Have anyone tried it already ? . Is there a way to backup the current rom if something goes wrong ?
[ROM] "GENERIC" SC v2.0 USER/USERDEBUG - S905x2 / S905x3 - AndroidTV 9
Originally posted by yakaaithiri View PostFolks, will this rom work with A95X F3 Slim ? . Its a Amlogic S905X3 device.
Originally posted by majkool View Post
Try it but only DEBUG version because you will be able to open terminal and reboot to recovery to flash stock rom.
Is there a way to flash ATV via TWRP ? any zip or backup file please share.
superceleron I did restore a backup of the data partition after updating. Only thing I had to do was restore a backup of kodi which was no problem. I did notice that auto frame switch wasn't working right though. In the AFRD app under status for display refresh rate is modified to match movie it says no and I can't enable it with my mouse pad .
Originally posted by al4life View Postsuperceleron I did restore a backup of the data partition after updating. Only thing I had to do was restore a backup of kodi which was no problem. I did notice that auto frame switch wasn't working right though. In the AFRD app under status for display refresh rate is modified to match movie it says no and I can't enable it with my mouse pad .
The Frame Rate doesn't change until a movie is playing and you will see a small "Toast Toggle" pop-up notification (at bottom of the screen) showing what the video frame rate was changed too according to the video metadata.
There are currently 4379 users online. 2 members and 4377 guests.
