MVR9 RK3328 - Custom AndroidTV Pie ROM by mo123
Hi ,
i tested your Rom on my Box , works , but only Wifi not ,
here are my Specs:
SCISHION Android 8.1 TV Box
rk3328 - RTL 8723 ce - Mali-450Mp - Cortex-A53
[QUOTE=Rudboy;n802352you not have any Tutorial how to add Wifidrivers , but it is possible [/QUOTE]
You can send me a link to your stock firmware for your device.
But Android 9 works differently so you can't just add drivers or build a new kernel, you have to rebuild the whole firmware since the kernel is part of the system now and you can't change anything manually. Maybe I can fix your ethernet problem but not wifi, if I have time in a week or 2 maybe I can check but can't promise anything.Last edited by gefattern; 23 July 2020, 15:45.
Originally posted by italorecife View PostMy TV Box is this: Alfawise T9 (https://forum.freaktab.com/forum/tv-...3-0-support-4k)
I installed your system but put it in bootloop, you know how to fix ?
Originally posted by italorecife View Postcould mo123 help me?
There is also no way to contact the manufacturer to release the source code of their device.
This ROM is for devices with DDR4 RAM, so if the T9 uses DDR3 it might cause problems.
You can use FactoryTool v1.67 and the Restore option if you want to flash your stock firmware back.
Sorry, can't help since I don't have such a device.
I have a T9 4GB/64GB TV BOX (RK3328) TV stick, it got bricked. I searched the internet and tried many methods to recover it, but failed, please help if you know a better solution.
I used RKBatchTool to restore it, and got a blue square, but after I click "restore" button, it failed at "Prepare idb fail"
I also tried RK Android Tool, my stick is loaded as "Found one MASKROM Device". I played around the tool, but every time it failed at the same reason "Prepare idb fail ".
I have no ideas, anyone please help!
Originally posted by billi69 View PostI have a T9 4GB/64GB TV BOX (RK3328) TV stick, it got bricked. I searched the internet and tried many methods to recover it, but failed, please help if you know a better solution.
Rockchip's official flash tool is FactoryTool v1.68
You have to contact the manufacturer of your device for the correct firmware and pins to short on your board to revive it.
Hello, I have an H96 Max+ with an RK3328 SoC, 4GB of DDR3 ram/32GB of storage. I flashed your rom with the restore option and couldn't get it to start. I plugged it into my TV and HDMI CEC got it started but it's stuck at the animation. I suspect the remote doesn't work but that doesn't explain why it doesn't boot, any ideas?
EDIT: I did get the remote to turn it on after a few tries, but still no boot, stuck on animation
Here is stock ROM: https://drive.google.com/drive/folde...V94e65sk6ZxdRO
and apparently website: https://www.h96tvbox.com/
There are currently 3500 users online. 0 members and 3500 guests.
