ATV9-MOD-(P212)AMPERE-V3
hi
I installed ATV9-img- debug-ampere AP6330-v3 on my device T6 s905x and it was successfully completed, but the problem when operating the device works well but asks to choose the language and choose the language but when I press the OK button it does not work until I continue to the next steps, unfortunately I could not Do this because the remote does not work, and also I cannot replace the remote file because I cannot log in. Please help.
Originally posted by bumerc View Postuse the remote control of your TV. Read the previous pages, it is described several times how you can replace the remote.conf. Regarding USB port - only one of the two works at the moment
Originally posted by RiCkLaR_atvX View PostFor those that know how, setting the CPU minimum frequency at 500 or 600 mhz seems to really improve this firmware which is already very stellar and I don't feel a need to change much of anything.
Thank you
Hannah
Unfortunately I read all the previous pages and did not find any solution to this problem and also tried to login ssh and I could not login as root, generally I have a request if it is possible to modify the remote file in the Rom so that we can install the Rom without problems.
2. Attach your remote.conf here
:/vendor/etc/dropbear # dmesg | grep chip
[ 0.226749] Meson chip version = RevB (21:B - 82:0)
[ 1.153218] hdmitx: system: hdmitx_device.chip_type : 3
[ 1.350089] chip type:0x21
[ 7.828709] The chip is not support hevc encoder
127|:/vendor/etc/dropbear # mount -o rw,remount /vendor
:/vendor/etc/dropbear # cp /sdcard/remote.conf /vendor/etc/remote.cfg
cp: bad '/sdcard/remote.conf': No such file or directory
1|:/vendor/etc/dropbear #
emtrack_default:s0 tcontext=u:r:dropbear:s0 tclass=dir permissive=1
[ 1290.332520] meson-remote c8100580.rc: scancode 80 undefined
[ 1290.332637] meson-remote c8100580.rc: no valid key to handle
[ 1290.744918] meson-remote c8100580.rc: scancode 81 undefined
[ 1290.745032] meson-remote c8100580.rc: no valid key to handle
[ 1431.566207] type=1400 audit(1589554607.436:240): avc: denied { search } for p id=3106 comm="[email protected]" name="3117" dev="proc" ino=614 scontext=u:r:hal_m
how to replace remote file or confLast edited by Leiden; 15 May 2020, 16:04.
/dev/root on / type ext4 (ro,seclabel,relatime,block_validity,delalloc,barr ier,user_xattr,acl)
devtmpfs on /dev type devtmpfs (rw,seclabel,relatime,size=1027176k,nr_inodes=1859 08,mode=755)
tmpfs on /dev type tmpfs (rw,seclabel,nosuid,relatime,mode=755)
devpts on /dev/pts type devpts (rw,seclabel,relatime,mode=600,ptmxmode=000)
proc on /proc type proc (rw,relatime)
sysfs on /sys type sysfs (rw,seclabel,relatime)
selinuxfs on /sys/fs/selinux type selinuxfs (rw,relatime)
tmpfs on /mnt type tmpfs (rw,seclabel,nosuid,nodev,noexec,relatime,mode=755 ,gid=1000)
/dev/block/odm on /odm type ext4 (ro,seclabel,relatime,block_validity,delalloc,nojo urnal_checksum,barrier,user_xattr,acl,inode_readah ead_blks=8)
/dev/block/product on /product type ext4 (ro,seclabel,relatime,block_validity,delalloc,nojo urnal_checksum,barrier,user_xattr,acl,inode_readah ead_blks=8)
/dev/block/vendor on /vendor type ext4 (ro,seclabel,relatime,block_validity,delalloc,barr ier,user_xattr,acl,inode_readahead_blks=8)
none on /acct type cgroup (rw,nosuid,nodev,noexec,relatime,cpuacct)
/sys/kernel/debug on /sys/kernel/debug type debugfs (rw,seclabel,relatime,mode=755)
configfs on /sys/kernel/config type configfs (rw,relatime)
none on /dev/stune type cgroup (rw,nosuid,nodev,noexec,relatime,schedtune)
none on /config type configfs (rw,nosuid,nodev,noexec,relatime)
none on /dev/cpuctl type cgroup (rw,nosuid,nodev,noexec,relatime,cpu)
none on /dev/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset,noprefix,r elease_agent=/sbin/cpuset_release_agent)
cg2_bpf on /dev/cg2_bpf type cgroup2 (rw,nosuid,nodev,noexec,relatime)
bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime)
pstore on /sys/fs/pstore type pstore (rw,seclabel,nosuid,nodev,noexec,relatime)
tracefs on /sys/kernel/debug/tracing type tracefs (rw,seclabel,relatime)
/dev/block/data on /data type ext4 (rw,seclabel,nosuid,nodev,noatime,nodelalloc,resgi d=1065,errors=panic,data=ordered)
/dev/block/cache on /cache type ext4 (rw,seclabel,nosuid,nodev,noatime,nodelalloc,error s=panic,data=ordered)
/dev/block/metadata on /metadata type ext4 (rw,seclabel,nosuid,nodev,noatime,nodelalloc,error s=panic,data=ordered)
/dev/block/param on /mnt/vendor/param type ext4 (rw,seclabel,nosuid,nodev,noatime,nodelalloc,error s=panic,data=ordered)
/dev/block/tee on /mnt/vendor/tee type ext4 (rw,seclabel,nosuid,nodev,noatime,nodelalloc,error s=panic,data=ordered)
tmpfs on /storage type tmpfs (rw,seclabel,nosuid,nodev,noexec,relatime,mode=755 ,gid=1000)
adb on /dev/usb-ffs/adb type functionfs (rw,relatime)
/data/media on /mnt/runtime/default/emulated type sdcardfs (rw,nosuid,nodev,noexec,noatime,fsuid=1023,fsgid=1 023,gid=1015,multiuser,mask=6,derive_gid,default_n ormal)
/data/media on /storage/emulated type sdcardfs (rw,nosuid,nodev,noexec,noatime,fsuid=1023,fsgid=1 023,gid=1015,multiuser,mask=6,derive_gid,default_n ormal)
/data/media on /mnt/runtime/read/emulated type sdcardfs (rw,nosuid,nodev,noexec,noatime,fsuid=1023,fsgid=1 023,gid=9997,multiuser,mask=23,derive_gid,default_ normal)
/data/media on /mnt/runtime/write/emulated type sdcardfs (rw,nosuid,nodev,noexec,noatime,fsuid=1023,fsgid=1 023,gid=9997,multiuser,mask=7,derive_gid,default_n ormal)
:/vendor/etc/dropbear # cp /your_sdcard/mount/point/remote.conf /vendor/etc/remote1.tab
cp: bad '/your_sdcard/mount/point/remote.conf': No such file or directory
f': No such file or directoryLast edited by Leiden; 15 May 2020, 18:22.
There are currently 2480 users online. 1 members and 2479 guests.
