MVR9 RK3328 - Custom AndroidTV Pie ROM by mo123
Originally posted by jcabad66 View PostI have managed to install in A5X MAX, and it works, but has several problems that makes a limited use of it.
Until now I have discovered:
1.- Bluetooth does not work
2.- There is no SPDIF audio output.
3.- It does not reboot (always go to off)
4.- Even after installing TWRP it is impossible to reboot to TWRP (I think this is due to point 3)
May be more problems
You can built it from Rockchip's code on Github.
But TWRP brings other problems like you can't boot firmware from a micro-sd card or update firmware on emmc from micro-sd cards anymore which is possible with stock recovery.
TWRP recovery is only useful for root, but there is already Magisk support so it's not needed and for backups there is Titanium Backup that only backups your apps and data and can restore it on any device. You can also try https://f-droid.org/en/packages/dk.jens.backup/ to backup your apps and settings.
Restoring backups with TWRP will cause problems if there are preinstalled apps or firmwares have different partition sizes which is not a problem with these 2 apps.
You can also make a full backup of firmware on the device with AndroidTool backup instructions I posted several times on freaktab in the past and easily restore everything, all apps intact, search for backup Rockchip etc.
Originally posted by SSimon View Post
The option to flash an image in the developer options is not available on my device. How do I enable it?
It should be on certain Android 9 devices & most Android 10-11 devices but is missing on Android 12.
If you don't have it then ask the manufacturer of your device to release a new firmware with those settings.
There are currently 1364 users online. 0 members and 1364 guests.
