ATV9-MOD-(P212)AMPERE-V3
    Ok successful flash of this Rom. Got SSH working, still not joy with remote. Took my original remote.conf and copied to /vendor/etc/remote.cfg still only up and down buttons working. Then I copied remote.conf to /vendor/etc/remote1.tab still only up and down working. I'm probably doing something wrong. Here is my original remote.conf. Any help would be great. Thanks! Nice ROM!
    #this file is configuration for each factory remote device
    # work_mode 0 :software mode 1 :hardware mode
    # repeat_enable 0 :disable repeat 1 :enable repeat
    # factory_code each device has it's unique factory code.
    # pattern:custom_code(16bit)+index_code(16bit)
    # examble: 0xff000001 = 0xff00(custom cod) 0001 (index)
    # release_delay unit:ms.release will report from kernel to user layer after this period of time
    # from press or repeat triggered.
    # debug_enable 0 :debug disable 1 :debug disable
    # SW MODE:
    # bit_count how many bits in each frame
    # tw_leader_act time window for leader active
    # tw_bit0 time window for bit0 time.
    # tw_bit1 time window for bit1 time
    # tw_repeat_leader time window for repeat leader
    # REG
    # reg_base_gen set value for PREG_IR_DEC_BASE_GEN
    # reg_control set value for PREG_IR_DEC_CONTROL
    # reg_leader_act set value for PREG_IR_DEC_LEADER_ACTIVE
    # reg_leader_idle set value for PREG_IR_DEC_LEADER_IDLE
    # reg_repeat_leader set value for PREG_IR_DEC_REPEAT_IDLE
    # reg_bit0_time set value for PREG_IR_DEC_BIT0_TIME
    #amlogic NEC remote
    factory_code = 0xfe010001
    work_mode = 0
    repeat_enable = 1
    repeat_delay = 40
    repeat_peroid = 39
    release_delay = 121
    debug_enable = 1
    fn_key_scancode = 0x00
    left_key_scancode = 0x51
    right_key_scancode = 0x50
    up_key_scancode = 0x16
    down_key_scancode = 0x1a
    ok_key_scancode = 0x13
    pageup_key_scancode = 0x55
    pagedown_key_scancode = 0x54
    mouse_begin
    0 0x51
    1 0x50
    2 0x16
    3 0x1a
    mouse_end
    key_begin
    0x01 11
    0x4e 2
    0x0d 3
    0x0c 4
    0x4a 5
    0x09 6
    0x08 7
    0x46 8
    0x05 9
    0x04 10
    0x13 97
    0x19 15
    0x42 14
    0x16 103
    0x1a 108
    0x51 105
    0x50 106
    0x18 102
    0x11 104
    0x4c 109
    0x10 125
    0x5a 119
    0x59 122
    0x52 128
    0x58 123
    0x54 120
    0x55 121
    0x40 116
    0x41 113
    0x45 130
    0x49 134
    0x0a 133
    0x48 138
    0x4d 70
    0x0e 136
    0x0f 186
    0x43 183
    0x03 127
    0x06 139
    0x44 140
    0x00 63
    0x02 395
    key_end
    repeat_key_begin
    0x01 11
    0x4e 2
    0x0d 3
    0x0c 4
    0x4a 5
    0x09 6
    0x08 7
    0x46 8
    0x05 9
    0x04 10
    0x13 97
    0x19 15
    0x42 14
    0x16 103
    0x1a 108
    0x51 105
    0x50 106
    0x18 102
    0x11 104
    0x4c 109
    0x10 125
    0x5a 119
    0x59 122
    0x52 128
    0x58 123
    0x54 120
    0x55 121
    0x40 116
    0x41 113
    0x45 130
    0x49 134
    0x0a 133
    0x48 138
    0x4d 70
    0x0e 136
    0x0f 186
    0x43 183
    0x03 127
    0x06 139
    0x44 140
    0x00 63
    0x02 395
    repeat_key_end
      Originally posted by bumerc View Post
      replace the vendor partition
      repack the aml_package _ *. img and try again
      edit: or update via vecovery: vendor.zip
      Hello, I now have updated the vendor.PARTITION and can confirm that Wifi is NOT working.
      Work Done:
      - My TV Box: Nexbox A95X 2GB/16GB S905X WIFI AP6330
      - Unpack Level 1
      - copied updated vendor.PARTITION
      - repack
      - Burn with USB Burning Tool and it was a success
      Attached is the combined diagnostic output of following commands
      Code:
      C:\opt\adb>adb connect 192.168.0.101:5555
      C:\opt\adb>adb root
      C:\opt\adb>adb shell dmesg > dmesg1
      C:\opt\adb>adb shell lsmod >> dmesg1
      C:\opt\adb>
        ok guys, thanks for the tests, tomorrow will continue..
          Your effort is highly appreciated.
ID:	803640Click image for larger version
ID:	803641Click image for larger version
ID:	803642Click image for larger version
ID:	803643Click image for larger version
ID:	803644Click image for larger version
ID:	803645Click image for larger version
ID:	803646Click image for larger version
ID:	803647Click image for larger version
ID:	803648Click image for larger version
            I have ddr3 2gb 16gb.I have not bought a uart adapter yet.
              sagert
              how does your device behave with working Frinware, does it slow down over time? What is the CPU temperature? The maximum clock frequency of your RAM memory is 800Mhz, I have set u-boot to 792Mhz for DDR3.
              Did you test the FE with a new kernel?
                hannah
                Your WiFi chip will now be recognized properly, but there is still a problem with the FW, I will check the new changes more closely
                firmtech
                use remote.tab files, if you've created a working remote.tab, post it here, I'll add it to the next build
                  hannah
                  Appreciate your effort and shall wait patiently.
                    sagert
                    I'm on Android 10 now. this is the port from Phhusson and daivietpda.Android 10 is faster for Android 9 and it does not slow down.Of course you need to finish it a little.I will test your firmware a little later.
                      hannah
                      Do I need to try flashing the device? I have exactly the same nexbox as hannah
                        can you send me a link please?
                          Still no luck with remote. I tried all combinations renaming my original remote.conf to remote.tab, remote1.tab via ssh using mount -o rw,remount /vendor first. I am seeing this when I press the right remote button (this is a button that is not working) in the terminal window.
                          [ 671.611492@1] meson-remote c8100580.rc: scancode 80 undefined
                          [ 671.611599@1] meson-remote c8100580.rc: no valid key to handle
                          Buttons that work, even though some are mapped wrong have no output in terminal.
                          HDMI CEC works great with Samsung TV so remote is not a huge issue.
                          Pic of remote attached if someone is familiar with it.
                            Here on the site there is an Android Q theme for amlogic s905x.
                              activate debugging in your remote.cfg file
                              Code:
                              debug_enable 1
                              start the SSH session, press the buttons of your remote control one by one and then enter the command
                              Code:
                              dmesg -c
                              note the codes of each button. Also write a comment on each key code, which key it belongs to, post this note here
                                need to check.
                                changed. Most buttons should work
