A95X F4 "AMLogic 905X4"
    In Droid settings
    Picture Mode(does it work?)
    Have Not Tested...
    >Picture Mode;worked(I selected "user")
    >Custom Settings;worked(mine is 50/50/45)
    >DNR;not worked and always stay in "medium"!!
    I cant find ...In settings under services
    Allow APKPure Auto install ?
    note;probably,after OTA update and Factory reset;I'v removed this "APK-Pure"!
    Screen-saver never worked especially if you connected ext.HDD or USB-disk to the device!!
    and also "WallPaper" does not worked properly and it shows with device Papers and incl.my personal Photos even my Movie/Clips etc., files WTF!
    ...However Have installed Hidden Android Settings APK
    OLder Version V0.1 by Kasitskyi has no Ads
    Newer Version from Playstore/APKPure bloated with Ads....
    I do not find or do not understand this
    ...Customize Your Pixel.....
    There is Screensaver Settings there
    Maybe apply and will work for You
    do not urderstand too ??
    I always use Airmouse as well since a very long time,otherwise Remote sometimes sucks!
    I never use NFlix&YT from my Box(I use for these my TV and IPTV)
    "HELP" button worked for KODI
    Some more Tweeks /Box is running Not Bad... agreed+
    but need custom ROM or stock ROM(bug fix)
    note;Andro-10 kinda problematic with this Box! might be "11" will help?
    "Launcher" is does not matter for me at present
      APKPure Auto Install
      Go To
      Settings
      Device Preferences
      Accessibility
      Services
      Most TV Boxes come with System Settings Sub Menu or
      More Settings
      Advanced Settings
      Settings Settings
      Some Dont like This TV Box
      So there are APK,s Apps that allow access to Hidden Android Settings/More Settings/Advanced SEttings
      Tv Box Rom is Clone of/Based on Phone or Tablet
      These apps take you to Hidden Settings
      When you open Hidden Settings the first Header will Read as Customize Your Pixel
      That is why posted Customize Your Pixel
      Android 10 is Fine for now
      Box is New...
      Custom Rom is always best
      Iam still in shock and disbelief from Not 1 but 2 OTA updates....
      More Testing
      Happy Testing
        Is there a way to make display bigger?
        Hi all I was able to change the display setting using this app from Play Store https://play.google.com/store/apps/d...hl=en_GB&gl=US
          Hi Freddy
          for APKPure;my device shown below>>>
          Accessibilty;Services; "SD Maid" only!! there is no APKPure! and my Apk. for "Cleaner" Apk. and kinda works unstable!)
          and no any Apk. seems on Services
          But anyhow its not for my vital Apk. this "APKPure"
          Yesterday I'v hv been tried to install this Apk. from APKPure own site/side and its not worked stable! even everytime I got such a warning
          ""check your internet connection"" and no any item worked! but in the meantime my Internet Connection always is ON and worked
          perfect! why APKPure says; no internet connection! weird
          A lot of other Apk.s also not worked stable even not worked.....
          So,seems that in near future I'll say bye+bye to this A95X4 device!
          This device doesnt work well and does not support or stable-work etc., with "ANDROID-10"!! I guess might be Andro-11 may work!
          previous A95X F3 model with Android-9 works way better then this new one
          Yesterday I gave a new order for the new RK3566(X96-x6 8/64)from Banggood and seems that they have shipped my parcel today
          https://www.banggood.com/X96-X6-Smar...se=CN&ID=47184
            ...So there are APK,s Apps that allow access to Hidden Android Settings/More Settings/Advanced SEttings
            if you are saying;"Accessibility" menu and SERVICES;no any Apk.s is there!!
            or one Apk have,that this one my own Apk. is "SD MAID PRO" for Cleaning/restoring etc., but this Apk also not well worked! unstable(stable with A95X3 F3)
            So cant find any "Hidden" menu and any further pages&menus etc.,
            strange Box though
              Originally posted by bergamesk View Post
              ...So there are APK,s Apps that allow access to Hidden Android Settings/More Settings/Advanced SEttings .....
              Activity Launcher (Google Play)
                Got today KM6 Deluxe, underbox part is metal so i assume better cooling.
                A TV 10 menu is bit different then the A TV 7.1 and it's missing backround (all is only black so far).
                But seems more fluent then A95X
                Remote control is also much better (BT instead of IR)
                Android devices: Minix X7 (gone) , Minix X8-H , MK808b Plus
                Video Out: Benq W1000+ 1080p Projector
                Audio Out: HDMI -> Yamaha RX-V467B + 5.1 Yamaha Speakers
                Remote: Rikomagic MK702 II, Minix NEO M1
                Storage: NAS Zyxel NSA325v2
                  Greetings Bergamesk
                  Apologies for the confusion
                  I do not use Play store as the only source to install Apps
                  I prefer to sideload APK,s from other Sources like
                  APK Pure
                  APK Mirror
                  Aptoide
                  Android APK
                  etc...
                  You must First install APKPure to the TV Box then can Apply
                  My Bad
                  Hidden Android Settings is an APK/App you can install to any device TV Box/Tablet/Phone...
                  Big G search for
                  Hidden Andoird Settings APK
                  Available at
                  Play Store
                  Apk Pure
                  Apk Mirror
                  Whats this about a Rockchip on the Way???
                  Giving up on S905X4 so fast
                  Or Android 10
                  Ha Ha Ha
                  Happy Testing
                    freddy sorry for silly question...but what is the benefit to use other sources (APK Pure,,APK Mirror,Aptoide,Android APK...) then Play Store?
                      killeriq I use Aurora, APK Pure is my favorite and APK Updater and Google Play-store, this way there are updates for some that don't show up in the Play-store ...But I don't ever use auto updates
                      On this crappy A95X F4 box it doesn't matter if you auto update, on some other boxes, like the H96 Max those fixed YouTube and Chrome icons, if you auto update they stop working because they are fixed and cant be updated...really weird
                      I have a new Box coming with the Amlogic S905X4 that isn't sold yet in AliExpress and going to compare it to this A905X F4 and see if there is anything better.
                        Guys new OTA again last night
                          yep what "new" OTA update did it!
                          -actually "905X4" very fast device but not stable with Andro-10 system! my lot of Apk.s does not work well&easy!
                          -my quiz is;is it possible to transfer Andro-11 by firmware(OTA)??
                          -KODI is OK(I'v uninstalled default TVMP)! all Kodi Addons works stable
                          -with this last update;Box come a little bit faster!! I'v 64GB Flash-disk for my Photos(more than 60k photos)search and opened all those files
                          very fast(before it takes for example 3min. but now it takes 2min.!!)
                          -Picture quality;"videos"(fm ext.USB-Flash&HDD)almost very good with G31GPU,YTube 4K/HDR etc., OK
                          Dont forget;do it "factory reset" after firmware updated!!
                            Hi,wondering what "Brand" is this new 905X4 device??
                            btw my new ordered box(thru Banggood.com) on the way>>>X96 X6 RK3566 with Ram8Gb/Rom64Gb+Andro-11)
                              I'll let you know when I get it, it just might be a fake box.
                                almost all BRANDS is fake!
                                The real manufacturer is one or two or three..
                                but there are more than hundreds BRANDs in the market haahhaaaa
