ATV9-MOD-(P212)AMPERE-V3
bumrec, re-installed your rom, truly a great and fast rom, but encountered the same problems, no otg port nor usb ports functioning, so I was not able to use the usb burning, except by shortening the pins. As for the root, its confusing, on ESexplorer shows rooted but on Xplorer it shows unrooted, but I am sure it is rooted. so my only problem is the usb ports and the otg microusb port, otherwise it is a fantastic rom, so for now I went back to the Xperience rom, while I will continue to monitor this forum for any other developments, maybe someone else with Realtek has the same problem. Thanks again for the help in unbricking my device, but I will never stop testing. Take care and stay safe everyone.
Originally posted by bumerc View Postminonano
Your device does not support OTG and the USB ports can only work in host or device mode. I asked you to post dmesg log.. I can shoot you video with both working USB ports
Wait for another update, I'll put USB into host mode for devices that don't support OTG
Hello bumerc and thanks for this extremely good firmware!
I just discovered your firmware yesterday and installed it via USB on a Mecool M8S Pro+.
I would like to fix the remote and other hardware but I can't even connect via putty. (network error - connection refused )
(even with the very self explanatory pics provided!)
(I've connected numerous times in other devices like Raspberry Pie etc)
I have the right IP address of my Box, the ida_rsa.ppk and filled the root name in the autologin user field...
I can see that you're using Ubuntu but I used a Windows 7 machine with Putty 0.74 64 bits version.
Sorry but are you sure that the provided key works with ATV9-IMG-DEBUG-AMPERE-RTK-V3 version?
Is there something I missed?
Thanks!
alex161rus
try this..
open SSH and follow these steps:
Code:mount -o remount,rw /vendor
Code:cat > /vendor/etc/init/hw/template << EOF on boot insmod /vendor/lib/modules/dhd.ko firmware_path=/vendor/etc/wifi/4354/fw_bcm4354a1_ag.bin nvram_path=/vendor/etc/wifi/4354/nvram_ap6354.txt chown root wifi /sys/module/dhd/parameters/firmware_path chown root wifi /sys/module/bcmdhd/parameters/firmware_path chmod 664 /sys/module/bcmdhd/parameters/firmware_path chmod 664 /sys/module/dhd/parameters/firmware_path EOF
Code:cp /vendor/etc/init/hw/template /vendor/etc/init/hw/init.amlogic.wifi_buildin.rc && sync && rm /vendor/etc/init/hw/template
USB port is fixed, wait for new update..
Originally posted by bumerc View Postalex161rus
try this..
Need to replace strings in init.amlogic.wifi_buildin.rc? I'll do it now
Originally posted by minonano View Post
bumrec, I tried to reload the image again, but could not get the mask mode using the usb burning tool, then i tried to reset the box, now I am in a delema, all I am getting is a loop aroung the boot logo, wont stop or start. Also tried the sd burn, but no luck, just looping aroung the lolgo (superceleron). Any idea what went wwrong as all I did was reset (factory), thanks
There are currently 3249 users online. 0 members and 3249 guests.
