K-R42 - wasser firmware - JB Android 4.2.2
    I use parameter...
    1 . 0x00000000 Loader Image\RK3188Loader(L)_V1.24.bin
    2 x 0x00000000 parameter parameter
    3 x 0x00002000 misc Image\misc.img
    4 x 0x00004000 kernel Image\kernel-1080p.img
    5 x 0x00012000 boot Image\boot-1080p.img
    6 x 0x00020000 recovery Image\recovery.img
    7 x 0x00892000 system Image\system.img
    At CWM Screen I got some errors because of unable to mount xyz too, but I ignore it and make a restart from the menu...
    Then there is a black screen for a wile and now I've the desktop...
    RK3288 Devices
    - Overview BOX (LINK !)
      Originally posted by no_spam_for_me View Post
      BTW: can you explain the different and/or do you have a link?
      In MX you have 3 decoding options :
      SW : software
      HW : hardware
      HW+ : hardware plus
      passthru can only work in HW, cause in HW+, audio stream is decoded by hardware into PCM surround.
      Franck
      for windows8.1 drivers fix follow this.
      Jesurun v2.1 old rev with wasser firmware 1.2.5
      K-R42 v2.1 new rev with wasser firmware 1.2.5
      Minix neo x7 mini with quickshot firmware 3.1 with kernel HDMI patch
      Minix neo s8s with stock firmware
      Plex streamer with external MX player
      TV Sony Bravia HDMI 1080p/60hz with AC3/DTS passthru.
        Originally posted by ndriutti View Post
        Hello,
        I'm trying to flash wasser's firmware but at first boot I get stuck with the CWM recovery menu. Which "parameters" file should I use? There are four: parameter, parameter8, parameter10 and parameter14...
        Thank you for your help!
        Use parameter without number.
        At CWM choose erase cache and then reboot.
        Enjoy !
          Originally posted by franckleroy View Post
          Just upgraded to windows8.1 and that f***ng rk driver doesnt work anymore...
          Do you try these way and next posts (downgrade to usb1) ?
          RK3288 Devices
            Originally posted by wasser View Post
            - audio issue is now fixed, it will be released at the weekend
            Do you mean passthrough? Or just audio in general? (hoping for the first offcourse )
            Thank you for the development.
              Pass through
              Hello
              I was told that the pass through issue is just wrong settings in mx player.
              I was told to set the system to HW NOT HW+ and that all of the features then work correctly ...
              But I do NOT use XBMC so there you have it, lets us all know if it works
              Once Wasser releases the new firmware ... And normal audio is working again ...
              Michael T.
              3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
              CVSB-K200-Wireless Mini QWERTY Keyboard / Motion Mouse for Android RF
              Rii Mini i25 Qwerty Keyboard/Motion Mouse For Android RF
              Media Flow Suite ... 24 TB ReadyNas Pro wired 1 GB Ethernet
                Hi franckleroy,
                What is your impressions after flashing wasser 1.2.1 FW? Have you noticed something strange with mutual influence of Ethernet and wifi in case they are switched on at the same time? And do you have unexpected reboots too?
                CS918II/16GB(HTC-031-V1.0 board)
                CS918 (TN-BX09_V2.1 2013/05/31) FW: k-r42-old_revision-wasser-1.2.3- fried by 12V PS
                K-R42 board version B351_V2.0 1348, wifi Realtek8188ETV , RK3188T;FW: wasser-firmware-kr42-new-1.0.3
                  yes tried but doesnt work on my pc ...
                    Originally posted by michael2t View Post
                    Hello
                    Michael T.
                    NO when mx settings are ok, some movies are ok (DTS and AC3) but other not, compressed audio is apparently sent to receiver but my receiver display PCM and then I can only hear noises...
                    Franck.
                      Originally posted by digger View Post
                      Hi franckleroy,
                      Hi I have 3 kr42 and one minix 7 ;-)
                      I do prefer lewy fw as mele F10 mapping is better than in wasser one (especially the home button).
                      With wasser or lewy fw plus 1st november kernel it is quite stable, but I never put on wifi... because on eth0 I can stream at 50mbits and only 20mbits on wifi.
                      I cant use last wasser kernel (11/11) no mac, no eth0, no wifi, If a try system crash and reboot.
                      I do not test passthru for the moment, the priority is to find a stable system.
                      Franck.
                        Hi wasser
                        does you kernel include sam321 workaround for video playback ?
                        I use Finless 1.6 ROM + kernel_molle_20131109_neox7_1080p_cpu1608h_ddr720_ gpu600h_vsfsam on my x7mini and the playback is perfect !
                        Franck.
                          What's about NFS support?
                          In ES File Manager I only see my "errorsoft" (MS) NB but not the NFS share by haneWIN NFS.
                          Are the needing libs exist in this mod and if yes, witch one have to be instmod...?
                          RK3288 Devices
                            Hi wasser
                            Franck.
                            yes, it's included in my kernel
                              nfs is supported in all my rom.
                                1.2.2 firmware coming
                                Hi all.
                                i'm uploading 1.2.2 firmware for k-r42. It will be available sonn for download.
                                Some changes in the new firmware:
                                - new kernel
                                - improved suspend/resume, stability
                                - improved video playback
                                - fixed audo issue
                                - fixed key mapping issue
                                - support all revisions (you have to choose the correct one)
                                important:
                                - please erase NAND (click EraseIDB button) before flashing the firmware
