A95X F4 "AMLogic 905X4"
hi, i'm wondering if anyone has had a problem with this a95x f4 not fully turning off when powering the box off.. when this happens nothing i do will get the box to turn back on other than unplug it and plug back in. i haven't touch any settings or did anything yet, i'm just wondering whhy it's doing what it's doing..
skharel do u see the prerequisites to TWRP this will not work with SOC S905X4 are you trying to encourage people to brick their A95x F4 boxes- Download the recovery file that corresponds to our SoC:
– TWRP S905X2 / S922 for Android 9
– TWRP S905X2 (thanks to the user ViT)
– TWRP S905X
– TWRP S905
– TWRP S912 for Android 6 / TWRP S912 for Android 7
Originally posted by Darrell View Posthi, i'm wondering if anyone has had a problem with this a95x f4 not fully turning off when powering the box off.. when this happens nothing i do will get the box to turn back on other than unplug it and plug back in. i haven't touch any settings or did anything yet, i'm just wondering whhy it's doing what it's doing..
-I used both devices 905X4 F4 and 905X3 F3 too;almost as same saying description occured!
-and seems that "updates"(many of them)never fixed this issue too!! both 905X3 and 905X4
-now,I use 905X4 and some times device never opened or never completely OFF
note;yesterday I got another issue that device actually opened but not turned to Box UI !!!
so,y'll see these issue as well ON/OFF issue and stuck or not opening happens etc.,
and producer release many OTA updates but still w'v some of vital BUGs too
"Rooted" version awaiting
including awaiting a custom ROM as well!!
I do not work stable even with a lot of Apk. and still does not work either
Try this Maybe
Longpress/Hold down Power Button..
Should be Pop Up with Options
Power Off
Restart
Screenshot
Power Off and Restart work
Have not tested Screenshot
Happy Testing
Originally posted by masher17 View Postthis is the fan I always use from amazon https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
But that's a good idea unplugging the LED...I am still in the setup / testing phase, after the last OTA my WIFI works best on the 2.4Ghz...that was one main problem I was having, the IPTV works well now, but the Nova TV Apk 1.5.0b doesn't work in this box, Kodi 19 works & Filmplus v.1.2.8 works real good.
I know the box has no root, I haven't checked after the updates for root....
It would be nice if we knew what the updates fixed, it just says optimized system and fixed bugs....lol
Thx for Link to Coolers!!!!
AC Infinity Most Excellent!!!!
I went with the Dual 80 mm / 3.1 inch...
Super Quiet even on High
30 inch Tether between Fans with USB port for Additional Fans
All on same Speed Control
Rubber Feet / Standoffs Awesome Set Box Right on Top...
Very Impressed
Streamed Flu Tube for an Hour 4K to test
Bring Tempature Down From 69 to 49
Or Maybe All these Updates have been adjusting Clock Speed....
Ha Ha Ha
Box Running Much Cooler And Smoother Either Way
Happy Testing
Originally posted by matrix777 View Postskharel do u see the prerequisites to TWRP this will not work with SOC S905X4 are you trying to encourage people to brick their A95x F4 boxes- Download the recovery file that corresponds to our SoC:
– TWRP S905X
– TWRP S905
, I did brick few of them myself tho.
Originally posted by freddy View Post
Can be common issue with Any TV Box...............
Try this Maybe
Power Off
Restart
Screenshot
Happy Testing
Guest
Fleury Unplug the box for few minutes wait and plug it back in and try again. This box is poorly designed, and so far I think a piece of crap, so sad that many of us fell for this box. All of us expected this one to be really awesome, and we got fooled.
I think there has been 3 OTA updates and I don't see anything that was fixed or changed, I've had to unplug the box twice to get it to start working again.
Oh here is a good one, If I switch off the WIFI and plug in the Lan ethernet cable to update anything, and then unplug the Lan cable and switch on the WIFI It wont let me, the screen goes black I cant get into the settings to switch back on the WIFI....there is a few ways to get into the setting but the screen goes black every time...and then I have to unplug the device wait and try again.
In a way this is funny, I am glad that I bought this only for the bedroom and its not used every night.
I know money is the problem for most of us, but my main box that works the best is the Nvidia Shield, but costly and it was well worth it for me. Good luck to all and have a wonderful day.
Originally posted by masher17 View PostFleury Unplug the box for few minutes wait and plug it back in and try again. This box is poorly designed, and so far I think a piece of crap, so sad that many of us fell for this box. All of us expected this one to be really awesome, and we got fooled.
I will try your suggestion. That box really sucks. Yesterday it was the turn of Bluetooth not working, I had to do a factory reset. Thinking about buying the x96 x6
There are currently 2438 users online. 0 members and 2438 guests.
