A95X F4 "AMLogic 905X4"
Hi guys
forget/ignore this "Andro-11" f/w and continue with Andro-10
"A95X F4 with Android-10" is over or we can say it bye-bye!!
btw mine is with started two issue when I start the bow
1-opening time before 45/50seconds but now over 1 minute or or!! sometimes its wait 2min or 3min.!!
and sometimes waiting as normal open duration such as 45/50sec.
2-some Apks. freeze or page closed and returned to main menu!!
and of course some other issues too...
Looking a new Box "again" and probably I'll buy once more 905X4
but which BOX??
currently released Tanix X4 with AML905X4 any news for this or comment?
as I know that Android 10/11 Boxes all of them not stable and has many of BUGs etc.,
Andro-9 is more stable though
Guest
but which BOX??
So, the Amlogic 905X4 in my opinion has been a huge letdown so far.
Originally posted by androidboxtv View PostHi
I have been reading about the firmware for the A95X F4 and the wifi chip coming up on the searches is AW 3155-50R but the chip in My box is different but still has 3155
Can i use firmware that is made for AW 3155-50R on My box
Any help appreciated
This is the version i have was purchased early 2021 May/June
Then Later on in 2021 they released New Version with Android 11 and different wifi/ combo chip 3155 and i think there was another?
If you have a newer version is probly best to Test 3155
I have Tested all versions with limited success
** Always know how to UNBRICK your China Box before messing with it
Good Luck
Happy Testing
Originally posted by freddy View Post
The First Boxes released Had Android 10 with wifi/blutooth combo mediatek 7668
Good Luck
Happy Testing
Can you tell me how to unblrick
Also the reason for me finding another firmware is because it does not allow me to see files in my USB hard drive
recognises it when plugged in but cannot see files
i have tried using other file explorers and it can see the files but kodi 19.4 does not
is there any newer firmware on android 11 after 26 November 2021
Originally posted by androidboxtv View Posthave you got the box rooted pls
There was no Root on Android 10 version
I can not remember other versions i tested
I can not tell you how to Unbrick your Box
** Is a Disclaimer/Warning That is universal to all that Test
User Beware
Test At your Own Peril
There is always a chance of Bricking your Box.
If you Brick your Box there will be Help Here At Home
FreakTab
I do not know about other Firmware
Big G search will show
Also
XDA
4pda
Try a different Media Player other than Kodi
VLC
MX Player Pro
etc...
More Good Luck
Happy Testing
Hi
Thanks for the information
whatever file explorer i am using just shows the name of the USB hard drive but does not list the contents
on older andtoid it used to work fine
how can this be fixed
is it a launcher problem or a android firmware problem
Does NTFS USB hard drive work for your ua95x f4 box
Iam currently Testing Superceleron ATV Beta on A95X F4
User Beware
FreakTab
Also
XDA
4pda
VLC
MX Player Pro
etc...
More Good Luck
Happy Testing
I purchace this box before 3 months, suddenly the box has no power, no boot logo, no rgb lights nothing... i tried with new power supply and the problem still exists... any help to get back in life.. If you have any new rom (custom or not) or unbrick how to please provide me... thanks in advance
Testing Coreelec on A95X F4 First Version with 7668 wifi
In anticipation of Superceleron Latest Rom with Dual OS
Reboot to Recovery/Change OS
Have been Testing Coreelec
Strange....
Files Flashed to Box with Android 10 as OS
Regardless of DTB i tried / many
Coreelec would not Boot....
Files Flashed to Box with Android 11 as OS
* Gocast 11 202109061141
ax95x f4 wifi aw 3155
A95X F4 ddr3 4G G10s remote
Factory Tanix X4
Factory X96 X4 Pro
SC ATV V5
SC Nornal V1
Coreelec Boots with success !!!!
Must be something with Android 10
Or Boot load issues..
* Gocast Firmware is Probably Fake Android 11/Also would not boot
Bootloader issues
Happy Testing
There are currently 2553 users online. 0 members and 2553 guests.
