ATV9-MOD-(P212)AMPERE-V3
bumerc, I can confirm it works on my T95m, S905X, 2+8, RTL 8723. Wifi works, did not test bluetooth, original remote works, but the added Mele F10 remote does not, I guess I have to read previounot s pages on how to. Also I have noticed that rom is not rooted, I am correct?
Please confirm, thanks for a great rom.
I forgot to mention that I cannot shut down, but it will always reboot.
Correction, I think the reason the Mele remote does not work is because both usb ports don't work, so the transmitter plug in the usb is ineffective.
So the main problem seem to be the USB ports.
minonano
Hi, thanks for the report, both USB ports work on my test device, otherwise I would not have released the firmware. Plug a USB device into a non-working USB port, execute the dmesg command and send the command output in text form to me via PM.
ROM is rooted.
Shutdown must be activated in droid settings, switching off works with the original remote control
https://forum.freaktab.com/forum/tv-...569#post805569Last edited by bumerc; 18 May 2020, 07:12.
ROM is rooted.
Originally posted by bumerc View Postshort the pins 29-30 and flash the img
Now looking back, maybe my problem was loading your rom over the atvxperience one, instead of over the stock rom, what do you think?
Also the wifi worked immediately, so I didn't use SSH, is that ok?Last edited by minonano; 18 May 2020, 18:05.
Originally posted by minonano View Post
bumrec, it worked but only if i flash the stock rom, tried flashing yours and kept getting errors(sorry i didnt sve them).
There are currently 2295 users online. 0 members and 2295 guests.
