[ROM] "GENERIC" SC v2.0 USER/USERDEBUG - S905x2 / S905x3 - AndroidTV 9
Originally posted by sssolider2 View PostI sometimes get a black screen when I try to exit certain apps. What gives? Everything works fine.
Originally posted by sagert View Post
Hmm weird, anyone else as the same issue?
Originally posted by superceleron View Postkodi... ye kodi does that, i use a force close addon to kill kodi.
Originally posted by poffpoff View Post
Yes, i think its something about the latest Google Play Services, i have to unplug the usb receiver of my remote control and replug to the interface to appear again.
what i am doing now is that i am using the force kodi close addon - https://github.com/Based-Skid/plugin.close.kodi - it seems to do the trick but i need to test it further.
Originally posted by Agronur View PostI have two problems on user version.
1. main screen resolution is a bit low. icons are big. can we change main screen resolution to see more channels?
2. i dont have external storage write access. i cant write or delete a file.
optional problem: cant install dolphin emulator.
2º user build is more restrictive, but i do think i added support to write external storage.. it should pop up a small window asking you for permission, not sure now i do not touch in android 9 in 1 month +/- lol.
This is great work superceleron thanks for all your help with custom roms
I'm going to be receiving a T95 MAX+ which contains Amlogic S905X3, ARM G31 MP2 (Mali-T720MP2), 4GB DDR3 and 32GB Flash.
Can you confirm this works for this setup? if not can you make it work? I will try it of course soon as it arrives but would like a heads up if someone has tried it already (save me half hour or so putting it all back via UART)
Thanks in advance, might try cooking something myself eventually if i can get a custom rom to start with.
Apologies, should have searched first (although its deep within the tutorials section) (NOT TRIED YET BUT PROMISING)
Originally posted by drsam007 View PostI have ported SC2 ROM (userdebug version based on ATV) to T95 Max+. You can download it from:
https://mega.nz/#!zJVRVIpb!sed1AAXR4...cN5_A4tyHG9OlA
I have flashed it to my box using AMLogic USB Burning Tool 2.1.9, and I don't see any issues, but I am not responsible if it bricks your device.
There are currently 2536 users online. 1 members and 2535 guests.
