Netflix Black logo icon is Mobile version and only requires DRM Widevine L3.
ATV9-MOD-(P212)AMPERE-V3
Originally posted by hannah View Postbumerc
This post is about Netflix (with white Logo) NOT working in my tv box. (I know I am asking for too much now)
I am acutely aware of this issue and am following this post:
https://forum.freaktab.com/forum/tv-...-chinese-boxes
My TV Box: Nexbox A95X 2GB/16GB S905X WIFI AP6330
Rom Installed: ATV9-IMG-DEBUG-AMPERE-AP6330-V3.tar.xz
Working: Netflix App with Black Logo which needs a mouse to work properly.
NOT Working: Netflix App with White Logo
Error Messages:
- When the TV Box Starts this is reported by Netflix
This device is not optimized for Netflix (-14)
- When I click on Netflix App (White Logo) this error message is shown
Error: This version of Netflix app is not compatible with your device (-13)
Happy to provide dmesg or any other logs that may be useful troubleshooting.
Thank you and regards
Hannah
Originally posted by bumerc View PostI think this is an application for licensed devices with an integrated WV1 license. In this case, unfortunately, I cannot help you. Use the application with a dark logo
Next Questions for anyone who may have performed these two actions.
1. How to first unroot this Rom
2. How to install Magisk
Regards
Hannah
bumerc about the OTG port, well is a bit more complicated than just disabled in the uboot.
Since i made the rom to be used in khadas 3º usb port(USB C one) i added a internal compile option to make it always OTG and just ignore the uboot setting.
So unless i compile a new build, its going to be hard to fix.. but not impossible.
On the Android Assistant issue (Voice assist). there is a issue in the new androidtv assist app, just do not update it or if you do just change the system language from english US to english UK and it should work again.
superceleron
I use a standard gxl_p212_v1 u-boot, khadas and aml sources are the same in this regard. However, OTG port does not matter, this is deactivated by default in the kernel device tree source and must be activated before the compilation. In the last two builds I just forgot about this.
Originally posted by dsm150 View PostAbout Google assistant. I noticed that after the update, on the Nvidia shield (2017 android 8.0.1), voice search, searches only in YouTube. After uninstalling the Google update. Searches in all applications.P212(AMPERE) build for all standard S905X devices with Ampak WiFi chips (other WiFi chips on request, I need volunteer testers for this, to create the logs (only via PM)) Based on "IMG DEBUG V3" (https://forum.khadas.com/t/rom-sc-vim1-pie-atv-debug-user-builds-v2-20200130/5284) from superceleron (thanks for your
Originally posted by alex161rus View Post
need to check.
changed. Most buttons should work
[ 671.611492@1] meson-remote c8100580.rc: scancode 80 undefined
[ 671.611599@1] meson-remote c8100580.rc: no valid key to handle
There are currently 2985 users online. 0 members and 2985 guests.
