[ROM] "GENERIC" SC v2.0 USER/USERDEBUG - S905x2 / S905x3 - AndroidTV 9
Originally posted by Narcsoul View Post
Is this rom compatible with any android box with s905x3? Or did I misunderstood?
I made it to be as "universal" as possible, but all depends how far away your box maker gone from the amlogic reference design.
You misunderstood, that is why i have "Generic" notice the "", it may or may not work on your box.
well about the loop can't tell since i didn't try it..
The DDR4 is not in the DTB is in the uboot, the only way for you to know is grabbing a serial output as soon as you connect the box!
Also that dtb is from the 1gb ram.
Code:cat /proc/device-tree/amlogic-dt-id
Code:sm1_ac213_4g
Many Thanx. Is there any official rom for tanix tx3 somewhere in case I brick it up? Can you a provide a link?
Originally posted by 5p0ng3b0b View Post
Yeah it says g12a_u212_1g in in the DTB but my box is defo 4g/64g and uses it. DTB probably been tweaked from an older gen box.
Code:sm1_ac213_4g
There is no tanix tx3 in there. Why..?
Hi, Glad to share the updated firmware for TANIX TX3 Amlogic S905x3 8K Video Decode Android 9.0 TV Box Bluetooth 2.4G+5.8G WiFi (https://www.geekbuying.com/item/TANIX-TX3-Amlogic-S905x3-8K-Video-Decode-Android-9-0-TV-Box-4GB-64GB-421642.html?utm_source=freaktab.com&utm_medium=referral&utm_campaign=elaine&utm_term=TA
Originally posted by drsam007 View Post
Do I need usb-ttl cable for the same?
superceleron could you please tell me if I need usb-ttl cable to check serial console during boot?
Originally posted by majkool View PostX96 MAX+ 2/16GB s905x3
I'll lose lcd and reset button?
If yes how can I go back to stock rom (short pin on emmc)?
And yes you can short the pin on emmc to flash it again, or if you flash the debug build just install terminal emulator and open it and connect the usb cable to the OTG port and type this commands on the Terminal Emulator(without the ""):
"su"
"reboot update"
And voila...
There are currently 2416 users online. 0 members and 2416 guests.
