[ROM] "GENERIC" SC v2.0 USER/USERDEBUG - S905x2 / S905x3 - AndroidTV 9
Has anyone tried this on Beelink G1 minni2 (s905X3)? I really don't understand how this rom can work on both -S905x2-S905x3 boxes. I don't need to unstand, .just not wanting to waste the time. It does work great on one of my G1-mini (s905X2) boxes Thanks for any replies.Last edited by kenduvernay; 19 February 2020, 06:25.
Originally posted by kenduvernay View PostHas anyone tried this on Beelink G1 minni2 (s905X3)? I really don't understand how this rom can work on both -S905x2-S905x3 boxes. I don't need to unstand, .just not wanting to waste the time. It does work great on one of my G1-mini (s905X2) boxes Thanks for any replies.
And the s905x2 and x3 are basically the same cpu, the difference is the x3 as a NPU and x2 does not.. so all i have to do is code the uboot the distinguish between the 2 and make it load the proper DT.Last edited by superceleron; 19 February 2020, 10:09.
Yes it does work just fine in mini2.... actually it was tested in a mini2 :P
And the s905x2 and x3 are basically the same cpu, the difference is the x3 as a NPU and x2 does not.. so all i have to do is code the uboot the distinguish between the 2 and made it load the proper DT.
Thank you SC. I've installed on the Mini2 and it boots fine. I'm trying to change the Launcher But the "Droid Settings" doesn't take me to where I can set default apps. What am I missing?
This is the Android TV build you cant change the launcher of it, for that you need to flash the "Normal" build.
Found it. The correct rom for me is. "905x2-S905x3-DEBUG-Normal-v1.0-20200103.img"Last edited by kenduvernay; 19 February 2020, 11:10.
Originally posted by jer1956 View PostIm my opinion the only use for Android is to play Youtube, with AFDR. That requires root. Mediaplyer functions are best served with Coreelec/librelec. HD streaming services such as Netflix and Prime are never going to happen.
I use it even for media player, for me coreelec/etc.. are to limited! but is true HD flix and Prime will never happen in this boxes.
For HD/4k flix and Prime i have my work box and also a mibox or even my 4k tv.
But i still use this boxes for some gaming (well more the s922 ones for that), and mediaplayer like i said.
well i use android for a ton of other stuff that just YT...
Well we all have our choices and tastes
Those coming from HTPC must think thats normal. Its taken me 5 years to find ARM boxes which did what those with Sigma and Realtek designs did in 2015.
So SD audio and frame rate mismatch stuttering is by choice?
Also you can use debug version of this build and use AFRD and your rate mismatch is fixed, anyway like i said choices(or lack of choices) and tastes.
Would be great to see in main post on what devices it works and if what we lost e.g front lcd etc.
Works on:
gt1 mini 1,2, s95, x96 max, tx5 max
Thanks superceleron for your work!
There are currently 2380 users online. 0 members and 2380 guests.
