ATV9-MOD-(P212)AMPERE-V3
Originally posted by bumerc View Postwell, but without the log of the original bootloader I can’t do anything. Look in the forum how to make TTL-LogAttached FilesLast edited by firmtech; 25 April 2020, 17:37.
Back up and running. Used serial connection to fix. Created an sd card with known working ROM using Burn Card Maker. Connect serial adapter using GND RX TX terminals on s905x. TX from serial adapter goes to RX on s905x, RX from serial adapter goes to TX on s905x board. Open Putty, hit enter before kernel locks up box. This gives a working prompt in terminal. Type sdc_burn aml_sdc_burn.ini it flashes known good rom. Reboot and back up and running. Hopefully this will help others. Sagert, running your ROM again!
For AP6330 devices owners, please test and leave a feedback.
- Kernel
- dtb
- dhd module
- vendor partition
were recompiled from the source code and completely exchanged.
(WiFi FW 40143 added as default)
ATV9-IMG-DEBUG-AMPERE-AP6330-V3
firmtech
You could also test the new kernel..
To update from the SD card, a simple "run update" in the u-boot terminal is sufficient
Originally posted by firmtech View Post
I am able to output the serial data. Stops at loading the kernel. Maybe there is a glimmer of hope. I also have the original backup made with twrp which includes the boxes original boot.emmc.win file. Just not sure how to write data in serial mode.
Originally posted by bumerc View PostFor AP6330 devices owners, please test and leave a feedback.
- Kernel
- dtb
- dhd module
- vendor partition
Thank you
Work Done:
- My TV Box: Nexbox A95X 2GB/16GB S905X WIFI AP6330
- Downloaded this rom:
- Burn with USB Burning Tool and it was a success
- Fix remote with this instruction
https://forum.freaktab.com/forum/tv-...329#post803329
Issue: Wifi Does NOT work
Diagnostic output via adb:
Code:C:\opt\adb>adb shell ampere:/ # dmesg | grep chip [ 0.227064] Meson chip version = RevB (21:B - 82:0) [ 1.149050] hdmitx: system: hdmitx_device.chip_type : 3 [ 1.345948] chip type:0x21 [ 7.194370] The chip is not support hevc encoder [ 9.977097] F1 signature OK, socitype:0x1 chip:0x4330 rev:0x4 pkg:0x0 [ 9.992194] dhd_conf_set_chiprev: chip=0x4330, chiprev=4 ampere:/ # dmesg | grep wifi [ 0.000000] Kernel command line: init=/init console=ttyS0,115200 no_console_suspend earlycon=aml_uart,0xc81004c0 ramoops.pstore_en=1 ramoops.record_size=0x8000 ramoops.console_size=0x4000 otg_device=1 reboot_mode_android=normal androidboot.selinux=permissive logo=osd1,loaded,0x3d800000,1080p60hz maxcpus=4 vout=1080p60hz,enable hdmimode=1080p60hz frac_rate_policy=1 cvbsmode=576cvbs hdmitx=,444,8bit cvbsdrv=0 irq_check_en=0 androidboot.firstboot=0 jtag=apao androidboot.veritymode=enforcing androidboot.hardware=amlogic page_trace=on androidboot.rpmb_state=0 androidboot.serialno=1234567890 androidboot.wificountrycode=US ro rootwait skip_initramfs androidboot.dtbo_idx=0 --cmdline root=/dev/mmcblk0p18 buildvariant=userdebug [ 1.594791] wifi: power_on_pin_OD = 0; [ 1.597192] aml_wifi wifi: [wifi_dev_probe] no power_on_pin2 [ 1.603098] aml_wifi wifi: [pwm_double_channel_conf_dt] wifi pwm dt ok [ 1.609819] aml_wifi wifi: [pwm_double_channel_conf] wifi pwm conf ok [ 1.616415] aml_wifi wifi: [wifi_dev_probe] dhd_static_buf setup [ 1.636623] aml_wifi wifi: [wifi_dev_probe] interrupt_pin=487 [ 1.642609] aml_wifi wifi: [wifi_dev_probe] irq_num=0, irq_trigger_type=1 [ 1.649570] aml_wifi wifi: [wifi_dev_probe] power_on_pin=486 [ 1.655459] aml_wifi wifi: [wifi_dev_probe] clock_32k_pin=0 [ 1.661472] aml_wifi wifi: [wifi_setup_dt] wifi_setup_dt [ 1.666846] aml_wifi wifi: [wifi_setup_dt] irq num is:(64) [ 1.672454] aml_wifi wifi: [wifi_setup_dt] interrupt_pin(487) [ 1.678386] aml_wifi wifi: [wifi_setup_dt] power_on_pin(486) [ 8.968282] dhd_wifi_platform_load: Enter [ 8.977354] wifi_platform_set_power = 1 [ 8.986756] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486 [ 9.194503] aml_wifi wifi: [extern_wifi_set_enable] WIFI Enable! 486 [ 9.703353] wifi_platform_bus_enumerate device present 1 [ 10.232545] wifi_platform_set_power = 0 ampere:/vendor/etc/wifi # ls -l total 12 drwxr-xr-x 2 root shell 4096 2020-04-26 06:36 40183 -rw-r--r-- 1 root root 106 2020-04-26 06:36 p2p_supplicant_overlay.conf -rw-r--r-- 1 root root 81 2020-04-26 06:36 wpa_supplicant.conf ampere:/vendor/etc/wifi #
Regards
Hannah
Here is the required output via adb:
Code:ampere:/vendor/etc/wifi # lsmod Module Size Used by dhd 1327104 0 encoder 45056 0 amvdec_avs2 176128 0 amvdec_vp9 139264 0 amvdec_vc1 49152 0 amvdec_real 32768 0 amvdec_mmpeg4 32768 0 amvdec_mpeg4 49152 0 amvdec_mmpeg12 36864 0 amvdec_mpeg12 81920 0 amvdec_mmjpeg 24576 0 amvdec_mjpeg 32768 0 amvdec_h265 126976 0 amvdec_h264mvc 49152 0 amvdec_mh264 147456 0 amvdec_h264 114688 0 amvdec_avs 57344 0 stream_input 155648 10 amvdec_avs2,amvdec_vp9,amvdec_real,amvdec_mmpeg12,amvdec_mpeg12,amvdec_h265,amvdec_h264mvc,amvdec_mh264,amvdec_h264,amvdec_avs decoder_common 151552 17 encoder,amvdec_avs2,amvdec_vp9,amvdec_vc1,amvdec_real,amvdec_mmpeg4,amvdec_mpeg4,amvdec_mmpeg12,amvdec_mpeg12,amvdec_mmjpeg,amvdec_mjpeg,amvdec_h265,amvdec_h264mvc,amvdec_mh264,amvdec_h264,amvdec_avs,stream_input firmware 24576 18 encoder,amvdec_avs2,amvdec_vp9,amvdec_vc1,amvdec_real,amvdec_mmpeg4,amvdec_mpeg4,amvdec_mmpeg12,amvdec_mpeg12,amvdec_mmjpeg,amvdec_mjpeg,amvdec_h265,amvdec_h264mvc,amvdec_mh264,amvdec_h264,amvdec_avs,stream_input,decoder_common media_clock 36864 11 encoder,amvdec_avs2,amvdec_vp9,amvdec_mpeg12,amvdec_h265,amvdec_mh264,amvdec_h264,amvdec_avs,stream_input,decoder_common,firmware tb_detect 20480 0 mali 290816 31 ampere:/vendor/etc/wifi #
Originally posted by bumerc View Postok, please attach the full dmesg log in a text file
Code:C:\opt\adb>adb shell dmesg > dmesg
replace the vendor partition
repack the aml_package _ *. img and try again
edit: or update via vecovery: vendor.zipLast edited by bumerc; 25 April 2020, 23:11.
There are currently 2611 users online. 1 members and 2610 guests.
