This one is better for me than the previous one, and the main difference is that I got a workaround to make wifi work on reboot, now the wifi module can be loaded or unloaded all the times you want, and you can reboot the stick and got wifi working. A part of the workaround in kernel and the other part is in Petrus Reboot.apk
Petrus made a Reboot.apk that power off wifi before reboot or power off the stick, you need to use this apk to reboot the stick, if not you will get a bootloop and you need to power off the device to break it. More info here. Thanks a lot to Petrus for the apk and to thafath for give me some new info (we never stop to learn
Features:
-Workaround to make wifi work on reboot.
-A lot of kernels with overclock and without it, 720p and 1080p. (thanks to phjanderson for marvin tool, it makes a lot easier to make a bucnh of kernels in a row.
-Vsinc video fix in all the kernels.(Thanks to sam321 and phjanderson)
-Rooted and SuperSU installed.
-Full Busybox installed. To have some linux console functionality from android.
-Some apps are now installed like user app instead of system app, if you don’t use them you can erase them easy. Those apps installed by default are:
-SuperSu. To manage root in your device.
-Reboot.apk by Petrus, with this app you can power off the stick, reboot to recovery or bootloader or simply do a normal reboot. Thanks a lot to him. reboot.apk by Petrus
-Terminal emulator: With this you can use a command shell.
-Chrome and Firefox.
-Null imput keyboard. Disabled by default. If you use a remote keyboard it will be very useful.
-AdAway. An app that block most of the advertising.
-Gmail.
-Google search and google calendar.
-Fancy widget.
-Rockchip explorer.
-RKGameControl.
-Youtube.
-Wifidisplay
If you don’t want some of them, only erase them from settings/app. All of them are user apps.
-flash_image and dump_image binary. Flash img files or backup your system look here for more info
- cwm installed in the very first boot automatically. So you will have a very functional recovery with backup and install roms in a easy way.
- Full init.d support. with this you can run some scripts at start-up. Thanks to Finless and 900Supersport they give me the instructions to make it work.
Some functionalities that are not tested (I have not the equip to test them):
-HDMI passthrough
-Bluetooth
UPDATED TO 1.5A.
-BUG IN BUSYBOX SYMLINKS FIXED.
-Some build.prop changes.
ONLY IF YOU HAVE THE 1.5 INSTALLED: DOWNLOAD http://www.freak-tab.de/leolas/QX1/l....5a-update.zip
Download it, reboot to cwm recovery (you can use Reboot.apk by Petrus to do this), and install the file from cwm. NO NEED WIPE DATA. Only install zip from sdcard and select leolas-qx1-1.5a-update.zip, the reboot the stick.
There is 2 ways to install the rom:
Using cwm recovery.
If you have cwm installed then you need to download: http://www.freak-tab.de/leolas/QX1/l...l-QX1-1.5a.zip
unzip it and you got 2 files:
leolasROM-qx1-1.5.zip: this is the cwm zip, to install it from recovery. It comes with a kernel only overclocked in ram, 720p and wifi workaround, if you want other kernel look at:
kernel_leolas_qx1.zip: Inside this zip are a lot of kernels, with different overclock or not, 1080p or 720p, wifi workaround or not, each img file has a txt file explaining the features of each kernel.
Select one of them, rename it to kernel.img and add to leolasROM-qx1-1.5.zip or flash it latter using the instructions in:http://www.freaktab.com/showthread.p...stallable-zips
Once you have the cwm zip prepared:
Enter in cwm recovery.
Select wipe data/factory reset and yes.
Select mount and storage.
Select format boot and yes.
Select format system and yes.
Select format kernel and yes.
Select Go back.
Select install zip from sdcard.
Select leolasROM-QX1-1.5.zip depending where you copied it in internal or external sdcard.
Reboot the stick.
Enjoy the rom.
Using rkandroidtool 1.37.
This way will erase your internal sdcard. so make a backup before flash it.
Download: http://www.freak-tab.de/leolas/QX1/leolas-QX1-1.5a.zip
Unzip it.
Run rkandroidtool.exe
disconnect from PSU the stick, push the reset button and while it is pressed connect the microusb to the OTG port:
Look at this image.
1. Check that Found RKAndroid Loader Rock Usb appears
2. Erase IDB
3. Select the amount of nand you want to install apps. (Default 2Gb and recommended
4. Select the kernel .img you want to flash, with each kernel there is a .txt explaining the kernel features.
5. Run and wait until the process finish, the stick will reboot, I suggest you wait a few minutes (5 or so) before unplug it from the microusb.
6. Enjoy the rom
After install the rom.
In both options, the first boot will last some time, please wait patiently, it will not last more than 10 minutes (usually only a few, 2 or 3)
On the first boot it will install automatically some apps and a new cwm recovery so wait 5 minutes or so until it install all. (All this announced times are in the worst case, usually in 3-4 minutes the whole process will be finished
I checked it for a few days before publish it, but for sure that there are improvements, bugs to solve or request that you will ask, like gameloft fix, I am working on it, but when I got it I will launch a cwm zip to fix it.
Please feedback and I will try to solve the demands.
Remember that flashing a rom always is a little risk. Do it under your responsibility, I will try to help if you brick your device, I never got great problems flashing any roms, but you must know that
All corrections and suggestions are welcome. I hope you enjoy this rom.
