A95X F4 "AMLogic 905X4"
    Originally posted by killeriq View Post
    freddy sorry for silly question...but what is the benefit to use other sources (APK Pure,,APK Mirror,Aptoide,Android APK...) then Play Store?
    Hmmmmmmmmmm
    Some benefits are
    Break away from/ Not dependent on Big G,s Monopoly
    Support Open Source Third Party App Developers
    Install Apps Not available from Play Store
    Update Apps PLay Store cant/wont..
    Having More Than one Source is Best for any App can think to Test
    When testing a Box I use PC to download the APK,s / Apps I want to Test/Use on Box
    THen Copy Files To USB DRive
    Then Sideload APK,s / Apps FRom DRive
    Much Faster/ Easier than Sign In Play Store And download /install Apps from there /then Find out App you want is not available
    Also I dont Use Tv Box Browser/Chrome etc.. for Download
    USB Drive way Faster and Portable
    Can bring to Friends House and Sideload APK,s For There Box to Test
    Happy Testing
      got it, thanks...im already downloading APKs which i like and use "X-plore" manager , where i connect to persnal NAS and install from there...
      btw any good Weather app for Android TV?
      Android devices: Minix X7 (gone) , Minix X8-H , MK808b Plus
      Video Out: Benq W1000+ 1080p Projector
      Audio Out: HDMI -> Yamaha RX-V467B + 5.1 Yamaha Speakers
      Remote: Rikomagic MK702 II, Minix NEO M1
      Storage: NAS Zyxel NSA325v2
        weird situation after last update;
        >tried to install "APKPure" from device own "TV Store" and this apk. installed well...
        >for the APKPure; than warning msg appeared ...there is a new version,do you update now?...
        so,I clicked OK button,but fist of all I'v to accpected/confirmed this and a new page opened but I cant click the OK button because of
        this page suddenly closed!!! I tried several times but every time this page turned off! so I cant do it update action WTF
        >finally I'v uninstalled AKPPure apk.!!
        in fact I never need this apk.too
        So,this Box really shity with some of Apk. or might be the reason of Android or this Box really Rooted or not!
        So need another 905X4 Box BUT with very good working Andro OS!!
        we got 4/5 or 6 update by OTA/PC and what have in our hand??
        Another question is for the "CoreELEC" with 905X4???
          Hi Bergamesk
          You are Correct you do not need APKPure
          It reads like You have not set Permissions for APK,s if you are having Problems with some
          By Default Android 10 / Google Play Protect services deny Access/set permissions for Apps installed from Unknown Sources To OFF
          After you install
          Go to App Settings
          At the Bottom you will see
          Permissions
          Exp: most Apps need Access to Storage
          You must check this Box//Allow
          Box is running Smooth
          Not sure about CoreElec for X4
          Happy Testing
            Yesterday I had my USB stick connected and decided to change my wallpaper on the box. To my surprise it also picked up the wallpapers on my USB stick. I now have my custom wallpaper installed .
              Ok i got the firmware update for 20210709 ...awesome!
                all the updates are still without "change list" so what is the benefit?
                  Yesterday I'v tried some of Android Apk.s for Clearance/registy-tool/tweeking etc.,
                  First of all I'v to say that "A95X F4" is not ROOTED!!!
                  above apk.s say that this device non-rooted!
                  So,we cant do it more,almost all Apk.s not worked well as well
                  Now what I do with this shitty Box;only using "Media Player" for my some of recorded-medias and photos thats all
                  Note;KODI(19.1) works w/o any issue and I'v installed many Addons and all are OK such as Seren/4k/Black Lightning/Rogue One
                  and recommended to use with any Debrid Service as well(mine is Real-Debrid and AllDebrid)
                  so,welcome new 905X4 Boxes
                  ignore it this A95X F4!!
                    keep in mind if you connected ext.HDD/USB-disk.... Device system recognize all this connected ext.disks and you will see it all yr contents in your "Screen Saver" section WTF
                    I never seen this weird happen before on any other Boxes!
                    Screen-saver and especially WallPaper section does not worked stable and does not make any seperation for all of this
                    such as;if you click it WallPaper and wanna to change your background;the system gives you all what they have!
                    This Box need a good "custom ROM" plus stable worked Rooted system!
                      Hi Freddy
                      -I did it>>>GPStore;Play Protect;changed to "OFF" now! (before it stay "ON")
                      might be from now on my some of Apk. will work stable(I'm not sure that though)
                      -And this Box NOT Rooted! and or not properly rooted!
                      first of all this Box has to be rooted
                      5 or 6 update came for what???
                      -on the other hand Box running smoothly too
                        a new OTA Updated>>> 20210713 - 100838
                        how many OTA released as I do not count!
                        need properly "Rooted" firmware!
                          We should get ATV, maybe someone will port slimbox ATV rather then having android 10 mobile ROM
                            well Rooted ATV etc.,....
                            awaiting these
                              I also have the newest firmware 20210713 and still no root access as yet
                                If you are adventurous and not scared of bricking box you may try this , do it on your own risk https://androidpctv.com/tutorial-ins...tvbox-amlogic/
