But I don't see an SDcard under mounts.. Did you insert the SDcard into the cardreader of your box?
ATV9-MOD-(P212)AMPERE-V3
Originally posted by bumerc View Postwrong, you shouldn't take the second command 1:1, it's just an example.
I do not have any experience with putty, but it is only attempts to change the remote control file. I needed more explanation and clarification in order to be able to do that,i nsert the SDcard in tv box.
Thank you.
Originally posted by Leiden View PostI do not have any experience with putty, but it is only attempts to change the remote control file. I needed more explanation and clarification in order to be able to do that,i nsert the SDcard in tv box.
Thank you.
Originally posted by Leiden View PostMy problem is just replacing the remote file, my box is s905x
thank you
2. Copy aml_upgrade_package.img to ~/afck/ingredients/
3. Extract the aml_upgrade_package.img
Code:cd ~/afck
Code:export MAKEFLAGS='--no-print-directory'
Code:make mod-unpack
5. Recompile the vendor partition
Code:make mod-vendor
Code:make mod-IMG
7. Install aml_upgrade_package.img on your device and enjoy itLast edited by bumerc; 16 May 2020, 19:50.
also don't werk ,nothing works through USB.
USB port (OTG) trouble has been fixed. Wait for update!
OTG
[ 182.456056@0] usb 1-2: new high-speed USB device number 4 using xhci-hcd
[ 182.619087@0] usb-storage 1-2:1.0: USB Mass Storage device detected
[ 182.688613@0] scsi host0: usb-storage 1-2:1.0
[ 126.692084@0] usb 1-1: new high-speed USB device number 3 using xhci-hcd
[ 126.838183@0] usb-storage 1-1:1.0: USB Mass Storage device detected
[ 126.839962@0] scsi host0: usb-storage 1-1:1.0
There are currently 1578 users online. 0 members and 1578 guests.
