ATV9-MOD-(P212)AMPERE-V3
Originally posted by bumerc View PostYou may only view thumbnails in this gallery. This gallery has 2 photos.2 Photos
Hello bumerc
Thank you for making an ATV 9 rom for s905x and wifi AP6330.
This is my TV Box: Nexbox A95X 2GB/16GB S905X WIFI AP6330
pcbboard picture: https://ibb.co/2N4sPT4
I have installed your rom.
Working: LAN, BT, 1st USB Port (and not the 2nd USB Port)
Not Working: Wifi, Remote. (I have applied your wifi fix via ssh)
Following is the work done via ssh.
:/vendor/etc/dropbear #
cd /vendor/etc/wifi/buildin
mount -o rw,remount /vendor
cp -a config_6330.txt config.txt
reboot
I note the the following: (file size is 0 byte)
:/vendor/etc/wifi/buildin # ls -l
-rw-r--r-- 1 root root 0 2020-04-23 21:17 config_6330.txt
Diagnostic output of these two commands:
dmesg | grep chip
dmesg | grep wifi
130|:/vendor/etc/wifi/buildin # dmesg | grep chip
[ 0.229092] Meson chip version = RevB (21:B - 82:0)
[ 1.114130] hdmitx: system: hdmitx_device.chip_type : 3
[ 1.311043] chip type:0x21
[ 9.526795] The chip is not support hevc encoder
[ 12.145603] F1 signature OK, socitype:0x1 chip:0x4330 rev:0x4 pkg:0x0
[ 12.160616] dhd_conf_set_chiprev: chip=0x4330, chiprev=4
[ 24.130867] F1 signature OK, socitype:0x1 chip:0x4330 rev:0x4 pkg:0x0
1|:/vendor/etc/wifi/buildin # dmesg | grep wifi
[ 0.000000] Kernel command line: init=/init console=ttyS0,115200 no_console_suspend earlycon=aml_uart,0xc81004c0 ramoops.pstore_en=1 ramoops.record_size=0x8000 ramoops.console_size=0x4000 otg_device=1 reboot_mode_android=normal androidboot.selinux=permissive logo=osd1,loaded,0x3d800000,1080p60hz maxcpus=4 vout=1080p60hz,enable hdmimode=1080p60hz frac_rate_policy=1 cvbsmode=576cvbs hdmitx=,444,8bit cvbsdrv=0 irq_check_en=0 androidboot.firstboot=0 jtag=apao androidboot.veritymode=enforcing androidboot.hardware=amlogic page_trace=on androidboot.rpmb_state=0 androidboot.serialno=1234567890 androidboot.wificountrycode=US ro rootwait skip_initramfs androidboot.dtbo_idx=0 vmalloc=512m --cmdline root=/dev/mmcblk0p18 buildvariant=userdebug
[ 1.551588] wifi: power_on_pin_OD = 0;
[ 1.553995] aml_wifi wifi: [wifi_dev_probe] no power_on_pin2
[ 1.559943] aml_wifi wifi: [pwm_double_channel_conf_dt] wifi pwm dt ok
[ 1.566577] aml_wifi wifi: [pwm_double_channel_conf] wifi pwm conf ok
[ 1.573240] aml_wifi wifi: [wifi_dev_probe] dhd_static_buf setup
[ 1.593470] aml_wifi wifi: [wifi_dev_probe] interrupt_pin=487
[ 1.599375] aml_wifi wifi: [wifi_dev_probe] irq_num=0, irq_trigger_type=1
[ 1.606402] aml_wifi wifi: [wifi_dev_probe] power_on_pin=486
[ 1.612236] aml_wifi wifi: [wifi_dev_probe] clock_32k_pin=0
[ 1.618268] aml_wifi wifi: [wifi_setup_dt] wifi_setup_dt
[ 1.623703] aml_wifi wifi: [wifi_setup_dt] irq num is69)
[ 1.629216] aml_wifi wifi: [wifi_setup_dt] interrupt_pin(487)
[ 1.635181] aml_wifi wifi: [wifi_setup_dt] power_on_pin(486)
[ 11.095015] dhd_wifi_platform_load: Enter
[ 11.106263] wifi_platform_set_power = 1
[ 11.121724] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 11.338372] aml_wifi wifi: [extern_wifi_set_enable] WIFI Enable! 486
[ 11.848538] wifi_platform_bus_enumerate device present 1
[ 12.406456] wifi_platform_set_power = 0
[ 23.073801] wl_android_wifi_on in 1
[ 23.078417] wl_android_wifi_on in 2: g_wifi_on=0
[ 23.083081] wifi_platform_set_power = 1
[ 23.092594] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 23.324458] aml_wifi wifi: [extern_wifi_set_enable] WIFI Enable! 486
[ 24.145729] dhd_conf_read_config: Ignore config file /vendor/etc/wifi/buildin/config.txt
[ 24.148455] Final fw_path=/vendor/etc/wifi/buildin/fw_bcm40183b2.bin
[ 24.158094] Final nv_path=/vendor/etc/wifi/buildin/
[ 24.160125] Final clm_path=/vendor/etc/wifi/buildin/clm.blob
[ 24.166547] Final conf_path=/vendor/etc/wifi/buildin/config.txt
[ 24.176067] dhd_os_open_image1: /vendor/etc/wifi/buildin/fw_bcm40183b2.bin (239507 bytes) open success
[ 24.318333] dhd_os_open_image1: /vendor/etc/wifi/buildin/ is not regular file
[ 24.320016] dhdsdio_download_nvram: Open nvram file failed /vendor/etc/wifi/buildin/
[ 24.362685] wifi_platform_set_power = 0
[ 24.370452] wl_android_wifi_on: Failed
[ 24.374316] dhd_open : wl_android_wifi_on failed (-35)
[ 24.385213] wl_android_wifi_off in 1
[ 24.389470] wl_android_wifi_off in 2: g_wifi_on=0, on_failure=1
[ 24.408377] wifi_platform_set_power = 0
[ 24.420056] wl_android_wifi_off out
[ 1914.689716] wl_android_wifi_on in 1
[ 1914.689718] wl_android_wifi_on in 2: g_wifi_on=0
[ 1914.689722] wifi_platform_set_power = 1
[ 1914.689758] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 1914.889810] aml_wifi wifi: [extern_wifi_set_enable] WIFI Enable! 486
[ 1915.535905] dhd_conf_read_config: Ignore config file /vendor/etc/wifi/buildin/config.txt
[ 1915.543429] Final fw_path=/vendor/etc/wifi/buildin/fw_bcm40183b2.bin
[ 1915.549793] Final nv_path=/vendor/etc/wifi/buildin/
[ 1915.554778] Final clm_path=/vendor/etc/wifi/buildin/clm.blob
[ 1915.560611] Final conf_path=/vendor/etc/wifi/buildin/config.txt
[ 1915.567451] dhd_os_open_image1: /vendor/etc/wifi/buildin/fw_bcm40183b2.bin (239507 bytes) open success
[ 1915.615445] dhd_os_open_image1: /vendor/etc/wifi/buildin/ is not regular file
[ 1915.617278] dhdsdio_download_nvram: Open nvram file failed /vendor/etc/wifi/buildin/
[ 1915.653663] wifi_platform_set_power = 0
[ 1915.662586] wl_android_wifi_on: Failed
[ 1915.666574] dhd_open : wl_android_wifi_on failed (-35)
[ 1915.678978] wl_android_wifi_off in 1
[ 1915.682786] wl_android_wifi_off in 2: g_wifi_on=0, on_failure=1
[ 1915.698613] wifi_platform_set_power = 0
[ 1915.707628] wl_android_wifi_off out
Please help me to have a working Wifi.
Thank you
Hannah
Hello bumerc
I now have rectified my mistake and copied the correct file. And wifi is NOT working
cp -a config_6335.txt config.txt
reboot
corresponding dmesg output:
:/vendor/etc/dropbear # dmesg | grep chip
[ 0.229499] Meson chip version = RevB (21:B - 82:0)
[ 1.119001] hdmitx: system: hdmitx_device.chip_type : 3
[ 1.315935] chip type:0x21
[ 8.031783] The chip is not support hevc encoder
[ 10.696865] F1 signature OK, socitype:0x1 chip:0x4330 rev:0x4 pkg:0x0
[ 10.711865] dhd_conf_set_chiprev: chip=0x4330, chiprev=4
[ 22.352764] F1 signature OK, socitype:0x1 chip:0x4330 rev:0x4 pkg:0x0
[ 63.392345] F1 signature OK, socitype:0x1 chip:0x4330 rev:0x4 pkg:0x0
:/vendor/etc/dropbear # dmesg | grep wifi
[ 1.556607] wifi: power_on_pin_OD = 0;
[ 1.559003] aml_wifi wifi: [wifi_dev_probe] no power_on_pin2
[ 1.564954] aml_wifi wifi: [pwm_double_channel_conf_dt] wifi pwm dt ok
[ 1.571591] aml_wifi wifi: [pwm_double_channel_conf] wifi pwm conf ok
[ 1.578232] aml_wifi wifi: [wifi_dev_probe] dhd_static_buf setup
[ 1.598470] aml_wifi wifi: [wifi_dev_probe] interrupt_pin=487
[ 1.604394] aml_wifi wifi: [wifi_dev_probe] irq_num=0, irq_trigger_type=1
[ 1.611384] aml_wifi wifi: [wifi_dev_probe] power_on_pin=486
[ 1.617276] aml_wifi wifi: [wifi_dev_probe] clock_32k_pin=0
[ 1.623280] aml_wifi wifi: [wifi_setup_dt] wifi_setup_dt
[ 1.628674] aml_wifi wifi: [wifi_setup_dt] irq num is69)
[ 1.634280] aml_wifi wifi: [wifi_setup_dt] interrupt_pin(487)
[ 1.640197] aml_wifi wifi: [wifi_setup_dt] power_on_pin(486)
[ 9.700867] dhd_wifi_platform_load: Enter
[ 9.709944] wifi_platform_set_power = 1
[ 9.719185] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 9.927824] aml_wifi wifi: [extern_wifi_set_enable] WIFI Enable! 486
[ 10.441619] wifi_platform_bus_enumerate device present 1
[ 10.952548] wifi_platform_set_power = 0
[ 21.399190] wl_android_wifi_on in 1
[ 21.402945] wl_android_wifi_on in 2: g_wifi_on=0
[ 21.407621] wifi_platform_set_power = 1
[ 21.416909] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 21.636701] aml_wifi wifi: [extern_wifi_set_enable] WIFI Enable! 486
[ 22.368021] dhd_os_open_image1: /vendor/etc/wifi/buildin/config.txt (47 bytes) open success
[ 22.400056] Final fw_path=/vendor/etc/wifi/buildin/fw_bcm40183b2.bin
[ 22.401028] Final nv_path=/vendor/etc/wifi/buildin/
[ 22.406066] Final clm_path=/vendor/etc/wifi/buildin/clm.blob
[ 22.413272] Final conf_path=/vendor/etc/wifi/buildin/config.txt
[ 22.423649] dhd_os_open_image1: /vendor/etc/wifi/buildin/fw_bcm40183b2.bin (239507 bytes) open success
[ 22.566834] dhd_os_open_image1: /vendor/etc/wifi/buildin/ is not regular file
[ 22.568538] dhdsdio_download_nvram: Open nvram file failed /vendor/etc/wifi/buildin/
[ 22.606024] wifi_platform_set_power = 0
[ 22.614048] wl_android_wifi_on: Failed
[ 22.617923] dhd_open : wl_android_wifi_on failed (-35)
[ 22.630510] wl_android_wifi_off in 1
[ 22.634135] wl_android_wifi_off in 2: g_wifi_on=0, on_failure=1
[ 22.650001] wifi_platform_set_power = 0
[ 22.659016] wl_android_wifi_off out
[ 62.190715] wl_android_wifi_on in 1
[ 62.194781] wl_android_wifi_on in 2: g_wifi_on=0
[ 62.201102] wifi_platform_set_power = 1
[ 62.209324] aml_wifi wifi: [extern_wifi_set_enable] WIFI Disable! 486
[ 62.495221] aml_wifi wifi: [extern_wifi_set_enable] WIFI Enable! 486
[ 63.506758] dhd_os_open_image1: /vendor/etc/wifi/buildin/config.txt (47 bytes) open success
[ 63.506815] Final fw_path=/vendor/etc/wifi/buildin/fw_bcm40183b2.bin
[ 63.506817] Final nv_path=/vendor/etc/wifi/buildin/
[ 63.506818] Final clm_path=/vendor/etc/wifi/buildin/clm.blob
[ 63.506820] Final conf_path=/vendor/etc/wifi/buildin/config.txt
[ 63.508153] dhd_os_open_image1: /vendor/etc/wifi/buildin/fw_bcm40183b2.bin (239507 bytes) open success
[ 63.673381] dhd_os_open_image1: /vendor/etc/wifi/buildin/ is not regular file
[ 63.673386] dhdsdio_download_nvram: Open nvram file failed /vendor/etc/wifi/buildin/
[ 63.673659] wifi_platform_set_power = 0
[ 63.673664] wl_android_wifi_on: Failed
[ 63.673668] dhd_open : wl_android_wifi_on failed (-35)
[ 63.673679] wl_android_wifi_off in 1
[ 63.673681] wl_android_wifi_off in 2: g_wifi_on=0, on_failure=1
[ 63.673798] wifi_platform_set_power = 0
[ 63.673802] wl_android_wifi_off out
Thank you in advance.
Hannah
Originally posted by hannah View PostNot Working:Remote.
/vendor/etcAttached Files
Originally posted by alex161rus View Postreplace file for nexbox s95x
/vendor/etc
hannah@DESKTOP-00V2F0C:/mnt/c/opt/rom/ATV9-IMG-DEBUG-AMPERE-V3$ scp -i id_rsa remote_ir_nexbox_a95x_s905x/remote1.tab [email protected]:/vendor/etc
* Welcome to ampere SSH-server! *
sh: scp: not found
lost connection
scp is failing to copy as it does not exist in the tvbox. Perhaps I need to push it via adb.
Shall try later.
Wifi is NOT working.
Hannah
As for ap6330, it was not buildin wifi and was optionally added. The nvram file is not loading at the moment, I have to find out why
EDIT: I found the bug, but this requires full recompilation of the kernel and wifi drivers. If I find time, I try to fix thisLast edited by bumerc; 24 April 2020, 09:39.
At this stage only Wifi NOT working.
/vendor/etc
Here are the commands run via adb:
Code:C:\opt\adb>adb connect 192.168.0.101:5555 C:\opt\adb>adb root <------------- must start adb as root otherwise all below commands will fail C:\opt\adb>adb shell mount -o rw,remount /vendor C:\opt\adb>adb push remote1.tab /vendor/etc remote1.tab: 1 file pushed. 0.1 MB/s (2143 bytes in 0.033s)
Originally posted by bumerc View PostAs for ap6330, it was not buildin wifi and was optionally added. The nvram file is not loading at the moment, I have to find out why
There are currently 2088 users online. 0 members and 2088 guests.
