ATV9-MOD-(P212)AMPERE-V3
now, second USB is working, but first (firmware upload) USB not working.
bluetooth is working
127|:/vendor/etc/dropbear # dmesg | grep wifi
[ 0.000000] Kernel command line: init=/init console=ttyS0,115200 no_console_suspend earlycon=aml_uart,0xc81004c0 ramoops.pstore_en=1 ramoops.record_size=0x8000 ramoops.console_size=0x4000 otg_device=1 reboot_mode_android=normal androidboot.selinux=permissive logo=osd1,loaded,0x3d800000,1080p60hz maxcpus=4 vout=1080p60hz,enable hdmimode=1080p60hz frac_rate_policy=1 cvbsmode=576cvbs hdmitx=,444,8bit cvbsdrv=0 irq_check_en=0 androidboot.firstboot=0 jtag=apao androidboot.veritymode=enforcing androidboot.hardware=amlogic page_trace=on androidboot.rpmb_state=0 androidboot.serialno=1234567890 androidboot.wificountrycode=US ro rootwait skip_initramfs androidboot.dtbo_idx=0 vmalloc=512m --cmdline root=/dev/mmcblk0p18 buildvariant=userdebug
[ 1.552076] wifi: power_on_pin_OD = 0;
[ 1.554524] aml_wifi wifi: [wifi_dev_probe] no power_on_pin2
[ 1.560377] aml_wifi wifi: [pwm_double_channel_conf_dt] wifi pwm dt ok
[ 1.567066] aml_wifi wifi: [pwm_double_channel_conf] wifi pwm conf ok
[ 1.573723] aml_wifi wifi: [wifi_dev_probe] dhd_static_buf setup
[ 1.593916] aml_wifi wifi: [wifi_dev_probe] interrupt_pin=487
[ 1.599855] aml_wifi wifi: [wifi_dev_probe] irq_num=0, irq_trigger_type=1
[ 1.606892] aml_wifi wifi: [wifi_dev_probe] power_on_pin=486
[ 1.612716] aml_wifi wifi: [wifi_dev_probe] clock_32k_pin=0
[ 1.618756] aml_wifi wifi: [wifi_setup_dt] wifi_setup_dt
[ 1.624189] aml_wifi wifi: [wifi_setup_dt] irq num is69)
[ 1.629704] aml_wifi wifi: [wifi_setup_dt] interrupt_pin(487)
[ 1.635667] aml_wifi wifi: [wifi_setup_dt] power_on_pin(486)
[ 10.171880] dhd_wifi_platform_load: Enter
[ 10.180890] wifi_platform_set_power = 1
[ 10.190973] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 10.399275] aml_wifi wifi: [extern_wifi_set_enable] WIFI Enable! 486
[ 10.912777] wifi_platform_bus_enumerate device present 1
[ 11.420993] wifi_platform_set_power = 0
[ 21.956915] wl_android_wifi_on in 1
[ 21.960416] wl_android_wifi_on in 2: g_wifi_on=0
[ 21.965318] wifi_platform_set_power = 1
[ 21.974667] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 22.236778] aml_wifi wifi: [extern_wifi_set_enable] WIFI Enable! 486
[ 23.125926] dhd_conf_read_config: Ignore config file /vendor/etc/wifi/buildin/config.txt
[ 23.129417] Final fw_path=/vendor/etc/wifi/buildin/fw_bcm40183b2.bin
[ 23.136369] Final nv_path=/vendor/etc/wifi/buildin/
[ 23.143606] Final clm_path=/vendor/etc/wifi/buildin/clm.blob
[ 23.146397] Final conf_path=/vendor/etc/wifi/buildin/config.txt
[ 23.160303] dhd_os_open_image1: /vendor/etc/wifi/buildin/fw_bcm40183b2.bin (239507 bytes) open success
[ 23.344644] dhd_os_open_image1: /vendor/etc/wifi/buildin/ is not regular file
[ 23.346445] dhdsdio_download_nvram: Open nvram file failed /vendor/etc/wifi/buildin/
[ 23.383551] wifi_platform_set_power = 0
[ 23.392111] wl_android_wifi_on: Failed
[ 23.396947] dhd_open : wl_android_wifi_on failed (-35)
[ 23.408162] wl_android_wifi_off in 1
[ 23.411934] wl_android_wifi_off in 2: g_wifi_on=0, on_failure=1
[ 23.427960] wifi_platform_set_power = 0
[ 23.439444] wl_android_wifi_off out
[ 33.239478] wl_android_wifi_on in 1
[ 33.242799] wl_android_wifi_on in 2: g_wifi_on=0
[ 33.247770] wifi_platform_set_power = 1
[ 33.256782] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 33.491978] aml_wifi wifi: [extern_wifi_set_enable] WIFI Enable! 486
[ 34.289196] dhd_conf_read_config: Ignore config file /vendor/etc/wifi/buildin/config.txt
[ 34.291826] Final fw_path=/vendor/etc/wifi/buildin/fw_bcm40183b2.bin
[ 34.308515] Final nv_path=/vendor/etc/wifi/buildin/
[ 34.308649] Final clm_path=/vendor/etc/wifi/buildin/clm.blob
[ 34.321258] Final conf_path=/vendor/etc/wifi/buildin/config.txt
[ 34.326109] dhd_os_open_image1: /vendor/etc/wifi/buildin/fw_bcm40183b2.bin (239507 bytes) open success
[ 34.460366] dhd_os_open_image1: /vendor/etc/wifi/buildin/ is not regular file
[ 34.462118] dhdsdio_download_nvram: Open nvram file failed /vendor/etc/wifi/buildin/
[ 34.523273] wifi_platform_set_power = 0
[ 34.533060] wl_android_wifi_on: Failed
[ 34.541078] dhd_open : wl_android_wifi_on failed (-35)
[ 34.550491] wl_android_wifi_off in 1
[ 34.552339] wl_android_wifi_off in 2: g_wifi_on=0, on_failure=1
[ 34.570194] wifi_platform_set_power = 0
[ 34.579200] wl_android_wifi_off out
[ 177.787796] wl_android_wifi_on in 1
[ 177.788001] wl_android_wifi_on in 2: g_wifi_on=0
[ 177.793166] wifi_platform_set_power = 1
[ 177.803106] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 178.030114] aml_wifi wifi: [extern_wifi_set_enable] WIFI Enable! 486
[ 178.756515] dhd_conf_read_config: Ignore config file /vendor/etc/wifi/buildin/config.txt
[ 178.761565] Final fw_path=/vendor/etc/wifi/buildin/fw_bcm40183b2.bin
[ 178.761568] Final nv_path=/vendor/etc/wifi/buildin/
[ 178.761570] Final clm_path=/vendor/etc/wifi/buildin/clm.blob
[ 178.761572] Final conf_path=/vendor/etc/wifi/buildin/config.txt
[ 178.773261] dhd_os_open_image1: /vendor/etc/wifi/buildin/fw_bcm40183b2.bin (239507 bytes) open success
[ 178.946135] dhd_os_open_image1: /vendor/etc/wifi/buildin/ is not regular file
[ 178.947872] dhdsdio_download_nvram: Open nvram file failed /vendor/etc/wifi/buildin/
[ 178.984487] wifi_platform_set_power = 0
[ 178.993335] wl_android_wifi_on: Failed
[ 178.997335] dhd_open : wl_android_wifi_on failed (-35)
[ 179.009722] wl_android_wifi_off in 1
[ 179.013434] wl_android_wifi_off in 2: g_wifi_on=0, on_failure=1
[ 179.029424] wifi_platform_set_power = 0
[ 179.038570] wl_android_wifi_off out
[ 248.215458] wl_android_wifi_on in 1
[ 248.229410] wl_android_wifi_on in 2: g_wifi_on=0
[ 248.229512] wifi_platform_set_power = 1
[ 248.237848] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 248.603620] aml_wifi wifi: [extern_wifi_set_enable] WIFI Enable! 486
[ 249.264871] dhd_conf_read_config: Ignore config file /vendor/etc/wifi/buildin/config.txt
[ 249.272398] Final fw_path=/vendor/etc/wifi/buildin/fw_bcm40183b2.bin
[ 249.278821] Final nv_path=/vendor/etc/wifi/buildin/
[ 249.283830] Final clm_path=/vendor/etc/wifi/buildin/clm.blob
[ 249.289596] Final conf_path=/vendor/etc/wifi/buildin/config.txt
[ 249.297011] dhd_os_open_image1: /vendor/etc/wifi/buildin/fw_bcm40183b2.bin (239507 bytes) open success
[ 249.355032] dhd_os_open_image1: /vendor/etc/wifi/buildin/ is not regular file
[ 249.356794] dhdsdio_download_nvram: Open nvram file failed /vendor/etc/wifi/buildin/
[ 249.393474] wifi_platform_set_power = 0
[ 249.402391] wl_android_wifi_on: Failed
[ 249.406191] dhd_open : wl_android_wifi_on failed (-35)
[ 249.418595] wl_android_wifi_off in 1
[ 249.422318] wl_android_wifi_off in 2: g_wifi_on=0, on_failure=1
[ 249.438210] wifi_platform_set_power = 0
[ 249.447273] wl_android_wifi_off out
[ 254.404525] wl_android_wifi_on in 1
[ 254.413091] wl_android_wifi_on in 2: g_wifi_on=0
[ 254.413151] wifi_platform_set_power = 1
[ 254.423994] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 254.688182] aml_wifi wifi: [extern_wifi_set_enable] WIFI Enable! 486
[ 255.397028] dhd_conf_read_config: Ignore config file /vendor/etc/wifi/buildin/config.txt
[ 255.399715] Final fw_path=/vendor/etc/wifi/buildin/fw_bcm40183b2.bin
[ 255.411161] Final nv_path=/vendor/etc/wifi/buildin/
[ 255.411204] Final clm_path=/vendor/etc/wifi/buildin/clm.blob
[ 255.417134] Final conf_path=/vendor/etc/wifi/buildin/config.txt
[ 255.424798] dhd_os_open_image1: /vendor/etc/wifi/buildin/fw_bcm40183b2.bin (239507 bytes) open success
[ 255.517096] dhd_os_open_image1: /vendor/etc/wifi/buildin/ is not regular file
[ 255.518769] dhdsdio_download_nvram: Open nvram file failed /vendor/etc/wifi/buildin/
[ 255.555720] wifi_platform_set_power = 0
[ 255.564297] wl_android_wifi_on: Failed
[ 255.568270] dhd_open : wl_android_wifi_on failed (-35)
[ 255.580610] wl_android_wifi_off in 1
[ 255.584388] wl_android_wifi_off in 2: g_wifi_on=0, on_failure=1
[ 255.600424] wifi_platform_set_power = 0
[ 255.609318] wl_android_wifi_off out:/vendor/etc/dropbear # dmesg | grep chip
[ 0.229275] Meson chip version = RevB (21:B - 82:0)
[ 1.114260] hdmitx: system: hdmitx_device.chip_type : 3
[ 1.311177] chip type:0x21
[ 8.557680] The chip is not support hevc encoder
[ 11.167147] F1 signature OK, socitype:0x1 chip:0x4330 rev:0x4 pkg:0x0
[ 11.182077] dhd_conf_set_chiprev: chip=0x4330, chiprev=4
[ 23.107737] F1 signature OK, socitype:0x1 chip:0x4330 rev:0x4 pkg:0x0
[ 34.256672] F1 signature OK, socitype:0x1 chip:0x4330 rev:0x4 pkg:0x0
[ 178.744499] F1 signature OK, socitype:0x1 chip:0x4330 rev:0x4 pkg:0x0
[ 249.254952] F1 signature OK, socitype:0x1 chip:0x4330 rev:0x4 pkg:0x0
[ 255.368989] F1 signature OK, socitype:0x1 chip:0x4330 rev:0x4 pkg:0x0
:/vendor/etc/dropbear # ^C
wifi not working
Regarding ap6330 wifi - I need to make some considerations about it, without a test device it is difficult to create a reasonable update
There are currently 2214 users online. 1 members and 2213 guests.
