and which options to select / deselect / leave
There are currently 3673 users online. 1 members and 3672 guests.
