ATV9-MOD-(P212)AMPERE-V3
Originally posted by firmtech View Post
alex161rus, tried your remote file. Did not work. Weird, that is the remote.conf from my original rom backup so you would think 0xfe01 should work. When I run dmesg -c with debug enabled I get same results I saw in terminal window. Buttons that work like UP and Down have no output to the screen. Buttons that are mapped wrong have no output to the screen either. Right and Left buttons that don't work have output like this... any thoughts? Thanks for your help!
[ 671.611492@1] meson-remote c8100580.rc: scancode 80 undefined
[ 671.611599@1] meson-remote c8100580.rc: no valid key to handle
Originally posted by bumerc View PostPost your original remote.conf with a comment for each key code, which function it triggers, I will later integrate this into dtbAttached Files
firmtech
download meson1.dtb
and install it..
SSH install(ccopy meson1.dtb to sdcard)
dd if=/sdcard/meson1.dtb of=/dev/block/dtb bs=262144
adb shell dd if=meson1.dtb of=/dev/block/dtb bs=262144
this is my log
:/vendor/etc/dropbear # dmesg | grep wifi
[ 0.000000] Kernel command line: init=/init console=ttyS0,115200 no_console_suspend earlycon=aml_uart,0xc81004c0 ramoops.pstore_en=1 ramoops.record_size=0x8000 ramoops.console_size=0x4000 otg_device=1 reboot_mode_android=normal androidboot.selinux=permissive logo=osd1,loaded,0x3d800000,1080p60hz maxcpus=4 vout=1080p60hz,enable hdmimode=1080p60hz frac_rate_policy=1 cvbsmode=576cvbs hdmitx=,rgb,8bit cvbsdrv=0 irq_check_en=0 androidboot.firstboot=0 jtag=apao androidboot.veritymode=enforcing androidboot.hardware=amlogic page_trace=on androidboot.rpmb_state=0 androidboot.serialno=1234567890 androidboot.wificountrycode=US ro rootwait skip_initramfs androidboot.dtbo_idx=0 --cmdline root=/dev/mmcblk0p18 buildvariant=userdebug
[ 2.474563] wifi: power_on_pin_OD = 0;
[ 2.476976] aml_wifi wifi: [wifi_dev_probe] no power_on_pin2
[ 2.482914] aml_wifi wifi: [pwm_double_channel_conf_dt] wifi pwm dt ok
[ 2.489548] aml_wifi wifi: [pwm_double_channel_conf] wifi pwm conf ok
[ 2.496205] aml_wifi wifi: [wifi_dev_probe] dhd_static_buf setup
[ 2.516436] aml_wifi wifi: [wifi_dev_probe] interrupt_pin=487
[ 2.522341] aml_wifi wifi: [wifi_dev_probe] irq_num=0, irq_trigger_type=1
[ 2.529371] aml_wifi wifi: [wifi_dev_probe] power_on_pin=486
[ 2.535203] aml_wifi wifi: [wifi_dev_probe] clock_32k_pin=0
[ 2.541247] aml_wifi wifi: [wifi_setup_dt] wifi_setup_dt
[ 2.546664] aml_wifi wifi: [wifi_setup_dt] irq num is64)
[ 2.552182] aml_wifi wifi: [wifi_setup_dt] interrupt_pin(487)
[ 2.558170] aml_wifi wifi: [wifi_setup_dt] power_on_pin(486)
[ 11.490189] dhd_wifi_platform_load: Enter
[ 11.499144] wifi_platform_set_power = 1
[ 11.508385] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 11.715095] aml_wifi wifi: [extern_wifi_set_enable] WIFI Enable! 486
[ 12.224325] wifi_platform_bus_enumerate device present 1
[ 14.369182] wifi_platform_set_power = 0
[ 14.373328] wifi_platform_bus_enumerate device present 0
[ 14.384435] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 14.593002] wifi_platform_set_power = 1
[ 14.596685] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 14.803379] aml_wifi wifi: [extern_wifi_set_enable] WIFI Enable! 486
[ 15.312385] wifi_platform_bus_enumerate device present 1
[ 17.377814] wifi_platform_set_power = 0
[ 17.382857] wifi_platform_bus_enumerate device present 0
[ 17.393168] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 17.607075] wifi_platform_set_power = 1
[ 17.610787] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 17.817424] aml_wifi wifi: [extern_wifi_set_enable] WIFI Enable! 486
[ 18.324358] wifi_platform_bus_enumerate device present 1
[ 20.386183] wifi_platform_set_power = 0
[ 20.389862] wifi_platform_bus_enumerate device present 0
[ 20.401459] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 20.608097] wifi_platform_set_power = 1
[ 20.611762] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 20.818422] aml_wifi wifi: [extern_wifi_set_enable] WIFI Enable! 486
[ 21.324812] wifi_platform_bus_enumerate device present 1
[ 23.395719] wifi_platform_set_power = 0
[ 23.399416] wifi_platform_bus_enumerate device present 0
[ 23.410978] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 23.618833] unregister wifi platform drivers
[ 23.623182] wifi_platform_bus_enumerate device present 0
[ 23.634829] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 23.864533] dhd_wifi_platform_load: Enter
[ 23.873586] wifi_platform_set_power = 1
[ 23.882822] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 24.089493] aml_wifi wifi: [extern_wifi_set_enable] WIFI Enable! 486
[ 24.596738] wifi_platform_bus_enumerate device present 1
[ 26.662474] wifi_platform_set_power = 0
[ 26.666414] wifi_platform_bus_enumerate device present 0
[ 26.678077] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 26.884799] wifi_platform_set_power = 1
[ 26.888473] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 27.095143] aml_wifi wifi: [extern_wifi_set_enable] WIFI Enable! 486
[ 27.600319] wifi_platform_bus_enumerate device present 1
[ 29.670846] wifi_platform_set_power = 0
[ 29.674739] wifi_platform_bus_enumerate device present 0
[ 29.686428] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 29.893167] wifi_platform_set_power = 1
[ 29.896838] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 30.103517] aml_wifi wifi: [extern_wifi_set_enable] WIFI Enable! 486
[ 30.612324] wifi_platform_bus_enumerate device present 1
[ 32.673623] wifi_platform_set_power = 0
[ 32.677256] wifi_platform_bus_enumerate device present 0
[ 32.688867] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 32.895508] wifi_platform_set_power = 1
[ 32.899178] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 33.105833] aml_wifi wifi: [extern_wifi_set_enable] WIFI Enable! 486
[ 33.612350] wifi_platform_bus_enumerate device present 1
[ 35.681674] wifi_platform_set_power = 0
[ 35.685561] wifi_platform_bus_enumerate device present 0
[ 35.697200] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 35.905023] unregister wifi platform drivers
[ 35.909408] wifi_platform_bus_enumerate device present 0
[ 35.921111] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 36.150810] dhd_wifi_platform_load: Enter
[ 36.159865] wifi_platform_set_power = 1
[ 36.169113] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 36.375763] aml_wifi wifi: [extern_wifi_set_enable] WIFI Enable! 486
[ 36.884401] wifi_platform_bus_enumerate device present 1
[ 38.950722] wifi_platform_set_power = 0
[ 38.954608] wifi_platform_bus_enumerate device present 0
[ 38.966167] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 39.172801] wifi_platform_set_power = 1
[ 39.176474] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 39.383161] aml_wifi wifi: [extern_wifi_set_enable] WIFI Enable! 486
[ 39.888336] wifi_platform_bus_enumerate device present 1
[ 41.953687] wifi_platform_set_power = 0
[ 41.957320] wifi_platform_bus_enumerate device present 0
[ 41.968936] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 42.175573] wifi_platform_set_power = 1
[ 42.179239] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 42.385897] aml_wifi wifi: [extern_wifi_set_enable] WIFI Enable! 486
[ 42.892740] wifi_platform_bus_enumerate device present 1
[ 44.962792] wifi_platform_set_power = 0
[ 44.970226] wifi_platform_bus_enumerate device present 0
[ 44.978505] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 45.185071] wifi_platform_set_power = 1
[ 45.188747] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 45.395412] aml_wifi wifi: [extern_wifi_set_enable] WIFI Enable! 486
[ 45.904316] wifi_platform_bus_enumerate device present 1
[ 47.969886] wifi_platform_set_power = 0
[ 47.973528] wifi_platform_bus_enumerate device present 0
[ 47.985127] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 48.192956] unregister wifi platform drivers
[ 48.197328] wifi_platform_bus_enumerate device present 0
[ 48.208999] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 48.438705] dhd_wifi_platform_load: Enter
[ 48.447765] wifi_platform_set_power = 1
[ 48.457007] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 48.663667] aml_wifi wifi: [extern_wifi_set_enable] WIFI Enable! 486
[ 49.172743] wifi_platform_bus_enumerate device present 1
[ 51.233698] wifi_platform_set_power = 0
[ 51.237331] wifi_platform_bus_enumerate device present 0
[ 51.248975] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 51.455582] wifi_platform_set_power = 1
[ 51.459245] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 51.665911] aml_wifi wifi: [extern_wifi_set_enable] WIFI Enable! 486
[ 52.172743] wifi_platform_bus_enumerate device present 1
[ 54.246693] wifi_platform_set_power = 0
[ 54.250586] wifi_platform_bus_enumerate device present 0
[ 54.262244] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 54.468994] wifi_platform_set_power = 1
[ 54.472655] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 54.679315] aml_wifi wifi: [extern_wifi_set_enable] WIFI Enable! 486
[ 55.188382] wifi_platform_bus_enumerate device present 1
[ 57.249646] wifi_platform_set_power = 0
[ 57.253274] wifi_platform_bus_enumerate device present 0
[ 57.264887] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 57.471561] wifi_platform_set_power = 1
[ 57.475224] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 57.681890] aml_wifi wifi: [extern_wifi_set_enable] WIFI Enable! 486
[ 58.188728] wifi_platform_bus_enumerate device present 1
[ 60.262566] wifi_platform_set_power = 0
[ 60.266462] wifi_platform_bus_enumerate device present 0
[ 60.277977] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 60.485847] unregister wifi platform drivers
[ 60.490279] wifi_platform_bus_enumerate device present 0
[ 60.501913] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 67.771162] aml_wifi wifi: [usb_power_control] Set WiFi power down
[ 68.005788] aml_wifi wifi: [usb_power_control] Set WiFi power on !
[ 68.035148] aml_wifi wifi: [usb_power_control] Set WiFi power on !
[ 68.240786] aml_wifi wifi: [pci_reinit] pci wifi reinit!
[ 68.240837] aml_wifi wifi: [wifi_power_ioctl] Set sdio wifi power up!
[ 68.247592] aml_wifi wifi: [wifi_power_ioctl] wifi interface dev type: sdio, length = 4
[ 86.035215] aml_wifi wifi: [usb_power_control] Set WiFi power down
[ 86.035941] aml_wifi wifi: [wifi_power_ioctl] ioctl Set sdio wifi power down!
:/vendor/etc/dropbear # dmesg | grep chip
[ 0.222797] Meson chip version = RevB (21:B - 82:0)
[ 1.150158] hdmitx: system: hdmitx_device.chip_type : 3
[ 1.347015] chip type:0x21
[ 9.493928] The chip is not support hevc encoder
Originally posted by bumerc View Postfirmtech
download meson1.dtb
and install it..
ADB install
reboot
:/vendor/etc/dropbear # dmesg -c
[ 689.882275] meson-remote c8100580.rc: scancode 80 undefined
[ 689.882402] meson-remote c8100580.rc: no valid key to handle
[ 699.339118] meson-remote c8100580.rc: scancode 81 undefined
[ 699.339274] meson-remote c8100580.rc: no valid key to handle
Originally posted by bumerc View Postshow the dtb installation log
login as: root
* Welcome to ampere SSH-server! *
Authenticating with public key "imported-openssh-key"
Passphrase for key "imported-openssh-key":
:/vendor/etc/dropbear # dd if=/storage/C0E4-7E0C/meson1.dtb of=/dev/block/dtb bs=262144
0+1 records in
0+1 records out
174080 bytes transferred in 0.013 secs (13390769 bytes/sec)
:/vendor/etc/dropbear # reboot
Originally posted by bumerc View PostOK, everything is right.
Are you sure you have a correct remote.conf file? The remote control works for other users..
Originally posted by bumerc View Postthere is a way to check this. Install CoreElec on the SD card and create a new remote.cfg file, compare the key codes of this file with the original fileAttached Files
There are currently 1931 users online. 1 members and 1930 guests.
