A95X F4 "AMLogic 905X4"
Originally posted by yougz View PostAndroid devices: Minix X7 (gone) , Minix X8-H , MK808b Plus
Video Out: Benq W1000+ 1080p Projector
Audio Out: HDMI -> Yamaha RX-V467B + 5.1 Yamaha Speakers
Remote: Rikomagic MK702 II, Minix NEO M1
Storage: NAS Zyxel NSA325v2
but very difficult!
I tried several times such about one week!
than one day it works!
the problem is connection/recognizing the Box against PC
and also doesnt matter yr PC-OS such Win7 or 8 or 10 !!
OTA is good and OK otherwise its very problematic updating with PC connection
and "nothing changed" after all updates! at least for me that there is no any effective change!
seems that Android-10 system does not worked well with this Box and "ROOT" situation unknown
and need proper Root!
yes bit tricky, but if you have April FW, then OTA doesnt work. After i flash it via PC i was able to get updates via OTAAndroid devices: Minix X7 (gone) , Minix X8-H , MK808b Plus
so,as we understand that first of all you have to flash yr Box with this 26/4 PC-Update
than y will be able to receive OTA updates respectively!
my first experience with this new sOC905X4 on Mecool KM6 Deluxe its not bad but I sold this Box even not liked!
A95X4 my second attempted and seems that I'll sale this unit too! Android-10 kinda not good/compatible and "Root"
is another story!
so shortly what is "905X4"??? its about 10% faster then 905X3 only!
previous model "A95X3" more stable and good with Andro-9
Need more 905X4 Boxes in the market in soon
Rooted+stable working Andro-10(or 11)
Guest
So now mine is set up using the latest firmware 2021-06-16 and working with the 5 GHz WIFI not working bad as long as I don't add or change anything ....lol
I like your enthusiasm about this box, keep our fingers crossed it gets better... I did notice that there is no navigation bar on the bottom like the A95X3 has...
Guest
probably yours were shipped with newer FW...that's why u dont need to bother with PC update.
Anyway I ordered MeCool KM6 Deluxe, most probably will get this A95X F4 away, as i prefer android TV OS on multimedia center, easier/faster to operate
But first want to test both of them...
Also ordered MeCool KD1 TV stickAndroid devices: Minix X7 (gone) , Minix X8-H , MK808b Plus
Originally posted by trebor View PostYES it works
English Instructions included
Supplied by Geekbuying: Similar to previous with some English Instructions Glad to share the firmware for A95X F4 Android 10 Amlogic S905X4 TV BOX (https://www.geekbuying.com/item/A95X-F4-Android-10-Amlogic-S905X4-4GB-64GB-TV-BOX-457384.html?utm_source=freaktab.com&utm_medium=referral&utm_campaign=elaine&utm_term=A
Ok I will try to insist then, if other people have succeeded it is possible.
Originally posted by bergamesk View PostOK but who is the main manufacturer of this "A95X F4"???
Bang/Ali or Geek/Gear etc., they never give us any proper info for firmware or producers!
they just wanna to sell goods!
RESPECT first!
Box looks just like Iron/Iron Plus
Took the plunge and grabbed one.
Have been testing last couple of days...
A95X F4
Your Choice
Your Life
Some things...
Amlogic ADB Tool by Ricky can connect to Box via PC
Did not attempt to Mess with anything
In Reboot Options i did test Reboot
Worked
Tested Reboot to Recovery
Did not work
Boot to recovery(toothpick method)
Many options there...
including Enter Fast boot
So i did
I fastbootd
Bluetooth Pair to phone
Good
Bluetooth pair to Xiaomi Game controller
Good
In regards to Root.....
Strange some apps read as device is rooted/others not
Side load APK,s some apps are automatically sent to system/load as system app
Like Root would do
In Kodi when go to add source
Reads as split screen
Showing Root Side
Its like box is quasi/half rooted
Or something...
More Testing....
"ROOT"
...In regards to Root.....
Strange some apps read as device is rooted/others not ...
seems unknown happen for this??
BUT in fact I never quite install and stable work some of my Apk.s!
There is two reason 1-Android-10 2-Device need worked/stable Root!
>PC f/w update;not easy worked! some of users say without any problem and some of user says always problem and device does not connected!(such as mine)
>My "Screen-saver" does not worked ever!
so,this Box not good not bad at all
and I'm looking another brand/brands "sOC905X4" devices
1 chinese box with S905X4 is good for now (For Me)
In settings under services
Allow APKPure Auto install
Will help with compatibility issues sideload APK,s
Its system app likes to be the Boss
Most APK,s i sideload come from APKPure anyways
Screensaver I never use
However Have installed Hidden Android Settings APK
OLder Version V0.1 by Kasitskyi has no Ads
Newer Version from Playstore/APKPure bloated with Ads....
Both work
Customize Your Pixel.....
There is Screensaver Settings there
Maybe apply and will work for You
In Droid settings
Picture Mode(does it work?)
Have Not Tested
I Mostly Use BlueTooth Game controller and Airmouse to Navigate
Have tested Remote Control Functions
U tube shortcut Key works
Netflix shortcut Key also works
Press Help Button
Shortcut To KOdi
Some more Tweeks /Box is running Not Bad
Also Have Been Testing Different Launchers
Maybe Test Station Launcher by mo123
For a different Look
Happy Testing
There are currently 1663 users online. 1 members and 1662 guests.
