ATV9-MOD-(P212)AMPERE-V3
Sorry. I use this firmware ATV9-IMG-DEBUG-AMPERE-AP6330-V3.01-02 and now my box MXQ Pro+ 4k with AP6330 cannot enter recognize the recovery button now.
I tried to use ATVX V2H zip file to update in Update app and now it got boot loop on the logo of androidtv. Last time i used this method to enter recovery mode as Update app will restart in recovery mode but now not.
Anybody has any advice? I don't know which pin need to be shorted on my box.
Update: It's ok now. Need short pin 17-18 Samsung KLMAG2WEMB-B031. Short pin then plug USB cable while open USB Burning Tool.Last edited by hall; 24 January 2021, 06:36.
Please help after flash i can use Putty for shell dropbear also adb over ethernet working but i have two usb ports one is USB-OTG other is USB both are not working but when I plug my phone it show charging only means ta volt output is less. what shoud i do to fix it i dont even have twrp. and cannot reflash other rom
Hello everyone, I hope someone answers me because I see that the post is outdated. I have a box with s905w SoC which has an RT8703BS chipset. Look for all the possible ROMs in which the Wi-Fi will work, but you can't find any. I got my hands on an atvX_s905w_4.3 ROM which had the SSH-Key-bundle file inside and it brought me to this post. I didn't try to connect via putty because I don't know where to get the device's IP from. Beyond that, I would like to know if I do this, will I be able to lower the drivers on my motherboard, otherwise I'll give up because I've been going around with this for three weeks. Thank you very much for your help​
Originally posted by pindonga.noname View PostHello everyone, I hope someone answers me because I see that the post is outdated. I have a box with s905w SoC which has an RT8703BS chipset. Look for all the possible ROMs in which the Wi-Fi will work, but you can't find any. I got my hands on an atvX_s905w_4.3 ROM which had the SSH-Key-bundle file inside and it brought me to this post. I didn't try to connect via putty because I don't know where to get the device's IP from. Beyond that, I would like to know if I do this, will I be able to lower the drivers on my motherboard, otherwise I'll give up because I've been going around with this for three weeks. Thank you very much for your help​
There are currently 3566 users online. 0 members and 3566 guests.
