K-R42 - wasser firmware - JB Android 4.2.2
    version 1.2.5
    - based on 4.2.2 JB
    - support old and new revisions
    - preinstall es filemanager, reboot, hwkeyboardhelperdemo
    - tvout fix
    - 1080p/720p boot and kernel images
    - cwm-recovery
    - rooted
    - init.d support
    - 1080p-24hz, 1080p-30hz, 1366x768p60hz support
    - nfs, cifs, ntfs, cdrom filesystem support
    - add launcher switcher
    - add auto hide systemui
    - add eth notification title
    - add screenshot
    - remove google searchbar
    - remove cpu/ddr lock on rk3188t
    - stock ir remote fix
    Link download:
    firmware without kernel:
    1080p/720p kernels for old revision:
    1080p/720p kernels for new revision:
    version 1.2.4
    - support Ugoos UT1, K-R42, T-R42 (only old revision)
    - preinstall xbmc, es filemanager, reboot, hwkeyboardhelperdemo
    - update kernel, improve suspend/resume, stability
    - 1080p/720p boot and kernels
    - cwm-recovery
    - rooted
    - init.d support
    - improved video streaming
    - 1080p-24hz, 1080p-30hzi, 1366x768p60hz support
    - nfs, cifs, ntfs filesystem support
    - allow user to set static ethernet mac adress
    Link download:
    http://www.freak-tab.de/wasser/firmware-wasser-1.2.4.zip
    oc kernels
    kernel-k_r42_new_revision_cpu1704_ddr720_1080p_gpu600h
    kernel-k_r42_new_revision_cpu1704_ddr800_1080p_gpu600h
    kernel-k_r42_new_revision_cpu1800h_ddr720_1080p_gpu600h
    kernel-k_r42_new_revision_cpu1800h_ddr800_1080p_gpu600h
    kernel-k_r42_new_revision_cpu1920h_ddr720_1080p_gpu600h
    kernel-k_r42_new_revision_cpu1920h_ddr800_1080p_gpu600h
    kernel-k_r42_old_revision_cpu1704_ddr720_1080p_gpu600h
    kernel-k_r42_old_revision_cpu1704_ddr800_1080p_gpu600h
    kernel-k_r42_old_revision_cpu1800h_ddr720_1080p_gpu600h
    kernel-k_r42_old_revision_cpu1800h_ddr800_1080p_gpu600h
    kernel-k_r42_old_revision_cpu1920h_ddr720_1080p_gpu600h
    kernel-k_r42_old_revision_cpu1920h_ddr800_1080p_gpu600h
    version 1.2.3
    - old revision support
    - wifi support
    - ethernet support
    - init.d support
    - 1080p24hz, 1080p30hz, 1366x768p60hz support
    - frame skipping fix for video play
    - rooted
    - ntfs, nfs, iso, cifs filesystem support
    - 40% like performance boost
    - preinstall es file manager, xbmc
    - new kernel, improve sleep/suspend, stability
    - support static ethernet mac adress
    - passthrough support in xbmc
    - fixed lan rx network traffic
    - fixed bug in formating the NAND Flash, sdcard is mount correctly
    - fixed tv-out bug
    Link download:
    1.2.3 firmware for k-r42 with OLD REVISION
    1.2.3 firmware for k-r42 with NEW REVISION
    Be aware: it is your own risk!
    please post your feedbacks, it's very important! and don't forget to report the firmware version you flashed, the revision of your k-r42!
    Thanks for making a thread about your kernel. Perhaps it's a good idea to describe how to install new kernels? That should avoid a lot of questions i think.
    I've got a question to start off with: does wifi work after suspend? I've tried one of your earlier kernels and it didn't come up again after suspend.
    Edit: the link points to the t-42 version.
      Wasser, thank you, great job. I'm going to flash my device today with this software.
      I am agree with fes suggestions.
      It's software - not kernel.
        Thanks for pointing out the mistake I'm so used to wasser making kernels until now.
          Old revisions supported?
          CS918(old wifi)+Air Mouse ea-01
          Out: TV LG HDMI (1 day a week AV out Samsung Tv)
          CX919(wifi ap6210)+Mele F10
          Out: TV LG HDMI
            +1
              it supports old revision too
                Originally posted by wasser View Post
                version 1.2
                I've flashed new rom to my K-R42 (v2.1).
                Small comparison wasser's rom to chinese rom (from previous, latests links):
                - slower WiFil; bandwidth decrease (in tests) from 7.5-6.7Mbps to 3.1-2.6Mbp;
                - ETH is not working (same packet lost like in Lewy's rom);
                - wallpaper is really nice;
                - sleep works the same but resume is better - with standard IR remote works every time;
                - increase score in AnTuTu from 17327 to 19752
                I'm going to fllash back chinese rom because both WiFi and ETH works perfect! Moreover justXBMC and XMBC "Frodo" works too!
                K-R42 PCB 2.1
                  Witch one? Link? thx
                  RK3288 Devices
                  - Overview BOX (LINK !)
                    version 1.2
                    Witch base ROM?
                    thx
                    RK3288 Devices
                      Hello wasser,
                      Thank you very much for this newest ROM!!!
                      I have not tried it yet because I'm playing now with my solution which I informed you about in another tread http://www.freaktab.com/showthread.p...l=1#post110142
                      There was described situation where I were trying to run speedtest and device was going to rebut while UpLoading part of test just started. But in spite of this issue and error obtained with using "busybox ifconfig eth0" concerning the RX traffiic, movies are streaming perfectly for me through the LAN.
                      Looking through build.prop I have found a little mistake with excessive gaps:
                      net.tcp.buffersize.default=4096,87380,256960,4096,16384,256960
                      net.tcp.buffersize.wifi=4096,87380,256960,4096,16384,256960
                      After removing them I don't have any reboot with speedtest.
                      I have just looked at build.prop of this your new ROM and found the same gaps.
                      I hope my tiny finding helps you
                      CS918II/16GB(HTC-031-V1.0 board)
                      CS918 (TN-BX09_V2.1 2013/05/31) FW: k-r42-old_revision-wasser-1.2.3- fried by 12V PS
                      K-R42 board version B351_V2.0 1348, wifi Realtek8188ETV , RK3188T;FW: wasser-firmware-kr42-new-1.0.3
                        Originally posted by digger View Post
                        Hello wasser,
                        Of course any finding helps me a lot. thanks digger!
                        Do you have k-r42 revision 2.1? if yes does ethernet work for you?
                        it seems some user still have problem with ethernet. sadly i don't have have to test it.
                        thanks
                          hello k-r42 revision 2.1
                          could someone please give me feedback if ethernet work for you? the feedback is very important for me to improve the firmware!
                          thanks
                            thanks
                            A quick note about your download link mate.
                            Even tho your link says K-r42-wasser-1.2.1.zip when you actually click it then it downloads T-r42-wasser-1.2.1.zip
                            If I change the link manually to http://www.freak-tab.de/wasser/k-r42-wasser-1.2.1.zip then I get the K zip.
                            Have you got this wrong mate?
                            To Infinity and Beyond.... XBMC
                              Downloaded (replacing T to K) and flashed.
                              Seems to work, including lan.
                              But sometimes - random reboots
