MVR9 RK3328 - Custom AndroidTV Pie ROM by mo123
received my MX10 today detached and checked inside:
Hynix H26M78002BFR64GB NAND
MT41K1G4RH-125:E DDR3 Speicher IC 4 Gb (1 G x 4) Parallel 800MHz
SV6051P wifi
device does not have BT... :-(
weired: this unit should have DDR4 >> https://forum.freaktab.com/forum/tv-...-wifi-fast-lan
mo123 any idea?
Originally posted by soldiaz View Postreceived my MX10 today detached and checked inside:
SV6051P wifi
mo123 any idea?
You probably got a clone of the original MX10 as well or the manufacturer switched over to even cheaper parts and DDR3 without informing anyone.
Oh yes, some super cheap RK3328 devices also don't have bluetooth, don't expect it ever to be there if it is not listed in the specs.
Originally posted by mo123 View PostAndroidTV Pie Custom firmware v1.3 by mo123
Changelog v1.3
Magisk patched by default
Speed optimisations
Updated apps yowhatsapp
Added Dashboard - Use it to change the All Apps screen when Long pressing Home or clicking on the red Apps icon.
Added Notifications app - Now you can see notifications like on regular Android
Add Terminal Emulator - Needed if you want to spoof a device with MagiskHideProps addon
Removed Safe Volume, volume should now stay at 15 steps
Added Setup on first start - Google account needed
Download Link: Here
Pass: mvr9
Use 7z to unzip and FactoryTool v1.68e Restore option to flash
Changelog v1.2
sepolicy: uncrypt: allow sys_admin capability
service: UsbDeviceManager: force restart when usb disconnect
Fix: MP3 Audio Files should use FFPlayer
Remove potential double free
init.rc: do not restart SF to fix flash during boot
Fix a memory leak in gatekeeper
Fix some Google apps permission problems
Fix auto frame-rate switching
Remove Hide HDMI Output, it was causing problems with some apps
Changed animation speeds so that the spinning wheel in some apps play smoother
Updated apps
Add SmartYoutube, Youtube Vanced
Add Navigation bar app - Open it and enable the Accessibility Service to have a navigation bar
Improve Mele F10 airmouse - Bottom row keys now control Rewind, Stop, Play/Pause, Forward & the 1st key second bottom row now opens menus in apps.
Download Link: Here
Pass: mvr9
Boot image required for Magisk: Here
Changelog v1.1
hwui: stability: check mmap return value
arm64: dts: rockchip: fix rk3328 rgmii high tx error rate
make: Use build prop overrides when generating vendor
arm64: dts: rockchip: fix rk3328 sdmmc0 write errors
Move custom dpi settings under Display
Create 0 compression ratio jar files for improving speed and memory usage when it comes to reading apks
arm64: dts: rk3328-evb-android: set eMMC default sample phase to 90
clk: fractional-divider: add handle to frac numerator is not to be greater than 4
Fixes crash/race condition when destroyActivity
When compiling, use release-keys tag not dev-keys - Fix issues with some app requiring release-keys
libstagefright: Free buffers on observer died
DisplaySettings: font size in 5% steps from 80% to 130%
Fix NullPointerException in ConnectivityService
ViewRootImpl: set max fling ticks per sec to 24
BT: multi device interference problem
Optimize the font cache size according to display resolution
Fix OOB access in mpeg4/h263 decoder
Request to reset effect buffer in clearInputBuffer
drm/rockchip: dw-hdmi: limit tmds to 340mhz on rk3228/rk3328
uas: add USB quirks to unusual_uas: blacklist Norelsys, WD, and Seagate
ASCII fastpath for towupper and towlower - Decrease some apps, games loading time by 7%
Lots of speed optimisations
Fix bootanimation becoming slow
Updated apps
Manually set LeanKeyKeyboard - It now supports special characters for German
In Settings - Device - More Settings - Display | You can now change the font size, DPI easily to be smaller or bigger to fit your needs
Download Link: Here
Pass: mvr9
Changelog v1.0
* Add MVR9 boot logo
* Add ‘More Settings’ menu to TvSettings if you want to change extra settings like in the normal firmware- Change the onscreen keyboard to a mouse friendly one that is faster
- Remove some preinstalled apps
- Several stability and video playback patches from AOSP merged.
- Add auto frame-rate, color mode switching
- Add 10-bit H264 video playback support
All Anime videos should play correctly now
https://www.koi-sama.net/files/hi10/ 21 - Add VC1 Blu-ray video playback support
https://drive.google.com/file/d/0BwxFVkl63-lERnhlY1pHeW5wbjQ/view 12 - Fix HDR video playback
- Add HD Audio(DTS-HD, True-HD) pass-through support.
Add various gamepads support- Xbox, Xbox One, Xbox Elite controllers
- Sony USB DS3 and DS4 controllers
- Switch joycon and pro controllers
- Steam controller(also need to use the Steam app)
- Shield controller
Fix Home button on airmouses, USB remotes- Long press to see All apps screen
- Single press to return to Android Homescreen
- Double press for Recent apps
– Long press OK/DPAD_Center to close selected app window.
– Long press back button to close all recent apps
Wifi- Add Wifi connect button on wifi password enter screen to be easily clicked with a mouse, airmouse to setup wifi without using the onscreen keyboard
- General Wifi improvements
- Fix ethernet stops/disconnects sometimes bug
- Spoof ethernet as wifi connection
– This fixes some games like Asphalt that only work over wifi connections to also work if only using an ethernet connection
- Fix Youtube VP9 videos freezing sometimes bug
- Change frame-buffer to 1080p, 320DPI
- Set HDMI Bitstream as default audio device.
- Add support for 192kbps FLAC audio support
- Add Shutdown menu to TvSettings - About Screen
- Fix some apps running sideways to always run in landscape
- Add some default Ad-blocker list to block some ads on websites
- Add some extra apps.
Use MiXplorer File Manager(Samba v2 addon included) if wanting to access Samba v2.
Some other file managers only use Samba v1 which has less than half of the network performance of Samba v2.0. Kodi 18 also uses Samba v2 so you can use that to setup your network shares if playing high bit-rate videos over ethernet to get the best network speed.
- Fixed Google Play Store new layout to use the top Apps/Games/Updates/Settings menu correctly. Seems it’s a server side switch by Google and not everyone gets updated to the new layout.
- Removed additional stock apps not needed
- Changed DPI to 320 for a better AndroidTV experience
- Updated to latest video codecs
- Added some extra HDMI CEC properties. Hope it can fix the not working after resume issue.
- Add AppDrawer icon
- Updated to the latest Magisk Manager
Patch your boot.img and then click 5 times on build Info under the About menu to activate Developer Options. In Developer Options choose Flash image and select the /Download/magisk_patched.img and then select the boot partition. Restart your device for Magisk to work.
Or you can boot to TWRP Recovery and flash the Magisk.zip file - Add RefreshRate switching for any app
- Add KeyMapper application
This is an open-source app, Check the AppDrawer to open it.
You can map the power off menu, screenshot and Google Assistant(if you have a voice button on your airmouse) - Add CetusPlay server app so you can use your phone as a remote control for AndroidTV.
Install the client app on your phone - https://play.google.com/store/apps/d...ay.remotephone - Add Kodi and Nova Video Player app preinstalled.
Nova is a very decent video player app with poster art, subtitle download, network playback, auto frame-rate switching and audio passthrough and works better than VLC & MXPlayer. Check the useful guide to use it optimally. - Nova now supports 10-Bit H265 video playback on Rockchip devices
- Also supports 10-Bit H264 software decoding used by Anime videos.
(1080p support still wip) - Improved auto frame-rate switching accuracy and removed unused resolutions.
* Youtube Vanced login support added so you don’t have to use the rooted versions. - You must install the MicroG and Youtube Vanced app to be able to login.
(Youtube Vanced gives a phone layout without ads compared to SmartYoutubeTV that has an AndroidTV layout)
https://vancedtube.com/non-root/ - Decreased animation time by 50% for AndroidTV.
Should be a lot snappier now. - Fixed slow AndroidUI on every boot caused by fractional frame-rates
Pass: mvr9
Use at your own risk.
Make sure you have a backup or your stock firmware and know how to use MaskROM Mode and short the correct pins.
Oreo firmware was reported to not work on some DDR3 devices since the MVR9 device uses DDR4 RAM.
(I bricked my devices 9 or 10 times before I got the final firmware working correctly, but it works now on MVR9 devices with DDR4)
Changelog v1.3
Speed optimisations
Download Link: Here
Pass: mvr9
Changelog v1.2
Updated apps
Download Link: Here
Pass: mvr9
Changelog v1.1
Updated apps
Download Link: Here
Pass: mvr9
Changelog v1.0
- Shield controller
Pass: mvr9
The ROM is not compatible with SCISHION v88.
If you have the device the firmware was made for then the wifi will work and you can finish the setup.
I flash minixfreak os 9 and work every thing very smoothly, wifi also working,
https://forum.freaktab.com/forum/tv-...9-0#post821896
Please take wifi driver from this build and configure it to your romLast edited by Atif Munir; 29 March 2021, 17:03.
There are currently 3528 users online. 0 members and 3528 guests.
