K-R42 - wasser firmware - JB Android 4.2.2
Originally posted by digger View PostHi wasser,
It's great that you have released your newest FW.
But situation with them crashes my brain entirely
1) I tried to flash my device with k-r42-new_revision-wasser-1.2.2 (suppposing I have new revision 2.1 board),
but have following:
-Eth - doesn't work(could not switch it on);
-wifi - doesn't work(could not switch it on).
-720p kernel(No 1080p???)
2) Flashed with k-r42-old_revision-wasser-1.2.2.
-Eth - works(but log shows me the same mistakes with RX packets), Speed Test crashes and causes reboot;
-720p kernel(No 1080p???).
Do you have any idea, or I missed something important?
There's a wifi regressison in 1.2.2 from yesterday. It's now fixed in 1.2.2 firmware from today. Please download it and flash again.
it's real 1080p kernel, the new kernel now just uses overlay which has great graphic performance and has self detection for the resolution 720p/1080p.
Originally posted by lefizz View PostI have the 2.1 board, I have flashed twice with the new revision firmware and always boot into cwm with these messages
Sent from my JY-G4 using Tapatalk 2
Originally posted by wasser View Postjust select "reboot system" to leave cwm.
Weird, should i try the old revision firmware?
Originally posted by lefizz View PostBut there are error messages at the bottom. Anyway, it sit there for about 10 seconds before crashing out. It reboots to a black screen. Basiclly it doesnt work.
Weird, should i try the old revision firmware?RK3288 Devices
- Overview BOX (LINK !)
Originally posted by wasser View Postit seems you have the old revision board. so you should use the k-r42-old_revision-wasser-1.2.2.
Have downloaded both your FWs (today Nov 17 version).
Tried to flash each of them.
But they behave with my device differently in compare to your version from yesterday.
I had Yesterday:
1) For k-r42-new_revision-wasser-1.2.2:
2) For k-r42-old_revision-wasser-1.2.2:
I have Today:
-wifi - works.
-720p kernel(Not 1080p kernel)
-Eth - works(but log shows me the same mistakes with RX packets), Speed Test doesn't crashes and doesn't causes reboot;
-wifi - works.
-720p kernel(Not 1080p kernel).
It is quite weird, isn't it?
I'm not able to obtain 1080p. I don't know why and what I have to do else so as to have it.
I couldn't take screenshots with AnTuTu information about GPU spatial resolution, because screenshot is cutting the image by some strange rison and capturing the central extra-zoomed part only. I have managed to take screenshots(extra-zoomed too) from Display Tester V.3.6.0. for both your today's firmwares. Here they are and they are identical with 720p:
CS918II/16GB(HTC-031-V1.0 board)
CS918 (TN-BX09_V2.1 2013/05/31) FW: k-r42-old_revision-wasser-1.2.3- fried by 12V PS
K-R42 board version B351_V2.0 1348, wifi Realtek8188ETV , RK3188T;FW: wasser-firmware-kr42-new-1.0.3
OK after deleting the cache partition and waiting for a 5 minute reboot it eventually went into android Yipee!!!
First things first this rom doesnt have XBMC installed, where can I first the right version for the RK3188??
Oh, and thanks for all the help. Much happier with my new purchase now, oh and ethernet is working which is great.
Thanks a lot
I had Yesterday:
I have Today:
-wifi - works.
-wifi - works.
[ATTACH=CONFIG]3997[/ATTACH][ATTACH=CONFIG]3998[/ATTACH]
the 1.2.2 firmware from today has a fix for wifi and it's expected that wifi works again in the 1.2.2 firmware from today. As i said before you have old revision board. Please use the old_revision firmware.
thanks
Originally posted by wasser View Postthe 1.2.2 firmware from today has a fix for wifi and it's expected that wifi works again in the 1.2.2 firmware from today. As i said before you have old revision board. Please use the old_revision firmware.
How can I tell if my CS918 board is old revision or new revision board? I am new here and just wanted to be sure before I flash your new firmware. Great works! keep it up!
Just by disassembling device (open it) and have a look at the PCB (board)
RK3288 Devices
Originally posted by wasser View Post- could you please post the output of "ifconfig" which shows mistakes with RX packets and the dmesg log ?
thanks
Originally posted by no_spam_for_me View PostJust by disassembling device (open it) and have a look at the PCB (board)
http://www.freaktab.com/showthread.p...l=1#post102362k-r42 Board TN-BX09_V.2.1 2013/05/31 ,wifi RTL8188ETV,
rom 1.0.4 (kitkat) old revision Wasser
There are currently 2175 users online. 0 members and 2175 guests.
