I just tried it, unfortunately it cannot flash successfully, the usb burning tool report this error: [0x10303004]Romcode/????/????/????????
[ROM] "GENERIC" SC v2.0 USER/USERDEBUG - S905x2 / S905x3 - AndroidTV 9
superceleron I have T95 Max+ S905X3 device. Most probably the DTB included in your img might not work with it. Would it work if I replace "_aml_dtb.PARTITION" file in level1 of your img with the one that I have in my stock ROM? Do I need to update/replace any other file?
superceleron or another question - what if I replace just system.PARTITION in my stock rom with what is there in your ROM?
Originally posted by pexcn View Post
Hi SC, if I can provide the dtb files of this device, so will this device be supported in the next release?
Originally posted by drsam007 View Postsuperceleron I have T95 Max+ S905X3 device. Most probably the DTB included in your img might not work with it. Would it work if I replace "_aml_dtb.PARTITION" file in level1 of your img with the one that I have in my stock ROM? Do I need to update/replace any other file?
Originally posted by drsam007 View Postsuperceleron or another question - what if I replace just system.PARTITION in my stock rom with what is there in your ROM?
hoo i see, the issue in your box from my build is the emmc is not compatible with my DT...
Anyway just as soon as you turn on the box just keep pressing enter key in serial terminal until you get a shell, something like "g12a_u212_v1:>"
When that happen, just type "update" and press enter ( without the "" ) and connect the usb cable and voila you can flash the box!
Originally posted by JuBaX View PostNot working on Magicsee N5 PLUS S905x3. Rom error while flashing.
I attach DTB and DTS for this box if it helps in anyway.
Also does this rom support mounting loop devices?
There are currently 1059 users online. 0 members and 1059 guests.
