Pipo M9 Max RileyROM 2.1
    Since you are rooted, you can use a root explorer app to find the bootanimation.zip in system/media.
    Just extract one of the png files from the zip file and place it in your pictures folder.
    I'm glad you are having a good experience.
    I have to spend the day in the hospital tomorrow as well...but only because I work there. Good luck with your dialysis.
    Randy
      Ok, i'm here, and the wifi works verry well, the page's load fast and locking on to the site was quick.
      You know i've read (here on FT) that the pipo only charged up using the charger that plugs into the tablet, well my tab came with a charging cable, has the same end on the cable as the power charger, but it can be pluged into the USB port on my computer and charge there. Also the case that came with the tab has a verry good keyboard, however it is hard to use while lying in bed, it needs to be setting on a flat surface, all in all, riley this rom works verry good, I will be using it for a while and I will let the fourm know if something goes wrong.
      Thanks for your work;
      ghforlife
        ghforlife
        Your tablet came with a case with inbuilt keyboard?
        May i ask from where did u order it?
        You can PM me, thank you.
          Originally posted by Falon View Post
          I wrote to them too and i had same answer.
          On faceboook Pipo replay:
          I will try this later, and ask the technicist's idea about this.
          I try to made video and send to Pipo.
          Did you managed to record the video? Because I received a message from Pipo support that they don't see the stuttering :-(
            Guys,where do you communicate with pipo on fb,I want to point them on the bugs I've found in their kernel.
            https://www.paypal.com/en_US/i/btn/x-click-but11.gif
              After service problem (English): [email protected]
                You can include also
                Sharon.chen@pipo.com.cn
                ben.lai@pipo.com.cn
                They answered me several month ago regarding firmware upgrades
                  This is for "babyboy3265": Yes, I my pipo did come with a case with a keyboard, it was one of those "Xmas" things, or at least that is what my wife told me, she's the one who got it for me, and she bought it from "pipomall.com" it cost her "$298.97 US, which was a lot considering the change from Canada's dollars to US, this all they take. Keyboard Case is ok, but it's hard for me to hold on my lap while on Dialysis, the one case I bought, at Wal-Mart, was way better. I'm sorry that I answered you this way, but I'm having problems with this site, I cannot replay to a thread unless I do it this way, I'm having to sign on 2 to 3 times and I've had to change my password 3 times, something about security< I have emailed the Adman about it but no reply from them only a new password. As you can see, I can't even do a new pargraf................
                    one simple question
                    DOES SKYPE CALLS WORK (AUDIO AND VIDEO)
                    does it crash like before
                      Originally posted by mite_jan View Post
                      one simple question
                      Works for me on 2.0 & 2.1
                        What type of bug did you find?
                          I'm send them video and they answer:
                          Hello,
                          I watched the video several times, I am afraid I have no idea about this.
                          I watched another videos of 720P and 1080P, I didn't find big difference between them.
                          I asked our technicist about this, I am afraid I don't find the solution.
                          Best regards,
                          Anna
                          PiPo Technology Co,.Ltd(digisino group)
                          Anna see no difference because sha has good device. We have bad device and they do nothing about this.
                            Big Thanks
                            Randy, you never cease to amaze us. I flashed this with the 10/30/2013 kernel and am trying it now. Looks promising. I will give my update soon.
                            Thanks and kudos for your hard work.
                              They have facebook page "Pipo tablet"
                              https://www.facebook.com/pipocn?fref=ts
                                I opened explorer this is all I have, and I could not find the file. what now!
