A95X F4 "AMLogic 905X4"
w'll see Update or lot of updates on next "new model!"
another "A95" brand Box
>Android-10 not proper/good etc., solution at least for our Box!
>Android-11 might be way better solution(who knows that)
since last two months that I'v tried to install many APK.s and mostly all those
ones does not work properly! even some of does not installed!
I'm looking a new Box fm UGOOS(AM7 with 905X4) well its kinda pricey but looks
good and already Technozon reviewed this new Box and seems that very fine
Auf YouTube findest du die angesagtesten Videos und Tracks. Außerdem kannst du eigene Inhalte hochladen und mit Freunden oder gleich der ganzen Welt teilen.
To be honest, I'm not sure why this box is getting such bad comments on here. What are you guys are trying to use it for? I use it as a streaming box and it is working pretty flawlessly.
I did modify it to run a fair bit cooler and maybe that is part of the problem you are encountering. Not having root is a bit of a pain as I would like to change the governor to Scheduling but apart from that, most functions are working fine.
Root is a double edged sword as a lot of official apps may not work correctly on rooted devices !!
Guest
Adrian Johnson not all these boxes are the same, some are flawed right out of box, some don't even work from the start. Mine if you change the Wi-Fi from 2.4 to 5Ghz the screen goes black and you cant get into the setting to change it, I had to un plug it to be able to switch it back. That has been fixed with one of the OTA updates...
A lot of us have the older A95X F3 which is rooted and had a few OTA updates and that box worked really well, a lot of us was hoping that this would be as good as the older A95X F3 is and still is better then the A95X F4....
yep its right
to this Box "A95X-F4" with Android-11
I got a message by Twitter but I do not who is this person,so in briefly said that Andro-11 ready for A95X box!!!
probably a new ROM or may rooted or whatever....
I'm waiting his response for this action!
and also I invite this person to ...come to Freaktab Forum...
such a mystery or what
will see it soon
Originally posted by hacko View PostHi guys, i have a question, i don't know if its normal or not, when i press reboot i need to disconect from power, the same after a power off (its don't start from rc)
it is normal? should i reinstall the firmware to test?
same behaviour on A95X3 F3 too
sometimes RC or any other Closed/re-start do not work correctly! and it freezes or do not respond
so have to power-off(fm power source)and re connect the Box as well
I got this error/bug same us A95X3 and now with new A95X4 too
Originally posted by Adrian Johnson View PostTo be honest, I'm not sure why this box is getting such bad comments on here. What are you guys are trying to use it for? I use it as a streaming box and it is working pretty flawlessly.
Hi, I am new to Tv Box.
I have A95X F4 4/64 model.
My problem is that after streaming YouTube in hd for half an hour the temperature goes up to 82°C SOC and 85°C DDR. I checked it using AIDA64 Apk. Sometimes it reaches up to 91°C.
When the temperature goes above 90°C, the wifi stop working and I can't open any app.
Is it normal Temperature for this box?
I did reset to this box and didn't change any setting to see if it would help. But it didn't.
I was wondering what can I do to reduce the temperature without cooling fan as it is hard to find in my country.
Sorry for the long text.
I am so pleased to hear your answers (Note: I have an error uploading photo)
There are currently 3070 users online. 0 members and 3070 guests.
