[ROM] "GENERIC" SC v2.0 USER/USERDEBUG - S905x2 / S905x3 - AndroidTV 9
Originally posted by 5p0ng3b0b View Post
You are the greatest! Thanks alot for pointing this out and apologies for all this being a bit off topic. I wrote a bash script to split the boot image and extract the dtb after examining a few methods written in C, python & perl available on github. None of the scripts/code I encountered accounted for multiple device trees and I was only extracting the first one found. I modified my script to extract the correct DTB and hey presto! Script was written to avoid commands dependent on busybox.
Yes you do of course!
Code:SM1:BL:511f6b:81ca2f;FEAT:A0F83180:20282000;POC:F;RCY:0;EMMC:0;READ:0;0.0;CHK:0; bl2_stage_init 0x01 bl2_stage_init 0x81 hw id:
superceleron I was able to find out why serial console was not working. It was because of defective USB TTL converter. I bought another one, and now I can see the uboot/kernel logs. I've pasted it at:
I am not sure what is the issue, but I keep seeing lot of "binder" transaction errors. The CPU also starts getting very hot. Nothing happens on screen other than Android boot animation.
I have done some more debugging. I compared the serial output with that of stock rom. There are many differences, but I think main issue starts when it tries to enabled wifi. On working stock rom:
Code:aml_wifi wifi: [usb_power_control] Set WiFi power on ! aml_wifi wifi: [pci_reinit] pci wifi reinit! aml_wifi wifi: [wifi_power_ioctl] Set sdio wifi power up! aml_wifi wifi: [wifi_power_ioctl] wifi interface dev type: sdio, length = 4 dhd_module_init: in Dongle Host Driver, version 100.10.315.3 (r771911) ======== dhd_wlan_init_plat_data ======== dhd_wlan_init_gpio: WL_HOST_WAKE=-1, oob_irq=84, oob_irq_flags=0x418 dhd_wlan_init_gpio: WL_REG_ON=-1 dhd_wifi_platform_load: Enter Power-up adapter 'DHD generic adapter' wifi_platform_set_power = 1 ======== PULL WL_REG_ON(-1) HIGH! ======== aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 482 aml_wifi wifi: [extern_wifi_set_enable] WIFI Enable! 482 BT_RADIO going: on AML_BT: going ON wifi_platform_bus_enumerate device present 1
Code:aml_wifi wifi: [usb_power_control] Set WiFi power on ! aml_wifi wifi: [pci_reinit] pci wifi reinit! aml_wifi wifi: [wifi_power_ioctl] Set sdio wifi power up! aml_wifi wifi: [wifi_power_ioctl] wifi interface dev type: sdio, length = 4 binder_alloc: 3481: binder_alloc_buf, no vma binder: 3336:3413 transaction failed 29189/-3, size 24-8 line 3258 binder: send failed reply for transaction 10516 to 3481:3623 binder_alloc: 3481: binder_alloc_buf, no vma binder: 3335:3394 transaction failed 29189/-3, size 100-0 line 3258 binder_alloc: 3481: binder_alloc_buf, no vma binder: 3335:3394 transaction failed 29189/-3, size 100-0 line 3258 binder: send failed reply for transaction 14259 to 3626:3626 binder: send failed reply for transaction 14268 to 3626:3828 binder: undelivered TRANSACTION_COMPLETE binder: undelivered TRANSACTION_ERROR: 29189
[ 23.046960@2] init: couldn't write 4035 to /dev/cpuset/camera-daemon/tasks: No such file or directory
there is something wrong in the build you doing, if you ever get the error above there is issues in the apk's of the mix you doing!
There is not much i can help when that error happens, it can be a lot of things.
Originally posted by superceleron View Post[ 23.046960@2] init: couldn't write 4035 to /dev/cpuset/camera-daemon/tasks: No such file or directory
Did some more debugging. If I do "logcat" on serial console, I can see following in the log:
Code:--------- beginning of crash 01-01 00:00:27.136 3574 3574 E AndroidRuntime: *** FATAL EXCEPTION IN SYSTEM PROCESS: main 01-01 00:00:27.136 3574 3574 E AndroidRuntime: java.lang.RuntimeException: Error receiving broadcast Intent { act=android.intent.action.USER_STARTED flg=0x50000010 (has extras) } in com.android.server.ConnectivityService$7@2fe0dfa 01-01 00:00:27.136 3574 3574 E AndroidRuntime: at android.app.LoadedApk$ReceiverDispatcher$Args.lambda$getRunnable$0(LoadedApk.java:1401) 01-01 00:00:27.136 3574 3574 E AndroidRuntime: at android.app.-$$Lambda$LoadedApk$ReceiverDispatcher$Args$_BumDX2UKsnxLVrE6UJsJZkotuA.run(Unknown Source:2) 01-01 00:00:27.136 3574 3574 E AndroidRuntime: at android.os.Handler.handleCallback(Handler.java:873) 01-01 00:00:27.136 3574 3574 E AndroidRuntime: at android.os.Handler.dispatchMessage(Handler.java:99) 01-01 00:00:27.136 3574 3574 E AndroidRuntime: at android.os.Looper.loop(Looper.java:193) 01-01 00:00:27.136 3574 3574 E AndroidRuntime: at com.android.server.SystemServer.run(SystemServer.java:454) 01-01 00:00:27.136 3574 3574 E AndroidRuntime: at com.android.server.SystemServer.main(SystemServer.java:294) 01-01 00:00:27.136 3574 3574 E AndroidRuntime: at java.lang.reflect.Method.invoke(Native Method) 01-01 00:00:27.136 3574 3574 E AndroidRuntime: at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:493) 01-01 00:00:27.136 3574 3574 E AndroidRuntime: at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:838) 01-01 00:00:27.136 3574 3574 E AndroidRuntime: Caused by: java.lang.NullPointerException: Attempt to invoke interface method 'int android.security.IKeystoreService.exist(java.lang.String, int)' on a null object reference 01-01 00:00:27.136 3574 3574 E AndroidRuntime: at android.security.KeyStore.contains(KeyStore.java:241) 01-01 00:00:27.136 3574 3574 E AndroidRuntime: at android.security.KeyStore.contains(KeyStore.java:249) 01-01 00:00:27.136 3574 3574 E AndroidRuntime: at com.android.server.net.LockdownVpnTracker.isEnabled(LockdownVpnTracker.java:92) 01-01 00:00:27.136 3574 3574 E AndroidRuntime: at com.android.server.ConnectivityService.onUserStart(ConnectivityService.java:4120) 01-01 00:00:27.136 3574 3574 E AndroidRuntime: at com.android.server.ConnectivityService.access$4800(ConnectivityService.java:198) 01-01 00:00:27.136 3574 3574 E AndroidRuntime: at com.android.server.ConnectivityService$7.onReceive(ConnectivityService.java:4177) 01-01 00:00:27.136 3574 3574 E AndroidRuntime: at android.app.LoadedApk$ReceiverDispatcher$Args.lambda$getRunnable$0(LoadedApk.java:1391) 01-01 00:00:27.136 3574 3574 E AndroidRuntime: ... 9 more
superceleron I have a breakthrough. Seeing that "vendor" partition had lot of differences, I took only "system" partition from your ROM, and it works beautifully! I also did vendor partition cleanup by comparing what was there in your ROM. Thanks for all the work. This ROM is now far better than the stock - which was crap.
So, T95Max+ users, if anyone wants SC2 ROM, do let me know. I'll upload it somewhere.
EDIT: typo
I have upload SC2 rom (userdebug version) for T95 Max+ here:
superceleron sorry for nagging so much, but one last question - I put a simple "android tv" splash as "bootup" logo, and after flashing it, it is shown correctly - but only during first boot. After that if I reboot, it shows me messed up superceleron logo, even though I have not even taken the logo partition from your ROM. I took only the "system" and "recovery" partitions. I am not able to debug how this bootup logo is getting overwritten and where. Any suggestion?
Originally posted by drsam007 View Post
But I thought s905x3 supported L1. Is it possible that some boxes with same SoC don't support it?
Originally posted by drsam007 View Postsuperceleron sorry for nagging so much, but one last question - I put a simple "android tv" splash as "bootup" logo, and after flashing it, it is shown correctly - but only during first boot. After that if I reboot, it shows me messed up superceleron logo, even though I have not even taken the logo partition from your ROM. I took only the "system" and "recovery" partitions. I am not able to debug how this bootup logo is getting overwritten and where. Any suggestion?
There are currently 2156 users online. 0 members and 2156 guests.
