[ROM] "GENERIC" SC v2.0 USER/USERDEBUG - S905x2 / S905x3 - AndroidTV 9
you need to be very fast, keep pressing enter in putty screen!
Originally posted by blust0ne View Post
check the boot stage with putty log file or attach your log file for reference.
BL1 BL2 BL3-1 --> BL3-3 ( you can get a uart console access here, in 2-3 second after power on)
do I need to connect the 3.3v? I only connected ground,Tx and RX
to napalmd
you have to try override the eMMC , then you can boot microsd that is prepared by burn card maker.
If your box is really bricked then if you connect via serial console to it you will only see the following looping: GXM:BL1:dc8b51:76f1a5;FEAT:ADFC318C:0;POC:3;RCY:
maybe try to use the aluminium foil like amazon fire stick 4K rooting process,
I already tried with the micro sd card prepared with burn card maker but it does not work.
Also my board is different I don't have those pins, and how should I use the pins? short them on boot?
thanks again for all the help.
You may only view thumbnails in this gallery. This gallery has 2 photos.2 Photos
try the jumper first and then other point near the eMMC.
I found the location between s905x and eMMC.
You need the plug with power on switch.
first , short the point with pinset.
power-on and then quickly release the short point ( a few milisecond is enough )
check putty log shows :
G12A:BL:0253b8:61aa2d;FEAT:E0F83180:2000;POC:F;RCY :0;EMMC:0;READ:0;CHK:1F;READ:0;CHK:1F;READ:0;CHK:1 F;SD?:0;SD:0;READ:0;0.0
bl2_stage_init 0x01
bl2_stage_init 0x81
hw id: 0x0001 - pwm id 0x00
bl2_stage_init 0xc0
bl2_stage_init 0x02
no sdio debug board detected
==> and then the cpu loads the bootloader from microsd or usb, not eMMC(has bad bootloader).You may only view thumbnails in this gallery. This gallery has 2 photos.2 Photos
Originally posted by evlo View Post
x96 max plus s905x3
I read this thread and understand it should work, but can someone please verify it? I think this box is quite popular, so there is a chance someone alrady tried it
Originally posted by blust0ne View Posttry the jumper first and then other point near the eMMC.
bl2_stage_init 0x01
bl2_stage_init 0x81
bl2_stage_init 0xc0
bl2_stage_init 0x02
the chip is labelled KLMBG2JENB-B041, I found the datasheet but the pins are on the bottom, and there are no way to see what are those on the side of the chip... https://datasheetspdf.com/parts/KLMB...pdf?id=1267094
Originally posted by napalmd View Post
putty log is the same with or without shorting pins, so I can't boot from sdcard...
The board has dual design layout , BGA and TSOP. the pattern line may be shared.
check tsop48 pin map , http://www.onfi.org/-/media/client/o...gold.pdf?la=en
After reading both datasheets, and you my low knowledge on the subject, I figured that DAT0 must be the pin 29 IO0 or DQ0, so I shorted it on boot and then it booted from the sd card and flashed the correct rom.
So here is if anyone else needs it.
i tried with T95Q and i find it a bit slow, unlike your previous build. i reverted back to your previous build.
my oem remote with mic still not working with voice control in this build.
i tried to merge some remote.tab found in vendor using other GT1 roms that worked well with my remote, but only the voice having issue in this rom.
is there other file or config that i can change in your build to make my voice remote work?
Originally posted by raptur3d View Posti tried with T95Q and i find it a bit slow, unlike your previous build. i reverted back to your previous build.
Originally posted by horstepipe View PostHello
just tried to flash a X96 Max Plus, but USB Burning Tool (v2.2.0) stopped at 3% with
[0x10303004]Romcode/Switch status/Identify/Error result
I'm quite new at troubleshooting these boxes, can I provide anything to get this fixed?
Best regards
Is one of the two!
There are currently 3099 users online. 1 members and 3098 guests.
