A95X F4 "AMLogic 905X4"
Originally posted by ushilives View Post
How did you update your box to android 11? The online updater says it is up to date on android 10
You have first generation a95xf4
Same as mine
There is no update to 11
They made new China boxes a95xf4 with Android 11 and different wifi modules.
So you were forced to buy new China Box.
If you want to Test Coreelec
Flash firmware with Android 11.
You can use the a95xf4 Android 11 firmware
You will have no wifi/bluetooth
Lan will work
And everything else
There are other Android 11 firmware you can test
Same result
No wifi/bluetooth
But ethernet will work
Maybe test Superceleron Tanix X4 V 2.0
Remote control functions from a95xf4 is included
Good luck
Happy Testing
Hi there, thanks for all the amazing contributions here!
I've got an A95X F4, 2GB ram + 100Mb eth version, came with Android 10, following Freddy's help on the CoreElec forum I made some progress.
I managed to flash vendor Android 11 version. The device does not boot to Android 11 but the flashing was enough to overwrite the original locked bootloader in the Android 10 vendor image, this enabled me to boot on sd card but not all images would work, which is why I'm now trying to at least get Android 11 to boot.
So, aml usb burn tool works with most roms I found but now when trying this rom and I have an issue in aml usb burning tool at 5%:
Code:Flash_init uboot/Falsh init and erase/Undefined/undefined 5%
Code:oemcmd [...] Failed at check dts
Do I have to modify the rom with rom kitchen before flashing to adapt for different hardware?
Code:Device_Out_Log:95LErr[usbFlw]remote [Failed at check dts] Device_Out_Log:780LErr[usbFlw]oemcmd[disk_initial 1]=[Failed at check dts] Device_Out_Log:LMsg[usbFlw]stack traceback: Device_Out_Log:LMsg[usbFlw] [string "usb_flow_dnl"]:921: in upvalue 'prERR' Device_Out_Log:LMsg[usbFlw] [string "usb_flow_dnl"]:780: in function <[string "usb_flow_dnl"]:682> Device_Out_Log:LMsg[usbFlw] [C]: in function 'xpcall' Device_Out_Log:LMsg[usbFlw] [string "usb_flow_dnl"]:1010: in main chunk Device_Out_Log:LMsg[usbFlw]FAILURE!! in [TPL] flow(true, nil) Device_Out_Log:LMsg[usbFlw]status,ret,errcode (true,nil, 0x030200ff) [flow]oemcmd[disk_initial 1]=[Failed at check dts]​
I tried with Aml Usb burn tool v3.1.6 and v3.2
Thanks so much for any help!
Welcome to Freaktab!!!
Looks like you are correct
No Android 11 for 2gig version a95xf4
Maybe take box apart
Confirm Ram chip
Ethernet transceiver
Wifi/ bluetooth
CoreElec. dmesg
You already have that in pastebin
Take some pics of board/ both sides
Maybe slimboxtv for Transpeed X4s which is 100M
Will work on your box.
It's just the 2 gig Ram that is issues
I have never flashed a 4gig firmware to 2gig box.
Happy Testing
As for the discussion, you need a new DTS + uboot for A11 work on that device! ye the diference from using 2 or 4gb can be big, it seems its not but it is.
On flash time, the tool and uboot do some checks to see if your device is supported if it does not find that information on both uboot and dts then it refuses to flash it.
I cant remember if i added 2gb support to my rom, i need to check the code!Last edited by superceleron; 29 April 2023, 17:18.
This thread
FergusL.
Now that you know Ram chip ??
These boxes have Android 11 versions with 2/16
Most are DDR3
Tox3lite (ugoos so probs wont)
X96 X4
H96max x4
Hk1 rbox x4s( also different names,transpeed
Transpeed x4 100
Would be better off trying 2 gig versions
Will have varying results
May get lucky and find box that has same wifi/ bluetooth
Good luck
Happy Testing
Guest
3rd place seems good for that box, I was so disappointed with my A95X F4 that I dumped it really fast.
Originally posted by masher17 View Post3rd place seems good for that box, I was so disappointed with my A95X F4 that I dumped it really fast.
New custom firmware from SlimBOXtv https://slimboxtv.ru/a95x-f4/
spdif - stereo only yet (no work DD or DTS)
no logo wifi/lan on front display
have root
other work fine
Originally posted by MaxJumper View PostNew custom firmware from SlimBOXtv https://slimboxtv.ru/a95x-f4/
have root
other work fine
Testing now on A95X F4 Amlogic S905X4
Happy Testing
There are currently 1279 users online. 2 members and 1277 guests.
